  4. Need Testers
Need Testers
78 Posts 8 Posters 49.6k Views 8 Watching
    Build 24120
    • Mostly code cleanup and tightening around application restriction.
    • Should fix Tools > Restart Reactor issue
      Not hearing a lot of grumbling, which is a Good Thing so far. Any and all feedback welcome. Please comment on the docs, too, if you have anything. On my end, I'm out of things to do on this feature, nothing to add, so I'm just waiting for fixing/tweaking.
        @toggledbits thanks for this feature! I sort of had to volunteer as a tester as I originally did a feature request for authentication support...
        Anyway, seems to work nicely, although only about an hour of testing behind. Will keep you posted if anything unexpected comes up. You could update docs though:
        "1. Copy the template users.yaml-dist from the dist-config distribution directory to your config directory."
        --> "1. Copy the template users.yaml-dist from the /opt/reactor/dist-config distribution directory to your config directory. Rename it as users.yaml file."
        (at least for me as a Docker user it wasn't immediately clear where to find this template)
        PablaP 1 Reply Last reply
          @tunnus Yes this would be a good improvement to the docs.. you weren't the only one who made this mistake lol!
            #32
            well, I actually knew to rename this file, but it took a while to find that template (as I've used MSR container for years now and did not remember the location of dist-config)
            • N Offline
              N Offline
              Hi, I used Portainer to change the image from latest to userauth and it was easy and thanks for this update!
              current configuration:
              Synology NAS/Docker/Reactor (Multi-hub) userauth-24120-7745fb8d
              unexpected:
              when I try to log in on http://10.0.0.1:8111/dashboard/ as admin:admin, I'm redirect to reactor http://10.0.0.1:8111/reactor/en-US/ and not to dashboard
              This happens on Chrome and Edge
              Features/suggestion that I image:
              Guest user has access to:
              all dashboard set to public (homescreen - all public group tile - all public single tile)
              where group tile are rooms/hubs/virtual/weather on homescreen dashboard
              and single tile are all the entities: devices/virtual devices/etc
              Admin can use option on tile VISIBLE/HIDDEN icon by clicking on it.
              If a tile is set to HIDDEN, all entities associated with it will also be hidden. Setting VISIBLE on specific entities will not be respected. Setting hidden on specific entities it will be not visible to guests.
              So Public means VISIBLE.
              imaging it:
              -Docker on Synology NAS
              -HASS Docker 2026.8.1
              -ZWaveJS-UI 11.22.3
              -Update 16/08/2026
                #34
                Not sure if others are experiencing the same, but with this build (userauth-24120-7745fb8d) if I go to Manual (i.e. http://reactor-ip:8111/docs/), it takes a very long time before search can be used as it stays in "initializing search" state. At least I haven't noticed the same with earlier releases. Browser is Chrome.
                  @toggledbits another thing noticed with this build is that deleting global reactions does not work.
                  How to reproduce:
                  1. create reaction
                  2. delete it
                  3. refresh browser
                  4. reaction is back...
                    How to reproduce:
                    1. create reaction
                    2. delete it
                    3. refresh browser
                    #36
                    @tunnus said in Need Testers:
                    I see it. It's also happening to latest-24115. I've got it fixed on my end and will roll a build on Sunday.
                    @noelab said in Need Testers:
                    I think I've got that nailed down as well. Look for Sunday's build.
                    @Pabla said in Need Testers:
                    I think better still, have Reactor docker containers copy dist-config to your data directory (as dist-config, not overwriting any existing real config), so no special steps are needed to find those files, they are just there. Sunday's build.
