  4. Reaction using Shell Command SSH
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 1 Posters 885 Views 1 Watching
  • C Offline
    C Offline
    cd12172
    wrote on last edited by cd12172
    Hi (fourth draft to simplify as I solve problems...)
    My MSR is installed from the HASS add on store.
    The Docker container did not have SSH client installed.
    I was able to get SSH installed and setup keys on a remote worker server for password free SSH logins.
    I now have a shell command that sends commands to the remote worker server. It renders content to a tidbyt LED matrix display.
    Does anyone know if this will survive an update of the Reactor addon? Will the updated docker image wipe SSH and the private keys stored in the Reactor Docker Container?
    Also - is it better to just move Reactor over to the worker server and manage my own updates?
    I am using HAOS - Core-2024.1.2, Supervisor 2023.12.0, OS 11.3
    • C Offline
      C Offline
      cd12172
      Update ot anyone trying to SSH from Multihub Reactor...
      I went to a linux bare metal install. Installing through the Add On store reset the docker image with every HASS restart. This means openSSH and the shared keys would disappear.
      Also - at time of writting the AddOn store version is out of date with no appearant activty. Likely to change, but I moved on to give more flexability to MSR.
      I look forward to the unintended consequences 🙂
        162.9k
