  4. Function sanity check please
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
1 Posts 1 Posters 472 Views 1 Watching
  • 3 Offline
    3 Offline
    MSR: latest-23078-d592d400
    --Docker image on unRAID
    Hubitat C-7: 2.3.5.121
    I'm always looking to simplify my rules and reactions and having finally grasped the Array function with a loop of perform.Action, I decided to re-write one of my rules. The kids like to play music on the Echo devices at a high volume, and I also have TTS loud during the night if a door/window are to open. In order to not have her yell at me later, I wrote a rule that resets the volume on each Echo device to a level of 2. However having 7 Echo's, there are many steps in my Reaction. Set the volume on device 1, wait a few seconds, set the volume on the device 2, wait, and so on.
    Sample snippet of the set reaction: (This works BTW.)
    To make it better, I created an array of the devices and want to run a perform.Action command. Less steps with the same results. Or so I thought. The end result is now a volume level of 0 or 1. I think the Echo gets confused. Either way, not a level of 2 like I was expecting. BTW volume 1 across the room is too low, in case you were wondering.
    New set reaction:
    ${{ each device in Echo_devices: performAction( device, 'volume.set', { level:0.20 } ); 0 }}
    The av_transport.stop works as expected. The issue is with the volume.set, {level:0.20}. Do I have something wrong in my command?
    Global expressions used:
      164.2k
