  4. Move Reactor from Docker to Home assistant plugin
3 Posts 2 Posters 1.0k Views 2 Watching
  • H Offline
    H Offline
    HansW
    I just installed the Reactor plugin for home assistant and tried to move my configuration by copying the reactor-data files to the same location in the home assistant files. Unfortunately this does not work.
    I tried rebooting, restarting but the reactor in home assistant stays clean. I tried adding some rules, they do stick but I soo no difference in the reactor-files.
    I guess I am missing something very obvious???
    No idea what however.... So I would appreciate some pointers.
    Warm regards
    Hans
    • H Offline
      H Offline
      HansW
      @toggledbits I installed the reactor plugin on the advice in the manual,
      Could you please give me an advice here?
      Warm regards,
      Hans
        I did not write the Reactor Add-on installation method/package for Home Assistant and I do not support it. I have no idea how it works, and I don't have a setup to debug/troubleshoot with. Perhaps another user of the Reactor Add-on can chime in.
        There was a related question/post in late December, here, and other recent posts. Check those out. They may provide some insight.
        The user who originally provided that add-on is no longer providing updates, apparently. Perhaps someone else who uses this configuration would want to pick it up?
          160.3k
