Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Reactor build 23063
- Reaction Editor (UI): restore wide fields in HTTP Request action; injection from changes in 23049.
- Reaction Editor (UI): fix detection of substitution in some cases that would cause single-action "try" button to not be disabled when a substitution was in the action's parameters (substitution isn't performed on single-action try).
- Entities Page: Action dialog now warns that substitution isn't performed in that tool (launching an action from entity detail panel).
- HassController: support for humidifier/dehumidifier (domain/service and device class, respectively).
- VirtualEntityController: Fix an error in config check that was not allowing underscore (
_
) in entity IDs. - VirtualEntityController: Enforce
x_virtualentity.set_attribute
parameters more aggressively (better error message when not provided). - VirtualEntityController: Fix an error in
that would cause the HTTP API to not give a response when the action completed. - I18n: Rework the loading of locale settings files, their relation to the node or browser locale, and the configurable overrides. Reactor will now use the requested locale (host config, browser config/URL, Reactor config) even if a translation file is not available for it. This places the burden on JS' native Intl, which is ample, and reduces some complexity in Reactor's model.
- HassController: Bless Hass to 2023.3.1
ZWaveJSController build 23063
- Command class
Sound Switch
now maps tochime
capability (Aeotec Siren 6, others) - Support multi-step action implementations (e.g.
chime.play
needs to set two values sequentially (volume then sound).
Reactor build 23078
- Fix loading of local capabilities definitions broken in a previous build.
- HassController: Bless Hass to 2023.3.5
Reactor build 23114
- Conditions: add
is NOT TRUE
andis NOT FALSE
operators. Theis NOT TRUE
operator (for example) is unlike theis FALSE
operator in that, if the tested value isnull
, theis NOT TRUE
operator result would be true, while theis FALSE
operator result would be false. This distinction facilitates some tests where it may be desirable to handlenull
as equivalent to eithertrue
orfalse
without having to provide an additional, separateis NULL
condition (and possibly an enclosing OR group). - DynamicGroupController: document group actions; this makes it an official feature (was experimental).
- Engine/Rule: Clean up a misspelled method name.
- InfluxFeed docs: update supported and recommended versions. [doc]
- HubitatController: Tweak reconnect timing decay (allow for longer decay when hub cannot be contacted for an extended period).
- Reactions: Clarify what "Disabled" means in the constraints of a Group action (incl. Repeat...While) of a reaction. It does not disable the actions in the group. The disable flag applies to the constraint conditions only, having the same effect as it would on rule-based triggers and constraints (i.e. it becomes as if the constraint conditions do not exist). [docs] and [docs]
- HassController: Bless Hass to 2023.4.6
- Conditions: add
MQTTController 23135
- In action payload, force conversion of all data types to string for "raw" output, rather than assuming result of expression is a string (although docs say to do that, it's just too easy to omit, and too easy to change it so the requirement is moot).
- Add
parameter: name
value form to action payload definition to draw payload value from the named parameter without the need to use anexpr
ession (this follows the implementation of action definitions in other Controller instances as well). That is, you can specify, for example,parameter: level
instead of usingexpr: parameters.level
(assuming the parameter value requires no scaling or other modifications to be compatible with the device). [docs]
Reactor Build 23171
NOTE: This build includes fixes made in a prior silent release (where the change(s) affected only one user).
DEPRECATION NOTICE: Support for versions of Home Assistant prior to 2022.5.3 will be removed on the next build. These older versions may continue to operate successfully with HassController going forward, but I will not address/fix issues for them.
- PR 0000356: Fix an issue where a rule with multiple sunrise/sunset conditions using the between operator chooses the first condition's before/after constraints rather than its own (i.e. it was choosing the control states from the first row rather than the current row).
- SystemController: the deprecated
suninfo.sun_angle
attribute is now removed (its replacement issuninfo.elevation
). - HubitatController: Hub variables can now be set up to 1024 characters with hub firmware 2.3.5.135 and above; for earlier firmware, the limit is 255 characters. The length limit is enforced by the hub, not HubitatController.
- HassController: Bless Hass to 2023.6.2
Reactor build 23196 (latest and stable branches)
NOTICE: As announced in the release note for the previous build (23171), Home Assistant versions earlier than 2022.5.3 are no longer supported.
- Introduce a maximum delay in the write-back of certain storage containers (e.g. that used for expressions).
- Docs: fix an error in an example on the How-To: Expressions with Entities page.
- HassController: Bless Hass to 2023.7.2
Reactor build 23218
- Improve the initialization of new global variables so they don't show "not yet evaluated" until a non-null value is set (null is a valid evaluation result and should remove the "not yet").
- Expressions: improve the display of non-printing characters in the expression editor's "current value" display (they now display as Unicode escape sequences).
