  4. Run rule on dimmer change?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
12 Posts 3 Posters 1.2k Views 3 Watching
  • I Offline
    I Offline
    ibrewster
    Reactor latest-23302-b7def56a; docker on Ubuntu 20.04; With Vera Plus and Ezlo Plus controllers
    I'm trying to tie the dimmer level of a dimmer switch to the dimmer level of a dimmable device (fan canopy light controller). In the triggers section of the rule I can select "dimming.level changes" as the condition, and I can get said dimming level in an expression that I then use to set the dimming.set attribute of the dimming device in the Set Reaction section, but this only works when going from 0--><some value>. When going from <some value> --> <some other value> or <some value>-->0, this does not work, because the rule is already set (it went true with the first change, and hasn't gone false yet - this is expected behavior as per the documentation)
    I can fix the <some value>-->0 issue by setting the Reset Reaction, but how can I get the rule to run - and set the entity dimming level - every time the switch value changes?
    (I tired to upload a screen shot of what I have, but I just kept getting errors)
      just to be clear, you have "changes from (any) to (any)" in your rule?
      • I Offline
        I Offline
        ibrewster
        That is correct, yes - and it works when going from 0-->any. After that, however, the condition evaluates to true, the rule is set, and so further changes do not trigger it again, as per the documentation (once true it remains true and the rule is not run again until it evaluates to false, i.e. 0)
        • I Offline
          I Offline
          ibrewster
          Ahhhh, I think I finally got it! If I add a second condition of device.dimming.level <> switch.dimming.level, then the rule is set whenever the switch changes, and quickly reset once the device is set to the same level, allowing the next change in switch level to properly trigger the rule again.
          Only took me two days and a forum post to figure that one out... 😆
            Please show your work (post screen shots of your rules).
            What you are describing doesn't make sense to me, and your fix seems unnecessary. I'd like to understand why, but I need to see your actual rules (please see the posting guidelines for this category as well).
            I 1 Reply Last reply
              I Offline
              I Offline
              ibrewster
              @toggledbits said in Run rule on dimmer change?:
              As I mentioned, I tried to do so, but the forum gives me errors. Specifically, it will show the image as uploading, get to 100%, pause, drop back to 60% (or so), give me a message stating "Looks like your connection to SmartHome Community was lost, please wait while we try to reconnect", the progress goes up to 100% again, and then I get an error stating "Something went wrong while parsing server response", and the image is not uploaded, leaving me with something like this:
              ![Screenshot 2023-12-01 at 8.55.28 AM.png]([[error:parse-error]])
              So as far as I can tell, no screen shot posting is possible.
              Perhaps walking through the steps of what happens will help?
              The rule is set up with a single Trigger:
              Entity Attribue -- Inovelli 2-in-1 (the switch) -- dimming.level -- changes -- from <blank> to <blank>
              A local expression is set up with the following code that gets the current dimming.level value:
              SwitchLevel = getEntity( "ezlo>device_65655fb712a3b714bdbcb935" ).attributes.dimming.level
              And a Set Reaction to set the LR Fan Light to the same level:
              Entity Action -- LR Fan Light -- dimming.set -- ${{SwitchLevel}}
              1. We start with the switch at 0 (off), and the rule is reset as expected
              2. We then set the switch to some other value (say, 50% or .5)
                2a. The rule is now set, and the Set Reaction runs as expected.
                2b. The rule remains set at this point - only going back to a dimming level of 0 will reset it.
              3. We then set the switch to another value, say 75% or .75
                3a. Since the rule is already in a set state, the Set Reaction does not run again, meaning the LR Fan light does not change dimming level
              Adding in the rule of the LR Fan Light level <> SwitchLevel allows the rule to drop back to a reset state after setting the LR Fan Light Level, thereby allowing it to run again the next time the switch level changes.
                If you only have a single trigger with changes -operator, the rule is immediately reset after the change (i.e. when change stops), so I don't quite get how your rule could stay set?
                  I Offline
                  I Offline
                  ibrewster
                  @tunnus said in Run rule on dimmer change?:
                  That is not the behavior I am seeing. Sorry! 🤷
                    ...and you don't have "delay reset" -condition option in use?
                    • I Offline
                      I Offline
                      ibrewster
                      wrote on last edited by ibrewster
                      Nope, the delay reset box is empty (nor have I tried to make any modifications in that section of the rule).
                      Although now that you mention it, it does seem odd, since while the rule remains set, if I toggle the rule open in the Rule Set list, the condition is evaluating to false, which (I would think) should reset the rule...right?
                      I have updated reactor recently, but let me try again in case 23302-b7def56a isn't the latest, and has a bug here...
                      EDIT: Nope, doesn't appear there are any updates available
                      • I Offline
                        I Offline
                        ibrewster
                        Ok, now I'm really confused. As part of my attempt to update reactor, the docker container obviously got restarted - and now the rule is working as expected, with only the change condition. I have no idea why the change in behavior, but at least it is now working as you guys expected.
                          Sounds to me like your UI was out of sync. A hard refresh should be done any time things don't look like expected.
                            111
                            3.5k
                            3.1k
                            428
                          • Self test
