  4. [MSR] Virtual and MQTT entities losing status after updates
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
7 Posts 3 Posters 1.3k Views 3 Watching
      Updates to extension controllers and Reactor itself (and its included controllers) often change the definition of capabilities and their implementation. To bring the entities up to the latest version of these capabilities and compatibility with their parent Controller's implementation, the entity is rebuilt, and when that happens, all previous attributes values are lost. Not doing it can result in logged errors and other more serious misbehavior. I can look into less dramatic solutions, but it won't be soon.
        @toggledbits that’s ok. I could write something to adapt to this behavior, as I’ve already done. I could just save the status to a global variable on stop and restore at startup if null. Being string or number values, it should be easier than forcing you to look at a general solution. Thanks.
          Also noticed this some time ago, and adapted using e.g. the following rule (if virtual switches have lost their values (states), defaults are set when MSR starts)
            @toggledbits since we're at this, what about a new config parameter in at least Virtual Entities (let's call it defaultValue)?
            It should be easier than writing a bunch of rules. Thanks.
              Not sure if that's enough to be generic (I have 40 virtual devices and some of them have values changed on the fly to drive some custom things, where restoring a default is not the best thing to do), but I've ended up with something like that.
              A rule that's saving the status in a global variable when a new Reactor version is available:
              dev =  matchEntities( { controller: 'virtual' } ),
              each d in dev: do
                d != "virtual>controller_all" && d != "virtual>system" ?
                  ({id: d, attributes: getEntity(d).attributes})
              : null done
              (maybe some checks to avoid null values could be useful, but when a new version is detected the old values should be in place - I cannot save them at shutdown, the best thing to do in order to get fresh values before the update)
              And another one running at startup and checking for nulls and restoring the values:
              each d in virtualdevices_status: do
                each attrs, key in d.attributes: do
                key != 'x_virtualentity' ?
                  each attr, akey in attrs: do
                  cVal = getEntity(d.id)?.attributes?[key]?[akey],
                  sVal = attr,
                  cVal == null && sVal != null ?
                      do
                        performAction(d.id, 'x_virtualentity.set_attribute', {akey: attr}),
                        d.id + ' _ ' + akey + ":" + attr
                      done
                    : null
                done : null
                done
              done
              YMMV.
              At this point, I'd probably appreciate the ability to define blocks of code and execute them directly in a reaction, instead of calls to a fake Set Variable, or at least if Set Variable reaction could support line breaks/multiline text, for readability.
              This could be easily encapsulated in a custom controller, but last time I checked we cannot call performAction or getEntity on other controllers. I tought to monitor via MQTT via an external script, but I wanted to stay in MSR in order to simplify things. Any comments @toggledbits? Thanks.
                each d in dev: do
                : null done
                    sVal = attr,
                        do
                        done
                      : null
                  done : null
                  done
                done
                YMMV.
                This code is now obsolete because the latest versions of both MSR and MQTTController have this behavior natively. I'll leave it just in case someone wants to look at some code enumerating/saving attributes.
                • Next Release?
