  4. Need Some Help Using browser_mod (HA integration)
26 Posts 2 Posters 11.3k Views 2 Watching
    Did you see my other note about actually verifying in HA that this works the way you expect? There actually is more debug info in the log, and specifically what I said I was looking for, so not sure what the disconnect is there, but anyway, MSR is sending what I expect. so I'd like you to use the "Developer Tools > Services" stuff in the Hass UI to see if you can make it work the way you want. There's no point chasing this in MSR if it's broken in Hass.
    PablaP 1 Reply Last reply
      @toggledbits Yes it does work in HA as expected.
        OK. Please post the YAML generated by the UI for that service call in developer tools.
        Also, there's no need to tag me in replies. Or in head posts. I get notified of all messages in this category.
          service: browser_mod.popup
          data:
            dismissable: true
            autoclose: false
            content:
              type: custom:mushroom-alarm-control-panel-card
              entity: alarm_control_panel.bar_partition
              states:
                - armed_home
                - armed_away
              layout: vertical
              show_keypad: true
            timeout: 120000
          target:
            device_id: 34ae76561192c4bb0b64fb07ad0f01c1
            data:
              dismissable: true
              autoclose: false
              content:
                states:
                  - armed_home
                  - armed_away
                layout: vertical
                show_keypad: true
              timeout: 120000
            target:
            OK. Download the latest hass_data.zip from here, and place the entire ZIP file in your config directory. Restart Reactor, and run your test again. Please post the log with context as before.
              wrote on last edited by Pabla
              Uploaded the ZIP file and uploaded into the config directory. Here are the logs, the popup still showed up on all Browser Mod devices.
              48.798Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:04:48.804Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
              [latest-23242]2023-10-18T06:04:48.811Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.80_64_6f_85_fe_37
              [latest-23242]2023-10-18T06:04:48.818Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_connected_devices
              [latest-23242]2023-10-18T06:04:48.833Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_path
              [latest-23242]2023-10-18T06:04:48.838Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_path
              [latest-23242]2023-10-18T06:04:48.844Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.ping_192_168_8_27
              [latest-23242]2023-10-18T06:04:48.850Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
              [latest-23242]2023-10-18T06:04:48.855Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
              [latest-23242]2023-10-18T06:04:48.860Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
              [latest-23242]2023-10-18T06:04:50.847Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:04:53.869Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:04:56.604Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
              [latest-23242]2023-10-18T06:05:00.095Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_free_memory
              [latest-23242]2023-10-18T06:05:00.543Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_internal_storage_free_space
              [latest-23242]2023-10-18T06:05:00.548Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_free_memory
              [latest-23242]2023-10-18T06:05:01.952Z <httpapi:INFO> httpapi: API request from ::ffff:192.168.8.237: GET /api/v1/systime
              [latest-23242]2023-10-18T06:05:02.853Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption
              [latest-23242]2023-10-18T06:05:02.864Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
              [latest-23242]2023-10-18T06:05:02.873Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
              [latest-23242]2023-10-18T06:05:02.882Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_usage
              [latest-23242]2023-10-18T06:05:02.894Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
              [latest-23242]2023-10-18T06:05:02.914Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
              [latest-23242]2023-10-18T06:05:03.280Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
              [latest-23242]2023-10-18T06:05:03.285Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
              [latest-23242]2023-10-18T06:05:03.290Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
              [latest-23242]2023-10-18T06:05:05.686Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_download_speed
              [latest-23242]2023-10-18T06:05:05.697Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_upload_speed
              [latest-23242]2023-10-18T06:05:05.706Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_download_speed
              [latest-23242]2023-10-18T06:05:05.715Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_upload_speed
              [latest-23242]2023-10-18T06:05:05.723Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_download_speed
              [latest-23242]2023-10-18T06:05:05.732Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_upload_speed
              [latest-23242]2023-10-18T06:05:06.740Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_ram
              [latest-23242]2023-10-18T06:05:06.750Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_cpu
              [latest-23242]2023-10-18T06:05:11.275Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.armans_macbook_pro
              [latest-23242]2023-10-18T06:05:11.862Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:05:15.436Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
              [latest-23242]2023-10-18T06:05:15.448Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.80_64_6f_85_fe_37
              [latest-23242]2023-10-18T06:05:17.864Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:05:18.306Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
              [latest-23242]2023-10-18T06:05:18.311Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
              [latest-23242]2023-10-18T06:05:18.315Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
              [latest-23242]2023-10-18T06:05:20.886Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:05:23.693Z <Engine:INFO> Enqueueing "Bar Tablet Alarm Arming Popup Copy<SET>" (rule-lnoyj3ub:S)
              [latest-23242]2023-10-18T06:05:23.699Z <Engine:NOTICE> Starting reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S)
              [latest-23242]2023-10-18T06:05:23.702Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
              [latest-23242]2023-10-18T06:05:23.707Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true }, "entity_id": "media_player.bar_tablet_2" }, "domain": "browser_mod", "service": "popup" }
              [latest-23242]2023-10-18T06:05:23.715Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
              [latest-23242]2023-10-18T06:05:23.718Z <Engine:INFO> Resuming reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S) from step 1
              [latest-23242]2023-10-18T06:05:23.719Z <Engine:INFO> Bar Tablet Alarm Arming Popup Copy<SET> all actions completed.