                      #37
                      Anyone else noticed this? @noelab, @Pabla? Other thing I found out today was that there's some kind of a log problem going on, Docker logs claim that reactor.log file cannot be found:
                      2024/05/11 21:48:36	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                      2024/05/11 21:48:32	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                      2024/05/11 21:48:32	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                      2024/05/11 21:48:32	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                      2024/05/11 21:48:32	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                      2024/05/11 21:48:09	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                      2024/05/11 21:48:08	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                      2024/05/11 21:48:08	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                      2024/05/11 21:48:08	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                      2024/05/11 21:48:08	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                      2024/05/11 21:46:50	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                      2024/05/11 21:46:45	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                      2024/05/11 21:46:45	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                      2024/05/11 21:46:45	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                      But reactor.log file seems to in place when checked via terminal:
                      N PablaP 2 Replies Last reply
                        N Offline
                        N Offline
                        @tunnus yes, some problem here too from the reactor log in container manager. Hope this may help too:
                        2024/05/08 21:20:46	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                        2024/05/08 21:20:46	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                        2024/05/08 21:20:46	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                        2024/05/08 21:20:46	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                        2024/05/08 21:20:46	stdout	[userauth-24120]2024-05-08T19:20:46.401Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 7ms (from 1715196046401<5/8/2024, 9:20:46 PM> to 1715196046408<5/8/2024, 9:20:46 PM>)
                        2024/05/08 21:20:45	stdout	[userauth-24120]2024-05-08T19:20:45.347Z <Timer:null> Timer#rule-lq1iq5i3 just a note: I'm setting a delay of only 8ms (from 1715196045347<5/8/2024, 9:20:45 PM> to 1715196045355<5/8/2024, 9:20:45 PM>)
                        2024/05/08 21:20:42	stdout	[userauth-24120]2024-05-08T19:20:42.093Z <Timer:null> Timer#rule-lq5ri09p just a note: I'm setting a delay of only 8ms (from 1715196042093<5/8/2024, 9:20:42 PM> to 1715196042101<5/8/2024, 9:20:42 PM>)
                        2024/05/08 21:19:04	stdout	[userauth-24120]2024-05-08T19:19:04.547Z <Timer:null> Timer#rule-lq5rgx5t just a note: I'm setting a delay of only 8ms (from 1715195944547<5/8/2024, 9:19:04 PM> to 1715195944555<5/8/2024, 9:19:04 PM>)
                        2024/05/08 21:19:02	stdout	[userauth-24120]2024-05-08T19:19:02.765Z <Timer:null> Timer#rule-lq5rhvua just a note: I'm setting a delay of only 8ms (from 1715195942765<5/8/2024, 9:19:02 PM> to 1715195942773<5/8/2024, 9:19:02 PM>)
                        2024/05/08 21:19:02	stdout	[userauth-24120]2024-05-08T19:19:02.153Z <EzloController:null> remapped item action to [Object]{ "item": "switch", "value": true, "method": "hub.item.value.set", "parameters": { "value": { "value": true } } }
                        2024/05/08 21:19:01	stdout	[userauth-24120]2024-05-08T19:19:01.110Z <Timer:null> Timer#rule-lq5qgdau just a note: I'm setting a delay of only 8ms (from 1715195941110<5/8/2024, 9:19:01 PM> to 1715195941118<5/8/2024, 9:19:01 PM>)
                        2024/05/08 21:18:59	stdout	[userauth-24120]2024-05-08T19:18:59.226Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715195939226<5/8/2024, 9:18:59 PM> to 1715195939234<5/8/2024, 9:18:59 PM>)
                        2024/05/08 21:17:10	stdout	[userauth-24120]2024-05-08T19:17:10.678Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715195830678<5/8/2024, 9:17:10 PM> to 1715195830686<5/8/2024, 9:17:10 PM>)
                        2024/05/08 21:14:44	stdout	[userauth-24120]2024-05-08T19:14:44.540Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715195684540<5/8/2024, 9:14:44 PM> to 1715195684548<5/8/2024, 9:14:44 PM>)
                        2024/05/08 21:09:18	stdout	[userauth-24120]2024-05-08T19:09:18.150Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715195358150<5/8/2024, 9:09:18 PM> to 1715195358158<5/8/2024, 9:09:18 PM>)
                        2024/05/08 21:05:44	stdout	[userauth-24120]2024-05-08T19:05:44.738Z <Timer:null> Timer#rule-ks56ms0b just a note: I'm setting a delay of only 8ms (from 1715195144738<5/8/2024, 9:05:44 PM> to 1715195144746<5/8/2024, 9:05:44 PM>)
