  4. Alarm from Home Assistant MQTT format into MSR
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 1.2k Views 2 Watching
    Hi everyone and happy new year!
    I've recently moved to an alarm integration that's using HASS MQTT format but I'm not pushing it to HASS as I've just mapped it as MSR entities.
    security_mode capability has less options and I'm wondering what's the best way to map other statuses. Is adding my own values considered safe or should we ask for more default statuses? Paging @toggledbits here, because I'm not sure a new ticket on mantis at this point is preferred instead of a post.
    Then, I'm just double checking what's everyone using regarding alarm panels.
    I'm using string_sensor.value to save the zone that's been armed/disarmed and keypad to keep track of the code/users/actions
    For the siren I'm just using a binary_sensor, with string_sensor in the same device to get the zone that's been triggered.
    What are you guys doing? Thanks!
    • toggledbitsT Online
      toggledbitsT Online
      Reactor doesn't restrict attribute values to only those declared in a capability. You can set an entity attribute to any value you want. I will happily add values to the standard definition if they seem universal; having them defined by the Z-Wave or ZigBee specs also contributes a vote.
        I don't have a Zwave/Zigbee Alarm, so I really don't know. I tried to search for something, but these alarms are not common. Right now, I'm just setting the same value coming from the payload.
        I had a virtual AlarmPartition under Vera and it was not mapped to security_mode, but that's fair, because I'm quite sure this capability was used in plugins and not by real devices.
        EDIT: since we're at this, is it safe to assume that the values reported in the docs (http://msr.bochicchio.it/docs/Standard-Capabilities/#other) are lower case instead of the case reported in the doc page? Thanks @toggledbits
          163.1k