              [latest-23242]2023-10-18T06:05:23.846Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
              [latest-23242]2023-10-18T06:05:25.353Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_thermal_0_temperature
              [latest-23242]2023-10-18T06:05:25.359Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_used_percent
              [latest-23242]2023-10-18T06:05:25.363Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_used
              [latest-23242]2023-10-18T06:05:25.368Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_ram_free
              [latest-23242]2023-10-18T06:05:25.372Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_load
              [latest-23242]2023-10-18T06:05:25.378Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_total
              [latest-23242]2023-10-18T06:05:25.382Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_thread
              [latest-23242]2023-10-18T06:05:25.387Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_sleeping
              [latest-23242]2023-10-18T06:05:25.391Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.192_168_8_27_cpu_used
              [latest-23242]2023-10-18T06:05:26.163Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door1
              [latest-23242]2023-10-18T06:05:26.173Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_east
              [latest-23242]2023-10-18T06:05:26.182Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_garden
              [latest-23242]2023-10-18T06:05:26.191Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_landing
              [latest-23242]2023-10-18T06:05:26.199Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_east
              [latest-23242]2023-10-18T06:05:26.208Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_west
              [latest-23242]2023-10-18T06:05:26.216Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.backyard
              [latest-23242]2023-10-18T06:05:26.225Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.east_side_house
              [latest-23242]2023-10-18T06:05:26.233Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_stairs
              [latest-23242]2023-10-18T06:05:26.242Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.bar_landing
              [latest-23242]2023-10-18T06:05:26.251Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_door
              [latest-23242]2023-10-18T06:05:26.259Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.west_side_back
              [latest-23242]2023-10-18T06:05:26.264Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door_main
              [latest-23242]2023-10-18T06:05:26.553Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
              [latest-23242]2023-10-18T06:05:27.267Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.armans_macbook_pro
              [latest-23242]2023-10-18T06:05:29.853Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_free_memory
              [latest-23242]2023-10-18T06:05:30.300Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.armans_macbook_pro_browser_visibility
              [latest-23242]2023-10-18T06:05:30.305Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_internal_storage_free_space
              [latest-23242]2023-10-18T06:05:30.309Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_free_memory
              [latest-23242]2023-10-18T06:05:33.283Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
              [latest-23242]2023-10-18T06:05:33.293Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
              [latest-23242]2023-10-18T06:05:35.316Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.317Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.318Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously true)
              [latest-23242]2023-10-18T06:05:35.319Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; rule state transition from SET to RESET!
              [latest-23242]2023-10-18T06:05:35.345Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.345Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.346Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.346Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.395Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.396Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.408Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.408Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.414Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.415Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.415Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.416Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.471Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.472Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.473Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.474Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.477Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.477Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.478Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.478Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.483Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.483Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) starting evaluation; because entity-changed System#reactor_system>system
              [latest-23242]2023-10-18T06:05:35.485Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.485Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.487Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) trigger evaluation result is false (previously false)
              [latest-23242]2023-10-18T06:05:35.487Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
              [latest-23242]2023-10-18T06:05:35.488Z <Rule:INFO> Reactor Has Started (rule-l9w76sss in Notifications) evaluation complete
              [latest-23242]2023-10-18T06:05:35.488Z <Rule:INFO> Reactor Update Available (rule-l9irdhgr in Notifications) evaluation complete
                You placed the entire ZIP file, not unzipped, in the config directory?
                  That is correct. /home/arman/Documents/reactor/config/hass_data.zip
                    Can you confirm that after restart of Reactor, you find a log message containing the text ZIP data update found, and another shortly after ZIP update file device configuration version 23240.2 overrides package version xxx.yyy?
                      Here are the startup logs, looks like there is a error saying the ZIP file has no hass_capabilities.json. Also ignore the dynamic group errors its still a work in progress lol .
                      [latest-23242]2023-10-18T18:58:22.258Z <app:NOTICE> Closing Structure...
                      [latest-23242]2023-10-18T18:58:22.258Z <Structure:NOTICE> Structure#1 Stopping controllers...
                      [latest-23242]2023-10-18T18:58:22.259Z <Structure:INFO> Structure#1 stopping HassController#hass
                      [latest-23242]2023-10-18T18:58:22.259Z <HassController:NOTICE> HassController#hass stopping
                      [latest-23242]2023-10-18T18:58:22.263Z <wsapi:WARN> client close from unknown connection? "192.168.8.185#3"
                      [latest-23242]2023-10-18T18:58:22.271Z <HassController:NOTICE> HassController#hass websocket closing, 1000
                      [latest-23242]2023-10-18T18:58:22.272Z <Controller:NOTICE> HassController#hass stopping
                      [latest-23242]2023-10-18T18:58:22.285Z <Controller:ERR> Controller HassController#hass is off-line!
                      [latest-23242]2023-10-18T18:58:25.508Z <Structure:INFO> Structure#1 stopping ZWaveJSController#zwavejs
                      [latest-23242]2023-10-18T18:58:25.508Z <Controller:NOTICE> ZWaveJSController#zwavejs stopping
                      [latest-23242]2023-10-18T18:58:25.514Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group open_zones: [TypeError] Cannot read properties of undefined (reading 'binary_sensor_babay_papa_windows') [-]
                      [latest-23242]2023-10-18T18:58:25.515Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'binary_sensor_babay_papa_windows') [-]
                          at HassController.getNamedEntity (/home/arman/Documents/reactor/server/lib/Controller.js:380:35)
                          at Structure.findEntity (/home/arman/Documents/reactor/server/lib/Structure.js:460:151)
                          at DynamicGroupController._update_group (/home/arman/Documents/reactor/server/lib/DynamicGroupController.js:318:60)
                          at /home/arman/Documents/reactor/server/lib/DynamicGroupController.js:375:67
                          at DynamicGroupController._update (/home/arman/Documents/reactor/server/lib/DynamicGroupController.js:367:274)
                          at DynamicGroupController.notify (/home/arman/Documents/reactor/server/lib/DynamicGroupController.js:255:91)
                          at /home/arman/Documents/reactor/server/lib/MessageBus.js:106:223
                          at MessageBus._sendToBus (/home/arman/Documents/reactor/server/lib/MessageBus.js:103:47)
                      [latest-23242]2023-10-18T18:58:25.517Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group phones: [TypeError] Cannot read properties of undefined (reading 'sensor_bar_tablet_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.518Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_bar_tablet_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.519Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group low_battery_35: [TypeError] Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.520Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.521Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group low_battery_10: [TypeError] Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.522Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.524Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group dead_battery: [TypeError] Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.524Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'sensor_backyard_gate_battery_level') [-]
                      [latest-23242]2023-10-18T18:58:25.527Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group offline_devices: [TypeError] Cannot read properties of undefined (reading 'controller_all') [-]
                      [latest-23242]2023-10-18T18:58:25.527Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'controller_all') [-]
                      [latest-23242]2023-10-18T18:58:25.529Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group add_on_update_available: [TypeError] Cannot read properties of undefined (reading 'update_address_sign_light_firmware') [-]
                      [latest-23242]2023-10-18T18:58:25.529Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'update_address_sign_light_firmware') [-]
                      [latest-23242]2023-10-18T18:58:25.603Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group jammed_door_locks: [TypeError] Cannot read properties of undefined (reading 'binary_sensor_touchscreen_deadbolt_access_control_lock_jammed') [-]
                      [latest-23242]2023-10-18T18:58:25.603Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'binary_sensor_touchscreen_deadbolt_access_control_lock_jammed') [-]
                      [latest-23242]2023-10-18T18:58:25.622Z <Controller:ERR> Controller ZWaveJSController#zwavejs is off-line!
