  4. [solved-ish] Reset Reaction doesn't allow multiple Conditions in Groups
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 2 Posters 1.1k Views 2 Watching
    I'd like the "None deferred" Reset Reaction group to have multiple Conditions. Is this not possible?
    Running latest version of MSR, 23049-1fd87c91
      Hm maybe I’m not understanding the question, but can’t you just hit the “+ Add Condition” button for the nine deferred group?
        @Pabla That's what I would expect but neither that or the copy button respond in the anticpated manner.
        I've been poking at this a bit more. I've consistently been able to reproduce as such:
        Scenario 1
        • Create group
        • add condition - make selection from dropdown (entity, rule state, etc), use subsequent dropdown to hone further from the initial choice (choosing the entity, selecting the Rule, etc.)
        • add condition - make selection from dropdown (entity, rule state, etc.), try to use subsequent dropdown to home further and no response.
        Scenario 2
        • Create group
        • copy button on the first Condition - nothing happens. No copy, no error, nothing.
        PablaP 1 Reply Last reply
          Scenario 1
          • Create group
          Scenario 2
          • Create group
          @gwp1 Weird I just tried this and was able to add multiple conditions, maybe try clearing browser cache and restart reactor? Beyond that I am not sure
            @Pabla Weirder still, now it works for me. ONLY DIFFERENCE... I wiped out the Reset Reaction completely and started fresh. All other times I had built the first group and copy button'd it to another.
            Let me try that to create the MBthR group now that I have the None Deferred group done.
            UPDATE: it's WAI now. 🤷♂
            "What changed?" I am doing this work from a different Mac. Same browser on both.
            UPDATE to the UPDATE: went back to the original Mac, browser was still open but the MSR tab closed. Opened new tab for MSR in same instance of the browser and... worked fine. 🤷♂ 🤷♂
            Will mark this as solved - I hate gremlins.
              163.8k