                        2024/05/08 21:05:44	stdout	[userauth-24120]2024-05-08T19:05:44.719Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715195144719<5/8/2024, 9:05:44 PM> to 1715195144727<5/8/2024, 9:05:44 PM>)
                        2024/05/08 21:00:16	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                        2024/05/08 21:00:14	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                        2024/05/08 21:00:12	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                        2024/05/08 21:00:12	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                        2024/05/08 21:00:12	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                        2024/05/08 20:59:52	stdout	[userauth-24120]2024-05-08T18:59:52.886Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715194792886<5/8/2024, 8:59:52 PM> to 1715194792894<5/8/2024, 8:59:52 PM>)
                        2024/05/08 20:58:22	stdout	[userauth-24120]2024-05-08T18:58:22.585Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715194702585<5/8/2024, 8:58:22 PM> to 1715194702593<5/8/2024, 8:58:22 PM>)
                        2024/05/08 20:56:26	stdout	[userauth-24120]2024-05-08T18:56:26.917Z <Timer:null> Timer#rule-lq5rh1ns just a note: I'm setting a delay of only 8ms (from 1715194586917<5/8/2024, 8:56:26 PM> to 1715194586925<5/8/2024, 8:56:26 PM>)
                        2024/05/08 20:56:06	stdout	[userauth-24120]2024-05-08T18:56:06.581Z <Timer:null> Timer#rule-lq1iq5i3 just a note: I'm setting a delay of only 8ms (from 1715194566581<5/8/2024, 8:56:06 PM> to 1715194566589<5/8/2024, 8:56:06 PM>)
                        2024/05/08 20:54:49	stdout	[userauth-24120]2024-05-08T18:54:49.514Z <Timer:null> Timer#rule-lq5rgx5t just a note: I'm setting a delay of only 8ms (from 1715194489514<5/8/2024, 8:54:49 PM> to 1715194489522<5/8/2024, 8:54:49 PM>)
                        2024/05/08 20:54:49	stdout	[userauth-24120]2024-05-08T18:54:49.058Z <Timer:null> Timer#rule-lq5qgdau just a note: I'm setting a delay of only 8ms (from 1715194489058<5/8/2024, 8:54:49 PM> to 1715194489066<5/8/2024, 8:54:49 PM>)
                        2024/05/08 20:54:43	stdout	[userauth-24120]2024-05-08T18:54:43.027Z <Timer:null> Timer#rule-lq5qgdau just a note: I'm setting a delay of only 8ms (from 1715194483027<5/8/2024, 8:54:43 PM> to 1715194483035<5/8/2024, 8:54:43 PM>)
                        2024/05/08 20:50:44	stdout	[userauth-24120]2024-05-08T18:50:44.225Z <Timer:null> Timer#rule-lq5rh750 just a note: I'm setting a delay of only 8ms (from 1715194244225<5/8/2024, 8:50:44 PM> to 1715194244233<5/8/2024, 8:50:44 PM>)
                        2024/05/08 20:50:43	stdout	[userauth-24120]2024-05-08T18:50:43.256Z <EzloController:null> remapped item action to [Object]{ "item": "dimmer", "value_expr": "min(100,max(0,floor(parameters.level*100+0.5)))", "method": "hub.item.value.set", "parameters": { "value": { "value_expr": "min(100,max(0,floor(parameters.level*100+0.5)))" } } }
                        2024/05/08 20:47:23	stdout	[userauth-24120]2024-05-08T18:47:23.713Z <Timer:null> Timer#rule-ks56ms0b just a note: I'm setting a delay of only 8ms (from 1715194043713<5/8/2024, 8:47:23 PM> to 1715194043721<5/8/2024, 8:47:23 PM>)
                        2024/05/08 20:47:23	stdout	[userauth-24120]2024-05-08T18:47:23.693Z <Timer:null> Timer#rule-lq5rhax4 just a note: I'm setting a delay of only 8ms (from 1715194043693<5/8/2024, 8:47:23 PM> to 1715194043701<5/8/2024, 8:47:23 PM>)
                        2024/05/08 20:47:22	stdout	[userauth-24120]2024-05-08T18:47:22.392Z <EzloController:null> remapped item action to [Object]{ "item": "switch", "value": false, "method": "hub.item.value.set", "parameters": { "value": { "value": false } } }
                        2024/05/08 20:46:10	stdout	[userauth-24120]2024-05-08T18:46:09.716Z <default:null> Module NotifyAlert v21092
                        2024/05/08 20:46:10	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                        2024/05/08 20:46:10	stdout	[userauth-24120]2024-05-08T18:46:09.704Z <default:null> Module NotifyPushover v21195
                        2024/05/08 20:46:10	stdout	[Reactor Log Panic] FileLogStream("/var/reactor/logs/reactor.log") error: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                        2024/05/08 20:46:10	stdout	/var/reactor/logs/reactor.log not found; reopening stream
                        2024/05/08 20:46:10	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                        2024/05/08 20:46:09	stdout	[userauth-24120]2024-05-08T18:46:09.014Z <Notifier:null> Module Notifier v22283
                        2024/05/08 20:46:06	stdout	    at /opt/reactor/server/lib/VirtualEntityController.js:357:319
                        2024/05/08 20:46:06	stdout	    at VirtualEntityController._load_devices (/opt/reactor/server/lib/VirtualEntityController.js:644:114)