                      [latest-23242]2023-10-18T18:58:26.470Z <Structure:INFO> Structure#1 stopping DynamicGroupController#groups
                      [latest-23242]2023-10-18T18:58:26.471Z <DynamicGroupController:null> DynamicGroupController#groups stopping
                      [latest-23242]2023-10-18T18:58:26.481Z <Controller:NOTICE> DynamicGroupController#groups stopping
                      [latest-23242]2023-10-18T18:58:26.488Z <Controller:ERR> Controller DynamicGroupController#groups is off-line!
                      [latest-23242]2023-10-18T18:58:26.503Z <Structure:INFO> Structure#1 stopping SystemController#reactor_system
                      [latest-23242]2023-10-18T18:58:26.504Z <Controller:NOTICE> SystemController#reactor_system stopping
                      [latest-23242]2023-10-18T18:58:26.512Z <Controller:ERR> Controller SystemController#reactor_system is off-line!
                      [latest-23242]2023-10-18T18:58:26.520Z <Structure:INFO> Structure#1 Final data sync...
                      [latest-23242]2023-10-18T18:58:26.521Z <default:INFO> Closing container Container#rulesets
                      [latest-23242]2023-10-18T18:58:26.521Z <default:INFO> Closing container Container#reactions
                      [latest-23242]2023-10-18T18:58:26.521Z <default:INFO> Closing container Container#states
                      [latest-23242]2023-10-18T18:58:26.583Z <default:INFO> Closing container Container#default
                      [latest-23242]2023-10-18T18:58:27.013Z <default:INFO> Closing container Container#expressions
                      [latest-23242]2023-10-18T18:58:27.019Z <Structure:NOTICE> Structure Structure#1 stopped
                      [latest-23242]2023-10-18T18:58:27.019Z <app:NOTICE> Stopping timers...
                      [latest-23242]2023-10-18T18:58:27.025Z <app:null> Shutdown complete, process ID 19741
                      [latest-23242]2023-10-18T18:58:35.498Z <app:null> Reactor build latest-23242-5ee8e1d4 starting on v16.15.1
                      [latest-23242]2023-10-18T18:58:35.501Z <app:null> Process ID 20525 user/group 1000/1000; bare-metal; platform linux/arm #1642 SMP Mon Apr  3 17:20:52 BST 2023; locale en_CA.UTF-8
                      [latest-23242]2023-10-18T18:58:35.502Z <app:null> Basedir /home/arman/Documents/reactor; data in /home/arman/Documents/reactor/storage
                      [latest-23242]2023-10-18T18:58:35.503Z <app:null> NODE_PATH=/home/arman/Documents/reactor
                      [latest-23242]2023-10-18T18:58:35.514Z <app:INFO> Configured locale (undefined); selected locale(s) en_CA.UTF-8
                      [latest-23242]2023-10-18T18:58:35.712Z <app:INFO> Loaded locale en-US for en-CA
                      [latest-23242]2023-10-18T18:58:35.729Z <Structure:null> Module Structure v23172
                      [latest-23242]2023-10-18T18:58:35.740Z <Capabilities:null> Module Capabilities v22356
                      [latest-23242]2023-10-18T18:58:35.840Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 23914 revision 1
                      [latest-23242]2023-10-18T18:58:35.901Z <Plugin:null> Module Plugin v22300
                      [latest-23242]2023-10-18T18:58:35.926Z <TimerBroker:null> Module TimerBroker v22283
                      [latest-23242]2023-10-18T18:58:35.937Z <Entity:null> Module Entity v22353
                      [latest-23242]2023-10-18T18:58:35.950Z <Controller:null> Module Controller v23069
                      [latest-23242]2023-10-18T18:58:36.003Z <default:null> Module Ruleset v22293
                      [latest-23242]2023-10-18T18:58:36.005Z <default:null> Module Rulesets v22146
                      [latest-23242]2023-10-18T18:58:36.054Z <GlobalExpression:null> Module GlobalExpression v23211
                      [latest-23242]2023-10-18T18:58:36.112Z <Predicate:null> Module Predicate v23093
                      [latest-23242]2023-10-18T18:58:36.126Z <AlertManager:null> Module AlertManager v22283
                      [latest-23242]2023-10-18T18:58:36.137Z <Rule:null> Module Rule v23107
                      [latest-23242]2023-10-18T18:58:36.150Z <GlobalReaction:null> Module GlobalReaction v22324
                      [latest-23242]2023-10-18T18:58:36.156Z <Engine:null> Module Engine v23231
                      [latest-23242]2023-10-18T18:58:36.174Z <httpapi:null> Module httpapi v23058
                      [latest-23242]2023-10-18T18:58:36.229Z <wsapi:null> Module wsapi v23172
                      [latest-23242]2023-10-18T18:58:36.232Z <app:NOTICE> Starting Structure...
