  4. localization settings
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
17 Posts 4 Posters 2.5k Views 4 Watching
    Using the following localization settings in reactor.yaml:
      units: metric
      locale: fi-FI
      time_format: "%H:%M:%S"
      date_format: "%d/%m/%Y"
    But still I'm getting US date & time formatting, so settings do not seem to override defaults? Using 23049 on Synology Docker
      There's no custom language file for Finnish that I'm aware of (there is definitely not one in the standard distribution). The config override of locale is really intended only for developer testing of localizations while they are doing them. In the absence of such a config/language file, Reactor can't know what to do and relies on nodejs to provide the formatting, which requires that the locale be correctly configured on the host.
      Locale for the host side is usually derived from configuration of the host itself (OS-dependent), or the docker container (by adding a LC_ALL environment variable to the container configuration).
      Display on the browser side (i.e. in the UI) is controlled by the browser's locale setting. Always (regardless of the locale setting on the host or in config).
        @toggledbits wasn't expecting language localization, but date & time. From the manual:
        "You can override the locale Reactor uses for both browser and host display by setting the locale key in the reactor section of reactor.yaml"
        "By default, dates and times are displayed in the settings determined by the locale (including the order of month, day and year in date displays, and 12/24 time display)"
        So by setting locale in reactor.yaml I was expecting to see e.g. 24 h time format. That didn't happen and then I added time_format and date_format, but still no change?
          @tunnus The time_format and date_format are no longer used, since the locale configuration now determines the date and time format.
            @toggledbits okay, but any idea why using "locale: fi-FI" in reactor.yaml does not change date & time format in UI? Or should it?
            FWIW, using Chrome with Finnish as preferred language (but as said, not expecting to see language impact here, only date/time formatting)
              ...I even tried adding LC_ALL variable to Docker with "fi_FI.UTF-8" as a value, but again no impact (for time formatting).
                At the moment it's an all or nothing deal... if there's a translation file, it will accept the locale; otherwise, it just sticks to default US English.
                Maybe you should write the fi-FI translation? 🙂
                  @toggledbits said in localization settings:
                  Might even do that 😁 But in the meanwhile wondering if nobody else is interested to get 24 hour time display. @therealdb & @Crille ?
                    The Swedish translation at http://[ip]:8111/reactor/sv-SE/ is in 24h format if the browsers locale setting is set to it.
                      @tunnus I have started Italian translation, but I'm busy with other things and I like American English anyway. But we could try to create an international English with 24h clock and right date formats, just in case 🤣
                        I'm working on some changes, but it may be another week. I'm swamped right now.
                          For anyone here trying to get the 24H & right date format 🙂 just add this to your reactor config file (at least v 23063 required):
                          reactor:
                            units: metric
                          Restart, hard refresh your browser and you're good to go. Thanks @toggledbits !
                            Note: you only need to do this if your locale-defined time format isn't 24 hour.
                            Also, the format shown by @therealdb might be normal for his locale, but not yours specifically. This config will also override the locale-defined date format; if you don't want that, set time_format only.
                            Final note: Locale setting is determined by (both) the locale set for the host OS and the locale settings of your browser. This is the preferred way to set locale. Setting locale in Reactor's config is specifically not recommended.
                            Edit: to be clear, to get your language's preferred date and time formats, you should do the following, in the order listed:
                            1. Configure your host system (or the Reactor docker container) and your browser for the correct locale. This may be sufficient for most uses. Make sure to re-open browser windows from the "root" of the Reactor URL (e.g. click the Reactor logo in the upper-left corner of the page).
                            2. If the time or date format presented by correctly completing step 1 does not suit your preferences, then and only then set date_format and/or time_format in Reactor's config.
                            3. Never use the Reactor config locale setting; this is for developers only and is not a complete solution for getting the correct locale. Locale configuration is always inherited from (both) your host system and browser, and that is the only correct way to do it permanently.
                              @toggledbits so with build 23063 Docker environment variable LC_ALL should work (tried with build 23049, but no success)?
                                That will change it on the host side. It has no effect on the browser settings (which are browser-dependent).
                                  @toggledbits yes, just wanted to confirm that with earlier builds LC_ALL was essentially ignored
                                    Not ignored, just not used if there was no language file present for the selected language.
                                      612
                                      3.6k
                                      3.2k
                                      794
