  4. HomeAsssistant Weather changed.... Global expression no longer functioning
Unable to add new groups in DGC, Reactor latest-26318
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
16 Posts 4 Posters 5.1k Views 4 Watching
    I had the same problem and moved to a rule with openweathermap.
    I capture the response in a global variable and use it in my automation. I even have a couple of virtual devices to remap it. Less dependent on HASS and OWM has better forecast for me. Free API keys if you make two separate calls for current and forecast.
      @therealdb said in HomeAsssistant Weather changed.... Global expression no longer functioning:
      I tried that, and you're right, in theory it should work, however, OWM shows "null" for forecast low for me.
        @tamorgen are you installed bare-metal, or running in docker?
          @tamorgen I've used OWM and VisualCrossing as well as pulling data in via local API from my Ambient and Tempest weather arrays in the backyard.
          OWM is currently in the middle of changing to v3.0 of their All-in-One API, fyi. This may/may not affect you.
            Service responses are addressed in build 24115 (just released)
            • T tamorgen
              @tamorgen try cnt param or similar to limit the response size.
                it's cnt. Since I just want the next forecast, I'm limiting it to 5.
                https://api.openweathermap.org/data/2.5/forecast?lat=X&lon=X&units=metric&appid=X&lang=en&cnt=5
                @gwp1 is right, but if you don't want to use onecall (very helpful to be honest) and want to make two calls, you'll be good with the free one. As I said, I just want forecast (for cloud, rain and min/max temp), so it's just one call for me.
                Initially I wanted to make a dedicated controller for OWM (using the native weather station capability), but it's just one call, so it's easier this way.
                  I'm installed bare-metal.
                    So it does appear to call the service now. Now I have to figure out how to get it into my expression.
                    This output was from going into the Entities tab, and running the service manually. If I want to get the forecast and get the high/low temps, will i need to run an action daily to call the service, or will the expression do it for me? I don't see any documentation yet on the Reactor installation instructions for Service responses.
                    wx.asoftime=null
                    wx.ceiling=null
                    wx.ceiling_unit=null
                    wx.cloud_cover=null
                    wx.condition_code=null
                    wx.description="cloudy"
                    wx.feels_like=null
                    wx.humidity=60
                    wx.humidity_unit="%"
                    wx.icon=null
                    wx.location=null
                    wx.precipitation_1hr=null
                    wx.precipitation_24hr=null
                    wx.precipitation_other=null
                    wx.precipitation_type=null
                    wx.precipitation_unit="in"
                    wx.pressure=30.26
                    wx.pressure_unit="inHg"
                    wx.temperature=41
                    wx.temperature_unit="°F"
                    wx.visibility=null
                    wx.visibility_unit="mi"
                    wx.wind_compass=13.7
                    wx.wind_conditions=null
                    wx.wind_direction="N"
                    wx.wind_gust=null
                    wx.wind_speed=8.26
                    wx.wind_speed_unit="mph"
                    x_hass.domain="weather"
                    x_hass.entity_id="weather.forecast_home"
                    x_hass.services=["weather"]
                    x_hass.state="cloudy"
                    x_hass_attr.attribution="Weather forecast from met.no, delivered by the Norwegian Meteorological Institute."
