  4. Is this possible? Store data from Asus Router ajax .asp page for Temperature data.
77 Posts 3 Posters 41.3k Views 2 Watching
    OK. The ~ means the home directory of the login user, and where MSR is running, that appears to be /home/stuart, so that's why the first attempt doesn't work.
    The second attempt doesn't work because you used root/... instead of /root/...... it's a path, not a username, so it needs to begin with a /. Just changing that is unlikely to work, either, because regular users (like stuart) do not have (and should never have) access to the .ssh directory of any other user, especially that of root.
    You need to copy the public and private key files to somewhere where Reactor has access, and specify the full path to that directory in the command line's -i option.
    Alternately, use the public key for user stuart as the trusted key on the router, and let that user make the connection. This is by far preferable, as copying root's private key around to other places and giving it lower access permissions presents serious security risks.
      OK thanks, I changed the command in the rule to this now:
      ssh -i /root/.ssh/id_rsa admin@192.168.0.1 'cat /sys/class/thermal/thermal_zone0/temp'
      I am no longer getting any alert errors in MSR but the local expression is not being populated. As your edit just said that is likely why.
      I then tried this command instead.
      ssh -i home/stuart/.ssh/id_rsa admin@192.168.0.1 'cat /sys/class/thermal/thermal_zone0/temp'
      and
      ssh -i /home/stuart/.ssh/id_rsa admin@192.168.0.1 'cat /sys/class/thermal/thermal_zone0/temp'
      But I get alert errors again.
      "Alternately, use the public key for user stuart as the trusted key on the router, and let that user make the connection."
      That might be the best option. I need to work out how to ssh-keygen for a particular user though ?
        and
        Why? Just use the existing key in ~stuart/.ssh. If there isn't one, you just run ssh-keygen as user stuart rather than as root (no sudo either).
          Got it I just connected to the MSR host logging in as me rather than root user and ran the keygen again, it created the two key files in my own .ssh folder now. I will add that to the router and try again. Thanks
            Its working now with my own public key added to the router. The local expression now has data. Not sure what the \n is on the end though? It didn't do that in the terminal command line.
              @cw-kid the \n at the end is a newline character. Linux is quite literal. You can push that string through the expression int() function and it will convert it to a number and ignore the newline.
                @toggledbits said in Is this possible? Store data from Asus Router ajax .asp page for Temperature data.:
                No idea what that means, but I will search. I also need to do some thing with that data like round it, as it says"66986" which should read as 66.99 degrees
                  OK I see what you mean my local expression is a string. But how to change it to int ?
                  When you create a local expression it gives you no option of the type it should be.
                    Round doesn't seem to work as the raw data does not have a decimal point in it in the first place.
                    How to add a decimal point then?
                      int(RouterCPUTemp) / 1000
                        Perfect thank you !
                        I might even create a virtual device (multi-string plugin) on Vera and have MSR send these values to that also, so I can also have a tile in our Home Remote dashboard app showing this data.
                          You can wrap that in a round() if you only want one decimal (for example)...
                          round( int( RouterCPUTemp ) / 1000, 1 )
                          cw-kidC 2 Replies Last reply
                            #23
                            Even better, you have made my day! Thank you.
                            I have been worrying about my router getting too hot, now I will know if it does.
                                Well that works ! Quickly added a custom tile in Home Remote dashboard
                                And this is the Multi-String device in Vera.
                                Think I can pull other temps off the router also, like the WIFI chips.
                                  Maybe I should also add a timeout to the ssh commands ?
                                  ssh -o ConnectTimeout=10 -i ~/.ssh/id_rsa admin@192.168.0.1 'cat /sys/class/thermal/thermal_zone0/temp'
                                    #27
                                    Think I just found a bug? try naming a local expression as "2.4GTempRaw" without the quotes in a rule and see what happens. I am stuck and cannot delete the expression or exist the rule. Had to refresh the browser to recover. Should of known not to put a dot in the name LOL.
                                    I might have just corrupted the rule now I cannot add an expression named "24GTempRaw"
                                    Or maybe its the numbers it doesn't like.
                                    OK that's better.
                                      You can do Wifi chip temps as well! Wonder what other commands I can send to get data back..
                                        #29
                                        This is much more powerful than I imagined. Seems you can send any old linux command like "free" to see the memory usage. I haven't figured out how to extract and parse just a part of the returned data yet though, say just the "Used" memory value.
                                        (string) " total used free shared buffers cached\nMem: 426020 303308 122712 3404 0 39212\n-/+ buffers/cache: 264096 161924\nSwap: 0 0 0\n"
                                        "303308" is the used memory value, no idea how to extract just that part of the data to another local expression though as its not formatted like JSON data would be.
                                          #30
                                          @cw-kid you're going to have to learn "regular expressions", which are patterns that can be matched in strings. It's another rabbit hole to go down, but here's a specific solution you might build on. Using your response string:
                                          The match() function (refer to the docs) will match a pattern to a string. In this case, the pattern contains "regular expression groups", which are the parentheses and their contents. These groups contain \d+ patterns (you have to specify them as \\d+ as shown because of string escaping in the language)... the \d pattern matches a single digit 0-9, and the modifier + after it tells it to match one or more occurrences — so each \\d+ matches a number made of one or more consecutive digits. So this whole pattern basically finds the word Mem: in the string, then from there finds the six numbers that follow. The 3 in the last argument tells match() to return only the third matched item, which is the number 122712, the amount of free space (it's third in place in the string of numbers based on the header line above it).
                                          You can Google around to find regular expression tutorials.
                                            161.0k