                        2024/05/08 20:46:06	stdout	    at Entity.setPrimaryAttribute (/opt/reactor/server/lib/Entity.js:563:19)
                        2024/05/08 20:46:06	stdout	Error: Invalid primary attribute assignment; capability not assigned (state_sensor.value)
                        2024/05/08 20:46:06	stdout	[userauth-24120]2024-05-08T18:46:06.542Z <VirtualEntityController:CRIT> Error: Invalid primary attribute assignment; capability not assigned (state_sensor.value) [-]
                        2024/05/08 20:46:06	stdout	Error: Invalid primary attribute assignment; capability not assigned (string_sensor.value)
                        2024/05/08 20:46:06	stdout	[userauth-24120]2024-05-08T18:46:06.541Z <VirtualEntityController:CRIT> Error: Invalid primary attribute assignment; capability not assigned (string_sensor.value) [-]
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.410Z <VirtualEntityController:null> Module VirtualEntityController v24117
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.391Z <SystemController:null> Module SystemController v24076
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.382Z <OWMWeatherController:null> Module OWMWeatherController v22294
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.161Z <EzloController:null> Module EzloController v23345
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.090Z <VeraController:null> Module VeraController v24050
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:05.089Z <TaskQueue:null> Module TaskQueue 24113
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.993Z <HassController:null> Module HassController v24115
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.726Z <InfluxFeed:null> Module InfluxFeed v23341
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.682Z <wsapi:null> Module wsapi v24115
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.439Z <httpapi:null> Module httpapi v24119
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.231Z <Engine:null> Module Engine v24113
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.229Z <GlobalReaction:null> Module GlobalReaction v24099
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.197Z <Rule:null> Module Rule v24115
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.176Z <AlertManager:null> Module AlertManager v24099
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.107Z <Predicate:null> Module Predicate v23093
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.045Z <GlobalExpression:null> Module GlobalExpression v24099
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.023Z <default:null> Module Rulesets v24099
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:04.022Z <default:null> Module Ruleset v24099
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.952Z <Controller:null> Module Controller v24099
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.929Z <Entity:null> Module Entity v24108
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.925Z <TimerBroker:null> Module TimerBroker v22283
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.460Z <Plugin:null> Module Plugin v22300
                        2024/05/08 20:46:05	stdout	[userauth-24120]2024-05-08T18:46:03.311Z <Capabilities:null> Module Capabilities v23331
                        2024/05/08 20:46:03	stdout	[userauth-24120]2024-05-08T18:46:03.269Z <Structure:null> Module Structure v24110
                        2024/05/08 20:46:03	stdout	[userauth-24120]2024-05-08T18:46:03.059Z <app:null> Local date/time using configured timezone and locale formatting is "5/8/2024, 8:46:03 PM"
                        2024/05/08 20:46:03	stdout	[userauth-24120]2024-05-08T18:46:03.058Z <app:null> Loaded locale en-US for en-US
                        2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.890Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8
                        2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.750Z <app:null> Resolved timezone=Europe/Rome, environment TZ=Europe/Rome; offset minutes from UTC=120
                        2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.656Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
                        2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.656Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
                        2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.656Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined)
                        2024/05/08 20:46:02	stdout	[userauth-24120]2024-05-08T18:46:02.584Z <app:null> Reactor build userauth-24120-7745fb8d starting on v20.10.0 /usr/local/bin/node
                        2024/05/08 20:46:02	stdout	NODE_PATH /opt/reactor:/opt/reactor/node_modules
                        2024/05/08 20:46:02	stdout	Reactor userauth-24120-7745fb8d app 24120 configuration from /var/reactor/config
                        -ZWaveJS-UI 11.22.3
                        -Update 16/08/2026
                          It looks like you may have a misconfiguration in your VirtualEntityController config. Can you post the config section for that?