- i18n: Fix init of localized weekday names when most recent Sunday occurs in prior month (caused, for example, incorrect weekday checkbox labels in Weekday conditions; cosmetic only, no operational effect).
- SystemController: for Reactor update, include update branch, version, and commit as attributes on system entity.
- Entities page: New Copy Attributes button in entity detail copies all attribute values to the clipboard.
- HassController: Bless Hass to 2023.8.0
Reactor Build 23242
- Rules Editor: Fixed an issue where a condition option change to the duration operator with no change to duration value may not be saved.
- HassController: Add mapping for
proximity
domain (tovalue_sensor
). - HassController: Bless Hass to 2023.8.2
ZWaveJSController build 23254
- Some versions of iBlinds v3 report CC 38 (Multilevel Switch) and some report 106 (Window Covering), no obvious way to tell if there's a config parameter that controls this, or if it's a firmware change (firmware versions report same even when command class is different). Update handles both based on what's available (this is the first time I've seen a 106-reporter in the wild).
MQTTController build 23254
- Improve recovery time when broker is starting up, accepts our connection, but then refuses subscription (i.e. it's not fully ready).
Reactor build 23302
- Expressions: functions
asin()
,acos()
,atan()
, andatan2()
, and the reserved wordpi
(lowercase), are now supported (identical to their JavaScript equivalents). - Update the documentation for migrating (importing) rules from Reactor for Vera (the Vera Reactor Plugin).
- HassController: All use of
x_hass.call_service
(the entity-based service call action) now uses thetarget
field to specify theentity_id
, rather than the old form which embedded theentity_id
in thedata
field. - HassController: The
x_hass_system.call_service
(system-global service call action) has been extended to allow the user to enter atarget
field for service calls that benefit from it. It should be noted, however, that thex_hass.call_service
action on a Reactor entity (mapping a HA entity) should be used in preference to the system-global service call whenever possible, as changes in ID by HA will break the system-global call without warning (entity-based service call actions will simply use the new ID given by HA). - HassController: Bless Hass to 2023.10.5
Reactor Build 23338
DEPRECATION WARNING (bare-metal installs only): all nodejs versions earlier than 18 are now end-of-life; these versions will not be supported for Reactor after 1-Mar-2024. You should upgrade nodejs as soon as possible. The minimum supported version is now 18.18, but for longevity, upgrading to the current LTS version is recommended. Users of Reactor running in docker containers are not affected, as the image always embeds a supported LTS version of nodejs (that is, no action is required for docker users).
- Expressions: Update lexpjs to fix degenerate case of
case
with singlewhen
and anelse
(which is better written as anif...then...else
, but shouldn't throw an error in any case). - CallMeBot: the built-in CallMeBot notifier is now deprecated. There are no plans to remove it right now, but it will not receive future updates. Use HTTP Request actions directly in Reactions instead.
- Reduce the frequency of reminder alerts when an upgrade is available.
- HassController: Bless Hass to 2023.11.3
Reactor Build 23344
This is a "silent" release (you won't get upgrade notices) and available for docker containers only at this time.
- PR 0000294: InfluxFeed now supports exporting of global variable values to InfluxDB. See docs.
- VirtualEntityController: Fix issue where a global variable dependency (value change) was detected, but the old GV value was always retrieved.
- Dashboard: Strings displayed by ValueSensor widgets are now elastic-sized to reduce overflow.
- Dashboard: Fix group spec handling so that custom top-level dashboards for a group can be created. This needs documentation.
- HassController: Bless Hass to 2023.12.1
Reactor Build 24052
BARE-METAL USERS: It is recommended that you update package dependencies when installing all Reactor updates. After unpacking the Reactor archive, remove any existing
package-lock.json
file from your Reactor install directory, and then runnpm i --no-save --no-package-lock --omit dev
to update package dependencies.BREAKING CHANGE: The
valve
capability'sstate
attribute value is now boolean, to match similar system capabilities (was previously/erroneously string). If you are using an entity with thevalve
capability in conditions or actions, make sure the type for the current or target state is boolean now.- Update support for many packages. Please remember to do
(bare-metal installs only; docker containers are always up-to-date). - Add ability to override the state of a rule from the UI, for logic debugging purposes. A disabled rule will have its state forced, but will not run its reactions. An enabled rule will also have its state forced, but the corresponding rule reaction will run on the state transition. When overridden, the trigger and constraint conditions have no effect on the overall rule state, but (if rule enabled) are still evaluated and their status is still accurately displayed on the status card for the rule in the UI.
- PR 0000357: Implement
getRule()
extension function to get rule metadata; refer to the docs for more. - Fix an error in the handling of the entity action cache in the UI (occurred when running actions from the entity detail in the Entities list).
- Docs: improvements to description of custom event handlers for HassController (still a work in progress, but isn't everything?).
