  4. Variable Value select array part
6 Posts 2 Posters 1.4k Views 2 Watching
  • wmarcolinW Offline
    Hi @toggledbits
    Is there any way that in the trigger the Varable Value could select the desired part of the array?
    For example, I could have a global variable VarTEST$[Part1, Part2, Part3] like this: ${{ [TestText, 5, 3] }}. Use the Variable Value to validate a VarTEST[Part2] == 5 trigger.
    What am I doing today? I've defined 3 global variables:
    And I validate each variable.
    In short, I would like to have a global variable of the array type, and be able to select which element of the array I would use for validation in a trigger.
      Make a local variable in the rule to extract the value you are interested in, and use the local variable in the condition.
        Thanks master 🙂
        One more help if possible, instead of doing this absurd of code, how could I make a loop, with the count from 6 to 0, that is, regressing?
        format( "Dia {0} {1} {2:4.1f}mm ",
          substr(HistPrecipitation.daily.time[6],8,2),
          if HistPrecipitation.daily.precipitation_sum[6] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[6]) +
          substr(HistPrecipitation.daily.time[5],8,2),
          if HistPrecipitation.daily.precipitation_sum[5] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[5]) +
          substr(HistPrecipitation.daily.time[4],8,2),
          if HistPrecipitation.daily.precipitation_sum[4] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[4]) +
          substr(HistPrecipitation.daily.time[3],8,2),
          if HistPrecipitation.daily.precipitation_sum[3] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[3]) +
          substr(HistPrecipitation.daily.time[2],8,2),
          if HistPrecipitation.daily.precipitation_sum[2] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[2]) +
          substr(HistPrecipitation.daily.time[1],8,2),
          if HistPrecipitation.daily.precipitation_sum[1] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[1]) +
          substr(HistPrecipitation.daily.time[0],8,2),
          if HistPrecipitation.daily.precipitation_sum[0] <= 2 then "💦" else "🌧️" endif,
          HistPrecipitation.daily.precipitation_sum[0])
        Reading the manual, I understood that it could be something with each, but I couldn't create the expression.
        Please, your help.
          wow. Nobody from the community chiming in on this part? What happened to all my expression experts? Sigh...
          Hints:
          • each
          • range operator
            Super!! The comment "range operator" opened a window for me 🙂 I didn't know about this facility.
            join((each i in 6..0 :
                      substr(HistPrecipitation.daily.time[i],8,2),
                      if HistPrecipitation.daily.precipitation_sum[i] <= 2
                      HistPrecipitation.daily.precipitation_sum[i])), " ")
            THANK YOU A LOT!!!
              Awesome! Well done!
                135.9k