                      [latest-23242]2023-10-18T18:58:36.251Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
                      [latest-23242]2023-10-18T18:58:36.258Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
                      [latest-23242]2023-10-18T18:58:36.347Z <HassController:null> Module HassController v23240
                      [latest-23242]2023-10-18T18:58:36.380Z <Controller:WARN> HassController#hass failed (1) to restore entity binary_sensor_front_water_fountain_sensor_water_alarm_water_leak_detected: [Error] Incompatible serialization data; can't unserialize [-]
                      [latest-23242]2023-10-18T18:58:36.381Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
                          at Entity.unserialize (/home/arman/Documents/reactor/server/lib/Entity.js:624:19)
                          at /home/arman/Documents/reactor/server/lib/Controller.js:458:70
                          at HassController._restoreEntities (/home/arman/Documents/reactor/server/lib/Controller.js:446:36)
                          at new Controller (/home/arman/Documents/reactor/server/lib/Controller.js:37:45)
                          at new HassController (/home/arman/Documents/reactor/server/lib/HassController.js:36:9)
                          at /home/arman/Documents/reactor/server/lib/Controller.js:93:37
                      [latest-23242]2023-10-18T18:58:36.384Z <Controller:WARN> HassController#hass failed (1) to restore entity binary_sensor_z_wave_wireless_flood_freeze_sensor_sensor_state_water: [Error] Incompatible serialization data; can't unserialize [-]
                      [latest-23242]2023-10-18T18:58:36.385Z <Controller:CRIT> Error: Incompatible serialization data; can't unserialize [-]
                      [latest-23242]2023-10-18T18:58:38.603Z <Structure:INFO> Structure#1 loading controller interface zwavejs (ZWaveJSController)
                      [latest-23242]2023-10-18T18:58:38.648Z <ZWaveJSController:null> Module ZWaveJSController v23194
                      [latest-23242]2023-10-18T18:58:38.651Z <Controller:INFO> Loaded ZWaveJSController version "0.1.23194"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/ZWaveJSController/
                      [latest-23242]2023-10-18T18:58:38.970Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log
                      [latest-23242]2023-10-18T18:58:38.971Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                      [latest-23242]2023-10-18T18:58:38.993Z <DynamicGroupController:null> Module DynamicGroupController v22313
                      [latest-23242]2023-10-18T18:58:39.021Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                      [latest-23242]2023-10-18T18:58:39.035Z <SystemController:null> Module SystemController v23214
                      [latest-23242]2023-10-18T18:58:39.048Z <Structure:INFO> Starting controller HassController#hass
                      [latest-23242]2023-10-18T18:58:39.049Z <HassController:NOTICE> HassController#hass starting...
                      [latest-23242]2023-10-18T18:58:39.063Z <Controller:INFO> HassController#hass ZIP data update found (/home/arman/Documents/reactor/config/hass_data.zip)
                      [latest-23242]2023-10-18T18:58:39.066Z <Structure:INFO> Starting controller ZWaveJSController#zwavejs
                      [latest-23242]2023-10-18T18:58:39.069Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming
                      [latest-23242]2023-10-18T18:58:39.070Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming
                      [latest-23242]2023-10-18T18:58:39.070Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming
                      [latest-23242]2023-10-18T18:58:39.070Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming
                      [latest-23242]2023-10-18T18:58:39.071Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1
                      [latest-23242]2023-10-18T18:58:39.123Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23194 rev 1 format 1
                      [latest-23242]2023-10-18T18:58:39.123Z <Structure:INFO> Starting controller DynamicGroupController#groups
                      [latest-23242]2023-10-18T18:58:39.138Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                      [latest-23242]2023-10-18T18:58:39.139Z <Structure:INFO> Starting controller SystemController#reactor_system
                      [latest-23242]2023-10-18T18:58:39.146Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                      [latest-23242]2023-10-18T18:58:39.344Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.8.85:3000
                      [latest-23242]2023-10-18T18:58:39.413Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "12.2.0", "serverVersion": "1.32.1", "homeId": 3775115912, "minSchemaVersion": 0, "maxSchemaVersion": 32 }
                      [latest-23242]2023-10-18T18:58:39.416Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected
                      [latest-23242]2023-10-18T18:58:39.417Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization
                      [latest-23242]2023-10-18T18:58:39.431Z <Controller:WARN> /home/arman/Documents/reactor/config/hass_data.zip: no hass_capabilities.json: hass
                      [latest-23242]2023-10-18T18:58:39.432Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23109 rev 1 format 1
                      [latest-23242]2023-10-18T18:58:39.468Z <Controller:WARN> /home/arman/Documents/reactor/config/hass_data.zip: no hass_devices.json: [Error] Entry not found [-]
                      [latest-23242]2023-10-18T18:58:39.468Z <Controller:INFO> HassController#hass loaded implementation data ver 23240 rev 1 format 1
                      [latest-23242]2023-10-18T18:58:39.473Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
                      [latest-23242]2023-10-18T18:58:39.475Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability power_switch
                      [latest-23242]2023-10-18T18:58:39.477Z <HassController:5:HassController.js:258> HassController#hass capability power_switch attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.477Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability toggle
                      [latest-23242]2023-10-18T18:58:39.479Z <HassController:5:HassController.js:258> HassController#hass capability toggle attributes [Array][  ]
                      [latest-23242]2023-10-18T18:58:39.480Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability dimming
                      [latest-23242]2023-10-18T18:58:39.480Z <HassController:5:HassController.js:258> HassController#hass capability dimming attributes [Array][ "level", "step" ]
                      [latest-23242]2023-10-18T18:58:39.481Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability rgb_color
                      [latest-23242]2023-10-18T18:58:39.481Z <HassController:5:HassController.js:258> HassController#hass capability rgb_color attributes [Array][ "red", "green", "blue" ]
                      [latest-23242]2023-10-18T18:58:39.482Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability hs_color
                      [latest-23242]2023-10-18T18:58:39.482Z <HassController:5:HassController.js:258> HassController#hass capability hs_color attributes [Array][ "hue", "saturation" ]
                      [latest-23242]2023-10-18T18:58:39.483Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability xy_color