                    x_hass_attr.cloud_coverage=89.8
                    x_hass_attr.dew_point=28
                    x_hass_attr.friendly_name="New Windsor Weather"
                    x_hass_attr.humidity=60
                    x_hass_attr.precipitation_unit="in"
                    x_hass_attr.pressure=30.26
                    x_hass_attr.pressure_unit="inHg"
                    x_hass_attr.supported_features=3
                    x_hass_attr.temperature=41
                    x_hass_attr.temperature_unit="°F"
                    x_hass_attr.visibility_unit="mi"
                    x_hass_attr.wind_bearing=13.7
                    x_hass_attr.wind_speed=8.26
                    x_hass_attr.wind_speed_unit="mph"
                    x_hass.last_response={"service":"weather.get_forecasts","since":1714043894115,"response":{"weather.forecast_home":{"forecast":[{"condition":"partlycloudy","datetime":"2024-04-25T16:00:00+00:00","wind_bearing":24,"temperature":57,"templow":41,"wind_speed":8.26,"precipitation":0,"humidity":51},{"condition":"sunny","datetime":"2024-04-26T16:00:00+00:00","wind_bearing":130.1,"temperature":61,"templow":41,"wind_speed":10.5,"precipitation":0,"humidity":30},{"condition":"cloudy","datetime":"2024-04-27T16:00:00+00:00","wind_bearing":142.8,"temperature":56,"templow":42,"wind_speed":10.31,"precipitation":0,"humidity":59},{"condition":"sunny","datetime":"2024-04-28T16:00:00+00:00","wind_bearing":234.2,"temperature":78,"templow":47,"wind_speed":7.15,"precipitation":0,"humidity":49},{"condition":"partlycloudy","datetime":"2024-04-29T16:00:00+00:00","wind_bearing":239.6,"temperature":86,"templow":62,"wind_speed":6.28,"precipitation":0,"humidity":42},{"condition":"cloudy","datetime":"2024-04-30T16:00:00+00:00","wind_bearing":257.4,"temperature":85,"templow":67,"wind_speed":8.08,"precipitation":0.02,"humidity":39}]}}}
                    My call was for daily, so it shows a forecast for 5 days. Somehow I need to distinguish just today's forecast.
                      The response is stored on the target Reactor entity (that's entity from which you make the service call, unless you are using call_service from the system entity, in which case you have to specify a target). The x_hass.last_response attribute is used to store the returned response. It is not processed in any way, it is stored as it is received (so it will always be a string).
                      I think the rest of the work is pretty much the same as how you'd handle a response from an HTTP request, and you've probably done it all before, but I'll spell it out for the benefit of other future readers.
                      If you copy-paste the response into a beautifier like jsonlint.com it will pretty-print the object so it's easier to discern its structure. The forecast lives in an array called forecast, and the array seems to have the current day's forecast as the first element (i.e. it's sorted by date, ascending). An unfortunate choice on the API's part is that they chose to name a key in their response weather.forecast_home — the dot in the key name will make it just a little harder to navigate through the object, because dot is a special syntax character in the expression language for accessing elements in object. We'll have to use an alternate syntax, which I'll illustrate with the example expression below that brings everything together up to this point. I break it into two parts to keep it more readable and easy to follow:
                      r = getEntity( 'entity-canonical-id' ).attributes.x_hass.last_response,
                      forecast_today = r.response['weather.forecast_home'].forecast[0]
                      Although this is two lines, it is implemented in one (probably global) expression. In the first line, we use an expression local variable r to fetch the response data from the entity. In the second line, we traverse the data in r to get to the forecast data. We use ['name'] syntax instead of .name syntax to access the property with key weather.forecast_home. The [0] at the end simply gets the first element (they are numbered from 0 in our expression language) of the forecast array.
                      At this point, the expression result would be an object containing the first forecast. You can add a further line to this expression to return one value from the forecast if you only need one, or create multiple new expressions that use the result of this expression if you need more than one value.
                      condition = forecast_today.condition
                      templow = forecast_today.tempLow
                      Overall, I'd make one rule to periodically call the service and fetch the weather, with whatever frequency suits you (i.e. it only does the fetch). I'd make forecast_today above a global expression. The parts of the forecast you need could be drawn out from forecast_today using other global expressions or in rule expressions. When the query rule causes an update to x_hass.last_response, the engine will re-evaluate the forecast_today expression to parse the result to the single forecast object. Other expression evaluations will be triggered by a change in that object, and that, of course, will cause evaluation of rules' triggers that involve those variables.
                        Looks like I may be missing something....
                        I tried it as you showed it, putting my cannonical ID in place.
                        It's giving me a response error "Last value: (error) Unexpected token o in JSON at position 1"
                        I then tried splitting up the lines, but that doesn't seem to work either.
                        It's giving me an error about an unexpected token o in JSON at position 1 as well, however, for the second one, it gives me "Last value: (error) Invalid scope in reference to member response of (object)null". I suspect the first method is the correct one, but I must have something incorrect in the format.
                          My bad. Looks like it does return a real object, and it doesn't need to be parsed. Remove the parseJSON() call. I'll fix up the earlier post.
                            Awesome, that did the trick!
                              164.4k
