  4. Using Zooz ZEN32 Scene Controller as Trigger
8 Posts 4 Posters 2.8k Views 4 Watching
    Hello all, I recently installed a Zooz ZEN 32 scene controller and was looking for some guidance on how I could use a button press as a trigger in MSR. The scene controller has a total of 5 buttons that can activate scenes based on single press, double press, triple till 5 presses and also a press and hold. Currently in MSR I see an entity for the scene controller itself and separate entities for each button.
    Using the MSR native Z wave controller I can see the button.state (shows if it was pressed single double...) and button.since which shows the last time the button was pressed. The issue with the button.state is that say I press the scene controller button once its state is single but it never "resets" it's state will remain single. So if I press the button again the trigger won't work (pulse action won't work here because the state never changes).
    Going through HA similar issue but instead the x_hass.state is used and the number pertains to how many presses 0 means one press, 3 means 2 presses and so on. But again the x_hass.state never resets to an "off" state so retriggering the rule will not work if you press the button again.
    Before I tackle this in other ways using separate rules, input booleans and expressions is there any other way I can go about this? To me I need to trigger that is something like button_pressed.single but I don't see that option.
    No logs since there is technically no issues and no real examples since I am stuck at the triggers part lol.
    MSR 23302
    Z Wave 0.1.23194
    HA 2023.11.2
    • SnowmanS Offline
      SnowmanS Offline
      Snowman
      If I understand you correcltly, I had the same issue when I first setup this device. Here's what I did to ensure the button state gets reset after a button is pressed two times in my case.
      I am using the ZwaveJS controller provided by @togglebit.
      Triggers
      Controller Scene 001.button.state (primary) == double
      Set Reaction
      Controller Scene 001.button.release
      The "button.release" action ensures the button state resets.
      Give it a try.
      PablaP 1 Reply Last reply
      • SnowmanS Snowman
        Triggers
        Set Reaction
        Give it a try.
        @Snowman this is exactly what I needed!! Thanks 🙂
          The "correct" way is to check both the button state and the timestamp (button.since changes each time the button is pressed).
          Using the button.release action is not recommended.
          • SnowmanS Offline
            SnowmanS Offline
            Snowman
            @togglebits Thanks for the recommendation. I do have to ask though.
            I am by no means an expert so how am I supposed to know this? The documentation does not mention anything about this. And based on your recommendation, I will have to review all my rules/logics using this device.
            Thanks in advance.
              The question has been asked and answered in prior forum posts.
              • SnowmanS Snowman
                Thanks in advance.
                Andr
                @Snowman
                I think my old thread could be helpful for you.
                Good luck 🙂
                Adding remotes, scene controllers as entities to MSR
                • SnowmanS Offline
                  SnowmanS Offline
                  Snowman
                  Thank you both @togglebits and @Andr. I got it now.
                  • C cd12172 referenced this topic on
                    141.0k