                      [latest-23242]2023-10-18T18:58:39.484Z <HassController:5:HassController.js:258> HassController#hass capability xy_color attributes [Array][ "x", "y" ]
                      [latest-23242]2023-10-18T18:58:39.484Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability color_temperature
                      [latest-23242]2023-10-18T18:58:39.485Z <HassController:5:HassController.js:258> HassController#hass capability color_temperature attributes [Array][ "value" ]
                      [latest-23242]2023-10-18T18:58:39.486Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability light_effect
                      [latest-23242]2023-10-18T18:58:39.486Z <HassController:5:HassController.js:258> HassController#hass capability light_effect attributes [Array][ "current" ]
                      [latest-23242]2023-10-18T18:58:39.487Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability binary_sensor
                      [latest-23242]2023-10-18T18:58:39.487Z <HassController:5:HassController.js:258> HassController#hass capability binary_sensor attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.488Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability person.binary_sensor
                      [latest-23242]2023-10-18T18:58:39.488Z <HassController:5:HassController.js:258> HassController#hass capability person.binary_sensor attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.489Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability motion_sensor
                      [latest-23242]2023-10-18T18:58:39.490Z <HassController:5:HassController.js:258> HassController#hass capability motion_sensor attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.490Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability tamper
                      [latest-23242]2023-10-18T18:58:39.491Z <HassController:5:HassController.js:258> HassController#hass capability tamper attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.491Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability co_detector
                      [latest-23242]2023-10-18T18:58:39.492Z <HassController:5:HassController.js:258> HassController#hass capability co_detector attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.492Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability door_sensor
                      [latest-23242]2023-10-18T18:58:39.493Z <HassController:5:HassController.js:258> HassController#hass capability door_sensor attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.493Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability freeze_detector
                      [latest-23242]2023-10-18T18:58:39.494Z <HassController:5:HassController.js:258> HassController#hass capability freeze_detector attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.494Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability gas_detector
                      [latest-23242]2023-10-18T18:58:39.495Z <HassController:5:HassController.js:258> HassController#hass capability gas_detector attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.495Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability heat_detector
                      [latest-23242]2023-10-18T18:58:39.496Z <HassController:5:HassController.js:258> HassController#hass capability heat_detector attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.496Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability presence_sensor
                      [latest-23242]2023-10-18T18:58:39.497Z <HassController:5:HassController.js:258> HassController#hass capability presence_sensor attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.497Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability smoke_detector
                      [latest-23242]2023-10-18T18:58:39.498Z <HassController:5:HassController.js:258> HassController#hass capability smoke_detector attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.498Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability window_sensor
                      [latest-23242]2023-10-18T18:58:39.499Z <HassController:5:HassController.js:258> HassController#hass capability window_sensor attributes [Array][ "state" ]
                      [latest-23242]2023-10-18T18:58:39.499Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability battery_maintenance
                      [latest-23242]2023-10-18T18:58:39.500Z <HassController:5:HassController.js:258> HassController#hass capability battery_maintenance attributes [Array][ "rechargeable", "replace", "charging" ]
                      [latest-23242]2023-10-18T18:58:39.500Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability value_sensor
                      [latest-23242]2023-10-18T18:58:39.501Z <HassController:5:HassController.js:258> HassController#hass capability value_sensor attributes [Array][ "value", "units" ]
                      [latest-23242]2023-10-18T18:58:39.501Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability temperature_sensor
                      [latest-23242]2023-10-18T18:58:39.502Z <HassController:5:HassController.js:258> HassController#hass capability temperature_sensor attributes [Array][ "value", "units" ]
                      [latest-23242]2023-10-18T18:58:39.502Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability humidity_sensor
                      [latest-23242]2023-10-18T18:58:39.503Z <HassController:5:HassController.js:258> HassController#hass capability humidity_sensor attributes [Array][ "value", "units" ]
                      [latest-23242]2023-10-18T18:58:39.503Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability pressure_sensor
                      [latest-23242]2023-10-18T18:58:39.504Z <HassController:5:HassController.js:258> HassController#hass capability pressure_sensor attributes [Array][ "value", "units" ]
                      [latest-23242]2023-10-18T18:58:39.504Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability voltage_sensor
                        OK. Sorry. Try a fresh download of the ZIP file and install the updated version. Same routine... install (to config), restart Reactor, run test, post logs.
                          So it looks like the ZIP file worked this time
                          [latest-23242]2023-10-18T23:13:13.781Z <Structure:INFO> Structure#1 loading controller interface zwavejs (ZWaveJSController)
                          [latest-23242]2023-10-18T23:13:13.825Z <ZWaveJSController:null> Module ZWaveJSController v23194
                          [latest-23242]2023-10-18T23:13:13.827Z <Controller:INFO> Loaded ZWaveJSController version "0.1.23194"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/ZWaveJSController/
                          [latest-23242]2023-10-18T23:13:14.159Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log
                          [latest-23242]2023-10-18T23:13:14.160Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                          [latest-23242]2023-10-18T23:13:14.182Z <DynamicGroupController:null> Module DynamicGroupController v22313
                          [latest-23242]2023-10-18T23:13:14.214Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                          [latest-23242]2023-10-18T23:13:14.228Z <SystemController:null> Module SystemController v23214
                          [latest-23242]2023-10-18T23:13:14.242Z <Structure:INFO> Starting controller HassController#hass
                          [latest-23242]2023-10-18T23:13:14.243Z <HassController:NOTICE> HassController#hass starting...