                          N 1 Reply Last reply
                            N Offline
                            N Offline
                            some devices are created for test purpose so maybe there are errors
                            code_text
                            • id: virtual
                              implementation: VirtualEntityController
                              enabled: true
                              entities:
                              HomeMode
                                 template: Binary Sensor
                                 name: v00 Automation Mode
                              Indici Temperatura Umidità
                                 name: v00 Temp Inside HOT
                                 template: Value Sensor
                                 name: v00 Temp Outside HOT
                                 name: v00 Temp Outside>Inside
                                 name: v00 Umidita Assoluta Interna
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xWeather_Umidita_Assoluta_Interna
                                 primary_attribute: value_sensor.value
                                 type: ValueSensor
                                 name: v00 Umidita Assoluta Esterna
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xWeather_Umidita_Assoluta_Esterna
                                 type: ValueSensor
                              IndiceThom
                                 name: vB1 IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xB1_IndiceThom_ID
                                 type: ValueSensor
                                 name: vB2 IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xB2_IndiceThom_ID
                                 type: ValueSensor
                                 name: vCS IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xCS_IndiceThom_ID
                                 type: ValueSensor
                                 name: vH IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xH_IndiceThom_ID
                                 type: ValueSensor
                                 name: vK IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xK_IndiceThom_ID
                                 type: ValueSensor
                                 name: vL IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xL_IndiceThom_ID
                                 type: ValueSensor
                                 name: vR1 IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR1_IndiceThom_ID
                                 type: ValueSensor
                                 name: vR2 IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR2_IndiceThom_ID
                                 type: ValueSensor
                                 name: vR3 IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR3_IndiceThom_ID
                                 type: ValueSensor
                                 name: vR4 IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR4_IndiceThom_ID
                                 type: ValueSensor
                                 name: vT IndiceThom
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xT_IndiceThom_ID
                                 type: ValueSensor
                              LUX Funzionale
                                 name: vB1 LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xB1_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vB2 LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xB2_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vCS LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xCS_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vH LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xH_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vK LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xK_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vL LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xL_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vR1 LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR1_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vR2 LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR2_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vR3 LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR3_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vR4 LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR4_Lux_Funzionale_ID
                                 type: ValueSensor
                                 name: vT LuxFunzionale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xT_Lux_Funzionale_ID
                                 type: ValueSensor
                              LUX AMBIENTALE
                                 name: vB1 LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xB1_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vB2 LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xB2_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vCS LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xCS_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vH LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xH_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vK LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xK_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vL LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xL_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vR1 LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR1_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vR2 LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR2_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vR3 LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR3_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vR4 LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xR4_Lux_Ambientale_ID
                                 type: ValueSensor
                                 name: vT LuxAmbientale
                                 capabilities:
                                   value_sensor:
                                       value:
                                         expr: xT_Lux_Ambientale_ID
                                 type: ValueSensor
                              State
                              EnergyMode10
                                 name: v00 EnergyMode Biorario
                                 name: v00 EnergyMode Sovraccarico Locale
                                 name: v00 EnergyMode Lavatrice State
                                 template: String Sensor
                                 capabilities:
                                   string_sensor:
                                       value:
                                         expr: xB1_Lavatrice_State
                                 name: v00 EnergyMode Oven State
                                 capabilities:
                                   string_sensor:
                                       value:
                                         expr: xK_Oven_State
                                 name: v00 EnergyMode Fridge State
                                 capabilities:
                                   string_sensor:
                                       value:
                                         expr: xK_Fridge_State
                                 name: v00 EnergyMode Dishwasher State
                                 capabilities:
                                   string_sensor:
                                       value:
                                         expr: xK_Dishwasher_State
                              HVACMode20
                              TEST100
                                 template: Binary Switch
                                 name: TestF ValueSensor
                                 name: TestG ValueSensor
                                 name: TestH StringSensor
                                 name: TestI StringSensor
                                 name: TestJ StringSensor
                                 name: Test Virtual Heating Thermostat
                                 capabilities:
                                   - hvac_control
                                   - hvac_heating_unit
                                   - temperature_sensor
