  4. Rule's sustain / delay reset etc. value parameterization thru entities
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 3 Posters 1.2k Views 3 Watching
    Some background
    I have two simple rules that will toggle my carport's down lights depending on outdoor brightness when I open the motorized sliding gate. I.e. if the brightness is 1500 lux or less and the gate is opened, the down lights will be switched on, and when the gate is closed, the lights will switch off after 3 minutes. Pretty simple 'coming home' functionality so to speak.
    Here's the switch off rule showing the 'hard coded' thresholds
    The problem
    I would like to parameterize the lux and switch off delay using entities. I bet the lux threshold can be done with local expressions the same way I do my WC background music scheduling:
    weekdays_enabled = (time() >= time(getEntity( "mqtt>wc-music-weekdays-enable" ).attributes.string_sensor.value )) && (time() <= time(getEntity( "mqtt>wc-music-weekdays-disable" ).attributes.string_sensor.value ))
    But the since I'm using the Condition must be sustained for functionality for the switch off rule, I have no idea how to parameterize that with some entity value.
    So my question is that is it even possible to do this using entities or could there some other way to accomplish the same functionality? In this example it's the sustain -value but I might need same kind of parameterization for the delay reset also.
    I have to go with entities, since my own HA system will provide the threshold values for the MSR through the MQTTController.
    Help would be appreciated @toggledbits
    br,
    MSR latest-23302-b7def56a and MQTTController [0.1.23254]
    • M mgvra
      Some background
      The problem
      br,
      @mgvra said in Rule's sustain / delay reset etc. value parameterization thru entities:
      You can use expressions in condition operands by using the substitution syntax: ${{ your-expression }}
      You cannot use expression substitution in the values of condition options. These are required to be constants (literal values).
      The workaround is to group conditions and use additional conditions as gating criteria. For example, if you would change the "sustained for" delay based on time of day, say 120 for day and 600 for night, then you would have conditions structured like this:
      Group A - Daytime -- AND group
          Rule Condition: Rule "Is Day" is TRUE
          Entity Condition: some entity test that tests a value
              condition option: Sustained for 120 seconds
      Group B - Night -- AND group
          Rule Condition: Rule "Is Day" is FALSE
          Entity Condition: the same test as used in group A
              condition option: Sustained for 600 seconds
      M 1 Reply Last reply
        Thanks for your quick reply!
        I'll use that for the brightness threshold.
        Well unfortunately this doesn't help much if I need to set an arbitrary delay value from my custom UI.
        Could this be a new feature request to support expression substitution in timeout values (sustain / delay reset etc) if it's feasible to implement?
        br,
          I have similar cases and if this is feasible for you, just use delay before/after the actual actions. Delay actions are accepting expressions. I have a couple of them even using random delays.
            163.2k