                          [latest-23242]2023-10-18T23:13:14.256Z <Controller:INFO> HassController#hass ZIP data update found (/home/arman/Documents/reactor/config/hass_data.zip)
                          [latest-23242]2023-10-18T23:13:14.259Z <Structure:INFO> Starting controller ZWaveJSController#zwavejs
                          [latest-23242]2023-10-18T23:13:14.262Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming
                          [latest-23242]2023-10-18T23:13:14.263Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming
                          [latest-23242]2023-10-18T23:13:14.263Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming
                          [latest-23242]2023-10-18T23:13:14.264Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming
                          [latest-23242]2023-10-18T23:13:14.264Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1
                          [latest-23242]2023-10-18T23:13:14.317Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23194 rev 1 format 1
                          [latest-23242]2023-10-18T23:13:14.317Z <Structure:INFO> Starting controller DynamicGroupController#groups
                          [latest-23242]2023-10-18T23:13:14.336Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                          [latest-23242]2023-10-18T23:13:14.336Z <Structure:INFO> Starting controller SystemController#reactor_system
                          [latest-23242]2023-10-18T23:13:14.347Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                          [latest-23242]2023-10-18T23:13:14.553Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.8.85:3000
                          [latest-23242]2023-10-18T23:13:14.626Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "12.2.0", "serverVersion": "1.32.1", "homeId": 3775115912, "minSchemaVersion": 0, "maxSchemaVersion": 32 }
                          [latest-23242]2023-10-18T23:13:14.629Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected
                          [latest-23242]2023-10-18T23:13:14.630Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization
                          [latest-23242]2023-10-18T23:13:14.644Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory
                          [latest-23242]2023-10-18T23:13:14.666Z <Controller:INFO> HassController#hass ZIP update file capabilities ignored; ZIP version 23109.1 <= package version 23109.1
                          [latest-23242]2023-10-18T23:13:14.668Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23109 rev 1 format 1
                          [latest-23242]2023-10-18T23:13:14.758Z <Controller:INFO> HassController#hass ZIP update file device configuration version 23240.2 overrides package version 23240.1
                          [latest-23242]2023-10-18T23:13:14.759Z <Controller:INFO> HassController#hass loaded implementation data ver 23240 rev 2 format 1
                          [latest-23242]2023-10-18T23:13:14.763Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
                          [latest-23242]2023-10-18T23:13:14.765Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability power_switch
                          [latest-23242]2023-10-18T23:13:14.766Z <HassController:5:HassController.js:258> HassController#hass capability power_switch attributes [Array][ "state" ]
                          [latest-23242]2023-10-18T23:13:14.767Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability toggle
                          [latest-23242]2023-10-18T23:13:14.768Z <HassController:5:HassController.js:258> HassController#hass capability toggle attributes [Array][  ]
                          [latest-23242]2023-10-18T23:13:14.768Z <HassController:5:HassController.js:247> HassController#hass checking implementation for capability dimming
                          However testing the rule the popup still showed on all browser mod devices. I know you had mentioned using x_hass.call_service on the device entity, but my question is how would MSR know what the browser_id would be for said entity? The browser_id is unique to this integration so I would think that MSR/HA would not have this info stored in the entity. Just a thought though. Is there any way we can get the call_service command for the HA system entity to work since it just seems like the target info isn't being passed through correctly?
                          [latest-23242]2023-10-18T23:15:24.707Z <Rule:INFO> Fountain (rule-grpsdlp33d in Backyard Reactor) evaluated; trigger state unchanged (true); rule state remains SET
                          [latest-23242]2023-10-18T23:15:24.710Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) starting evaluation; because data-changed Data#states:cs-rule-grpsdlp33d
                          [latest-23242]2023-10-18T23:15:24.710Z <Rule:INFO> Fountain (rule-grpsdlp33d in Backyard Reactor) evaluation complete
                          [latest-23242]2023-10-18T23:15:24.711Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) trigger evaluation result is true (previously true)
                          [latest-23242]2023-10-18T23:15:24.711Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) evaluated; trigger state unchanged (true); rule state remains SET
                          [latest-23242]2023-10-18T23:15:24.712Z <Rule:INFO> Backyard Fountain (rule-grptitus9c in Backyard Reactor) evaluation complete
                          [latest-23242]2023-10-18T23:15:26.304Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door1
                          [latest-23242]2023-10-18T23:15:26.315Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_east
                          [latest-23242]2023-10-18T23:15:26.324Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_garden
                          [latest-23242]2023-10-18T23:15:26.333Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.back_landing
                          [latest-23242]2023-10-18T23:15:26.342Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_east
                          [latest-23242]2023-10-18T23:15:26.349Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_entrance_west
                          [latest-23242]2023-10-18T23:15:26.355Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.backyard
                          [latest-23242]2023-10-18T23:15:26.362Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.east_side_house
                          [latest-23242]2023-10-18T23:15:26.369Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_stairs
                          [latest-23242]2023-10-18T23:15:26.375Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.bar_landing
                          [latest-23242]2023-10-18T23:15:26.382Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.deck_door
                          [latest-23242]2023-10-18T23:15:26.389Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.west_side_back
                          [latest-23242]2023-10-18T23:15:26.395Z <HassController:5:HassController.js:352> HassController#hass updating hass entity camera.front_door_main
                          [latest-23242]2023-10-18T23:15:27.253Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                          [latest-23242]2023-10-18T23:15:29.264Z <Engine:INFO> Enqueueing "Bar Tablet Alarm Arming Popup Copy<SET>" (rule-lnoyj3ub:S)
                          [latest-23242]2023-10-18T23:15:29.271Z <Engine:NOTICE> Starting reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S)
                          [latest-23242]2023-10-18T23:15:29.281Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                          [latest-23242]2023-10-18T23:15:29.287Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true } }, "domain": "browser_mod", "service": "popup", "target": { "entity_id": "media_player.bar_tablet_2" } }
                          [latest-23242]2023-10-18T23:15:29.298Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                          [latest-23242]2023-10-18T23:15:29.303Z <Engine:INFO> Resuming reaction Bar Tablet Alarm Arming Popup Copy<SET> (rule-lnoyj3ub:S) from step 1
                          [latest-23242]2023-10-18T23:15:29.304Z <Engine:INFO> Bar Tablet Alarm Arming Popup Copy<SET> all actions completed.
                          [latest-23242]2023-10-18T23:15:30.576Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.pabla_windows
                          [latest-23242]2023-10-18T23:15:33.070Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                          [latest-23242]2023-10-18T23:15:33.119Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                          [latest-23242]2023-10-18T23:15:33.243Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                          [latest-23242]2023-10-18T23:15:34.425Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                          [latest-23242]2023-10-18T23:15:34.443Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                          [latest-23242]2023-10-18T23:15:35.627Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_download_speed
                          [latest-23242]2023-10-18T23:15:35.640Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_upload_speed
                          [latest-23242]2023-10-18T23:15:35.650Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_download_speed
                          [latest-23242]2023-10-18T23:15:35.660Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wired_upload_speed
                          [latest-23242]2023-10-18T23:15:35.670Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_download_speed
                          [latest-23242]2023-10-18T23:15:35.679Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_bridge_upload_speed
                          [latest-23242]2023-10-18T23:15:35.700Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                          [latest-23242]2023-10-18T23:15:36.247Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                          [latest-23242]2023-10-18T23:15:36.678Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_ram
                          [latest-23242]2023-10-18T23:15:36.684Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_cpu
                          [latest-23242]2023-10-18T23:15:37.062Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.pabla_windows_browser_path
                          [latest-23242]2023-10-18T23:15:38.841Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                          [latest-23242]2023-10-18T23:15:38.851Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                            #21
                            First, I can see that target is being passed correctly.