- Docs: add a section in VeraController doc for the firmware's
UnsafeLua
flag, required to be on for thex_vera_sys.runlua
action to be available. The value is now also published as an attribute on the system entity. - HassController: Implement new HA
valve
domain with ourvalve
capability. - HassController: Bless Hass to 2024.2.2
MQTTController Build 24050
NOTE: Either 24049 or 24050 of MQTTController is required for Reactor 24052.
- Rebuild entity when configuration change detected (supports
version
field in user templates). - PR 0000365: Fix broken config for
tasmota_generic_relay
template'stoggle.toggle
action. - New templates for genmon (generator monitoring; see https://github.com/jgyates/genmon)
- Support for new js-yaml
- Support
map
in event handling configuration.
Reminder for Bare-Metal Installs
Friday, March 1 2024 is the last day for Reactor support on nodejs versions earlier than 18. The next build of Reactor releasing after March 1 will not operate on any earlier version. If you haven't upgraded your system to nodejs version 18 or higher, please read the earlier advisory for details and upgrade ASAP.
For the removal of doubt, builds 24052 (most recent build) and prior will continue to run on and after March 1 on earlier nodejs versions; there is not enforced stop on this date. It is only future builds that will refuse to start on out-of-date nodejs versions.
Docker images are always up-to-date and therefore this notice does not apply to them (no action required for docker users).
Reactor build 24057
NOTE (BARE-METAL ONLY): If you are upgrading to this build from a build earlier than 24052, please update your package dependencies. After unpacking the Reactor archive, remove any existing
package-lock.json
to update package dependencies.- PR 0000366: Fix an injection caused by the rule state override option added in 24052, which results in constraints on rules being handled incorrectly.
MQTTController build 24085
- Support for Shelly H&T Gen3 (use
shelly_handt3
template and settopic
). This is a battery-powered WiFi device, so its attributes will not be fully populated until the first wake-up.
Reactor build 24115
- Entities UI: When a capability filter is selected, the value column header displays a selector allowing the user to display a value in the column other than the primary value for the filtered entities.
- The extensions subdirectory
ext
may now be located underconfig
, which makes its location uniform for bare-metal and docker users; this will eventually become the standard location. It is not necessary at this time to relocate your existingext
directory if you have one — either or both the old and new locations will work for the foreseeable future. - Improve the coordination of the Reactions and Rules displays when open and interacting on multiple displays (e.g. when you delete a reaction on one screen, it should disappear from the other(s)).
- Fix a browser-side performance issue/delay with reconnection to a restarting Reactor service when the Status page is up and displaying the Recently Changed Entities widget. This also improves the memory consumption and performance of the widget generally.
- Increase tolerance for damage to most storage objects, particularly those that only maintain state that can usually be safely rebuilt on the fly. For those that cannot, like rules and expressions, isolate a faulty file and ignore the object with an alert to the user. Preserve the broken file.
- PR 0000367 Localization of the new strings in the rule state override menu and state display have been added.
- PR 0000368 Fix missing localization string for Copy Attributes button in Entities list entity detail card.
- Report detected time zone and offset in startup messages. Add time zone display to hover title on browser and host times in UI header.
- New
wifi_status
system capability for WiFi-connected devices that can report connection status. - PR 0000369 Docs: Add documentation for
ev_charger
system capability. - HassController now supports responses from services that support them; whether required or optional, a response will be requested and stored in
x_hass.last_response
on the target Reactor entity. The data returned is not processed in any way; it is written as-received to the attribute. Tip: if possible, always make the service call from the target entity, not from the system entity. - HassController: Bless Hass to 2024.4.4
MQTTController 24114
NOTE: This version requires Reactor build 24115 or higher
- Add template for Shelly RGBW2 (using Gen1 API) called
shelly_rgbw2_color
(requirestopic
). - Add support for
wifi_status
capability for some devices; more to come. Previously, those devices stored WiFi status info inx_mqtt_device
(extended capability) attributes. Now that a first-class capability is being used, the extended attributes are deprecated and will be removed from a future release. - Templates may now remove an action from an entity if it isn't supported by the device. This is done by specifying the action's value as
false
. If a device cannot support any action of a capability, the entire default list of actions for the capability can be removed by specifying the capability value asfalse
in theactions
section of the template. For an example, see the templateshelly_rgbw2_color
implementation for capabilitylight_effect
actionset_speed
, and the action implementation for thebutton
capability. - Templates may now define custom actions in
x_mqtt_device
. Including anarguments
object in the standard action arguments format allows the template to notify the UI of the arguments required by the action. For an example, see the templateshelly_rgbw2_color
actionx_mqtt_device.set_white
MQTTController 24120
- Soft reconfiguration of entities on configuration changes and system upgrades. This should preserve attribute values when the entity needs to be configured due to implementation changes for capabilities.