                            According to their documentation, the browser_id is something you have to add to the service data. It even says this in their documentation:
                            If no target or browser_id is specified, the service will target all registerd [sic] Browsers.
                            That's not something Reactor would or could know to add automatically, it's an integration-specific implementation detail; it's not part of target (which is HA-defined structure and only supports HA's native entity_id, device_id and area_id).
                            I didn't notice before, but you don't seem to be passing browser_id. That might help. It looks like you can set the browser ID on each client, which seems like a good idea (make them human-readable/friendly).
                              Yes this is what my original YAML was trying to do.
                              dismissable: true
                              autoclose: false
                              timeout: 120000
                              content:
                                states:
                                  - armed_home
                                  - armed_away
                                layout: vertical
                                show_keypad: true
                              target:
                              But the target: device_id: 34ae76561192c4bb0b64fb07ad0f01c1 is not being passed through correctly and the popup shows up on all devices. I also have set the browser_id for each device but thats only UI facing the number is what the HA service uses. See HA service call:
                              data:
                                dismissable: true
                                autoclose: false
                                content:
                                  states:
                                    - armed_home
                                    - armed_away
                                  layout: vertical
                                  show_keypad: true
                                timeout_action: 120000
                              target:
                              Here is the Reactor log for when I call a service using the first YAML code.
                              [latest-23242]2023-10-19T17:23:48.911Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
                              [latest-23242]2023-10-19T17:23:49.589Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.pabla_windows
                              [latest-23242]2023-10-19T17:23:50.546Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:23:53.537Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:23:56.365Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) configuration changed; reloading
                              [latest-23242]2023-10-19T17:23:56.370Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) stopping
                              [latest-23242]2023-10-19T17:23:56.385Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) stopped
                              [latest-23242]2023-10-19T17:23:56.386Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) starting
                              [latest-23242]2023-10-19T17:23:56.387Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) can't start -- rule is disabled
                              [latest-23242]2023-10-19T17:23:56.536Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:23:57.425Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                              [latest-23242]2023-10-19T17:23:57.427Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true } }, "domain": "browser_mod", "service": "popup", "target": { "entity_id": "media_player.bar_tablet_2" } }
                              [latest-23242]2023-10-19T17:23:57.432Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "data:\n  dismissable: true\n  autoclose: false\n  timeout: 120000\n  content:\n    type: custom:mushroom-alarm-control-panel-card\n    entity: alarm_control_panel.bar_partition\n    states:\n      - armed_home\n      - armed_away\n    layout: vertical\n    show_keypad: true\ntarget:\n  device_id: 34ae76561192c4bb0b64fb07ad0f01c1" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                              [latest-23242]2023-10-19T17:23:58.667Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                              [latest-23242]2023-10-19T17:23:59.545Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:24:02.560Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption
                              [latest-23242]2023-10-19T17:24:02.570Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                              [latest-23242]2023-10-19T17:24:02.579Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                              [latest-23242]2023-10-19T17:24:02.587Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_usage
                              [latest-23242]2023-10-19T17:24:02.597Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:24:02.617Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                              [latest-23242]2023-10-19T17:24:02.626Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                              [latest-23242]2023-10-19T17:24:04.337Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_internal_storage_free_space
                              [latest-23242]2023-10-19T17:24:04.347Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.main_floor_tablet_free_memory
                              [latest-23242]2023-10-19T17:24:05.211Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_internal_storage_free_space
                              [latest-23242]2023-10-19T17:24:05.216Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bar_tablet_free_memory
                              [latest-23242]2023-10-19T17:24:05.619Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:24:08.555Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                              [latest-23242]2023-10-19T17:24:10.096Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_download_speed
                              [latest-23242]2023-10-19T17:24:10.106Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_wan_upload_speed
                                You need to send browser_id in data
                                  Tried browser_id no popup on any devices, used device_id and popup came up on all devices again. Logs for both attempts below
                                  [latest-23242]2023-10-19T21:30:44.024Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:44.544Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                                  [latest-23242]2023-10-19T21:30:44.549Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                                  [latest-23242]2023-10-19T21:30:44.553Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                                  [latest-23242]2023-10-19T21:30:47.353Z <HassController:5:HassController.js:352> HassController#hass updating hass entity climate.shed_climate
                                  [latest-23242]2023-10-19T21:30:48.374Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                  [latest-23242]2023-10-19T21:30:48.387Z <HassController:5:HassController.js:352> HassController#hass updating hass entity climate.shed_climate
                                  [latest-23242]2023-10-19T21:30:49.377Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.ec_71_db_69_bf_c4
                                  [latest-23242]2023-10-19T21:30:49.386Z <HassController:5:HassController.js:352> HassController#hass updating hass entity device_tracker.80_64_6f_85_fe_37
                                  [latest-23242]2023-10-19T21:30:49.396Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.asus_router_connected_devices
                                  [latest-23242]2023-10-19T21:30:49.499Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                                  [latest-23242]2023-10-19T21:30:49.502Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true }, "browser_id": "05c0cb75141aeb8d38a86999e07e6a7d" }, "domain": "browser_mod", "service": "popup", "target": { "entity_id": "media_player.bar_tablet_2" } }
                                  [latest-23242]2023-10-19T21:30:49.508Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true\nbrowser_id: 05c0cb75141aeb8d38a86999e07e6a7d" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                                  [latest-23242]2023-10-19T21:30:51.381Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                  [latest-23242]2023-10-19T21:30:54.387Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                  [latest-23242]2023-10-19T21:30:54.943Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.main_floor_motion
                                  [latest-23242]2023-10-19T21:30:55.321Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:55.326Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:55.326Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:55.326Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:55.328Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:55.328Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:55.331Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:55.332Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:55.335Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:55.336Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:55.337Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:55.338Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:55.338Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) starting evaluation; because data-changed Data#states:cs-rule-grpri779hy
                                  [latest-23242]2023-10-19T21:30:55.338Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:55.377Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:55.377Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:55.378Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:56.801Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.main_floor_motion
                                  [latest-23242]2023-10-19T21:30:56.963Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:56.973Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:56.973Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:56.974Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:30:56.977Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:56.978Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:56.983Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:56.983Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:56.992Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:56.993Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:56.996Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:56.997Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:56.997Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) starting evaluation; because data-changed Data#states:cs-rule-grpri779hy
                                  [latest-23242]2023-10-19T21:30:56.998Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:57.057Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:57.057Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:57.058Z <Rule:INFO> Zone Opened (rule-ljwaswws in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:30:57.361Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_instantaneous_demand
                                  [latest-23242]2023-10-19T21:30:58.892Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) configuration changed; reloading
                                  [latest-23242]2023-10-19T21:30:58.896Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) stopping
                                  [latest-23242]2023-10-19T21:30:58.912Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) stopped
                                  [latest-23242]2023-10-19T21:30:58.912Z <Rule:NOTICE> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) starting
                                  [latest-23242]2023-10-19T21:30:58.913Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) starting evaluation; because startup
                                  [latest-23242]2023-10-19T21:30:58.916Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:30:58.917Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:30:58.918Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) evaluation complete
                                  [latest-23242]2023-10-19T21:30:58.918Z <Rule:INFO> Bar Tablet Alarm Arming Popup Copy (rule-lnoyj3ub in Home Reactor ) started
                                  [latest-23242]2023-10-19T21:30:59.546Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.processor_use
                                  [latest-23242]2023-10-19T21:30:59.556Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_free
                                  [latest-23242]2023-10-19T21:30:59.564Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.memory_use_percent
                                  [latest-23242]2023-10-19T21:31:00.052Z <HassController:5:HassController.js:100> HassController#hass MediaPlayer#hass>media_player_bar_tablet_2 performOnEntity x_hass.call_service no domain-specific cap, trying generic
                                  [latest-23242]2023-10-19T21:31:00.055Z <HassController:5:HassController.js:222> HassController#hass: sending payload for x_hass.call_service on MediaPlayer#hass>media_player_bar_tablet_2 action: [Object]{ "type": "call_service", "service_data": { "dismissable": true, "autoclose": false, "timeout": 120000, "content": { "type": "custom:mushroom-alarm-control-panel-card", "entity": "alarm_control_panel.bar_partition", "states": [ "armed_home", "armed_away" ], "layout": "vertical", "show_keypad": true }, "device_id": "05c0cb75141aeb8d38a86999e07e6a7d" }, "domain": "browser_mod", "service": "popup", "target": { "entity_id": "media_player.bar_tablet_2" } }
                                  [latest-23242]2023-10-19T21:31:00.064Z <HassController:INFO> HassController#hass action x_hass.call_service([Object]{ "service": "browser_mod.popup", "data": "dismissable: true\nautoclose: false\ntimeout: 120000\ncontent:\n  type: custom:mushroom-alarm-control-panel-card\n  entity: alarm_control_panel.bar_partition\n  states:\n    - armed_home\n    - armed_away\n  layout: vertical\n  show_keypad: true\ndevice_id: 05c0cb75141aeb8d38a86999e07e6a7d" }) on MediaPlayer#hass>media_player_bar_tablet_2 succeeded
                                  [latest-23242]2023-10-19T21:31:00.382Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption
                                  [latest-23242]2023-10-19T21:31:00.392Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                                  [latest-23242]2023-10-19T21:31:00.396Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.bchydro_electricity_consumption_cost
                                  [latest-23242]2023-10-19T21:31:00.401Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_usage
                                  [latest-23242]2023-10-19T21:31:00.406Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                                  [latest-23242]2023-10-19T21:31:00.410Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.2_month_hydro_cost
                                  [latest-23242]2023-10-19T21:31:02.049Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.pabla_windows
                                  [latest-23242]2023-10-19T21:31:02.255Z <HassController:5:HassController.js:352> HassController#hass updating hass entity binary_sensor.main_floor_motion
                                  [latest-23242]2023-10-19T21:31:02.614Z <HassController:5:HassController.js:352> HassController#hass updating hass entity sensor.home_partition_keypad
                                  [latest-23242]2023-10-19T21:31:02.620Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:31:02.620Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:31:02.620Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) starting evaluation; because entity-changed ValueSensor#hass>sensor_home_partition_keypad
                                  [latest-23242]2023-10-19T21:31:02.622Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:31:02.623Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:31:02.625Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:31:02.626Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:31:02.629Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) trigger evaluation result is false (previously false)
                                  [latest-23242]2023-10-19T21:31:02.630Z <Rule:INFO> Night or Away or Vacation or Armed (rule-grpri779hy in Notifications) evaluated; trigger state unchanged (false); rule state remains RESET
                                  [latest-23242]2023-10-19T21:31:02.632Z <Rule:INFO> Alexa No Zones Open (rule-grpozng7j0 in Notifications) evaluation complete
                                  [latest-23242]2023-10-19T21:31:02.632Z <Rule:INFO> Alexa Which Zones Open (rule-grpozjdlfa in Notifications) evaluation complete
                                    #25
                                    OK, you can't put device_id in data; it goes in target. And you can't do that, because you can't modify target, Reactor controls it. And Reactor has no way to get the device ID for a HA entity (it's not exposed in their documented APIs), so it's not possible for me to make a service call with anything other than the HA entity_id. That's neither here nor there, because (a) the docs for browser_mod are very specific that browser_id is to be used, and (b) both the service data from the API and my testing confirm that entity_id is supported and works fine to reach the browser_mod integration.
                                    In your attempt that used browser_id, you have used the HA device_id, and that's wrong. The browser ID comes from browser_mod's configuration (left margin panel), visible in the same place you would/could set/change it). The browser_id is much shorter than a HA device_id by default. Again, suggest you study the integration's docs carefully.
                                    In addition, I've now installed this integration myself, and in my own testing:
                                    1. entity_id as a target works fine every time, and
                                    2. if you don't include browser_id in the data, the pop-up comes up on all browsers, which is word for word what they say in their documentation (as I quoted in my previous message above). And this is true whether I use the HA Developer Tools interface or x_hass.call_service in Reactor.
                                    So you need to use browser_id in the data, and use the correct string for that ID.
                                      That looks like it did the trick! Was getting a bit confused between browser_id and device_id but your explanation cleared things up. Thanks again Patrick!
                                        160.6k