                                 primary_attribute: hvac_control.state
                                 template: Dimmer
                                 name: Test Virtual Color DimmerA
                                 capabilities:
                                   - color_temperature
                                 template: Dimmer
                                 name: Test Virtual Color DimmerB
                                 name: Test ModeHouse StringSensor
                                 capabilities:
                                   string_sensor:
                                       value:
                                         expr: x00_HouseMode_StartState
                                 name: TestA Dynamic Vec Binary
                                 capabilities:
                                   value_sensor:
                                       value:
                                 primary_attribute: string_sensor.value
                                 type: StringSensor
                                 name: TestB Dynamic Vec Binary
                                 capabilities:
                                   binary_sensor:
                                       state:
                                         expr:
                                 primary_attribute: state_sensor.value
                                 type: BinarySensor
                                 name: TestC Dynamic Vec Binary
                                 capabilities:
                                   value_sensor:
                                       value:
                                         if_expr: test
                                 name: TEST D Dynamic VEC
                                 capabilities:
                                   binary_sensor:
                                       state:
                                         expr:
                              END VIRTUAL DEVICE
                            -ZWaveJS-UI 11.22.3
                            -Update 16/08/2026
                            • N noelab
                              code_text
                              • id: virtual
                                enabled: true
                                entities:
                                HomeMode
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                IndiceThom
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   name: vH IndiceThom
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   name: vK IndiceThom
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   name: vL IndiceThom
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   name: vT IndiceThom
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                LUX Funzionale
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                LUX AMBIENTALE
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: ValueSensor
                                State
                                EnergyMode10
                                   capabilities:
                                     string_sensor:
                                         value:
                                   capabilities:
                                     string_sensor:
                                         value:
                                           expr: xK_Oven_State
                                   capabilities:
                                     string_sensor:
                                         value:
                                   capabilities:
                                     string_sensor:
                                         value:
                                HVACMode20
                                TEST100
                                   capabilities:
                                     - hvac_control
                                     - hvac_heating_unit
                                   template: Dimmer
                                   capabilities:
                                     - color_temperature
                                   template: Dimmer
                                   capabilities:
                                     string_sensor:
                                         value:
                                   capabilities:
                                     value_sensor:
                                         value:
                                   type: StringSensor
                                   capabilities:
                                     binary_sensor:
                                         state:
                                           expr:
                                   type: BinarySensor
                                   capabilities:
                                     value_sensor:
                                         value:
                                           if_expr: test
                                   capabilities:
                                     binary_sensor:
                                         state:
                                           expr:
                                END VIRTUAL DEVICE
                              #41
                              • id: testB_dynamic_vec
                                capabilities:
                                binary_sensor:
                                state:
                                expr:
                                type: BinarySensor
                              In this config, you are declaring binary_sensor as a capability, but then trying to set the primary attribute to state_sensor.value -- the capability state_sensor is not a Reactor-defined capability. That should be corrected.
                              I have other changes coming today to help examine the timer complaints. The logging issue seems like it should be more rare -- it's a race condition in the asynchronous writing of streams. I expect to see this messages occasionally, rarely (as I said), but in runs like you are getting is not cool, but I think it's induced by the timer complaint. Stay tuned.
                              Also, @noelab and @tunnus the log snippets you posted look heavily filtered. That removes important context, so please don't do that. I'd rather see one error message with full context than 20 with none.
                                Build 24133 userauth
                                • Force logging to be synchronous, to work around many long-standing issues with the naturally asynchronous nature of nodejs streams.
                                • Enhance diagnostic reporting for short timers (temporarily, in this branch only).
                                • Fix some issues with post-login redirection (if you were pushed to the login page by the dashboard or admin UI).
                                • VirtualEntityController: preserve attribute values if possible across system updates that affect capability definitions or implementations.
                                • DynamicGroupController: it is now possible to set the primary attribute of a dynamic group, and determine its value dynamically. Trivial example: add the binary_sensor.state attribute to a group to show true when any light in the group is on. Refer to the docs for DynamicGroupController.
                                • The dist-config directory is now copied to the user data virtual path target when running in docker containers so that its contents are more easily accessible to docker users.
                                • Fixed an issue in the core related to deleting certain objects (a Global Reaction was reported, but could have been many object types).
                                • Dashboard: further improvements to widget type guessing if we're not told by the entity configuration.
                                • Bring dist-config version of users.yaml into line with current reality.
                                • Fix the rpi-status.sh tool to work better with HTTPS enabled.
                                • HassController: Bless Hass to 2024.5.2
                                Note that this build incorporates all changes for userauth as well as latest branch changes not yet deployed for everyone else.
                                therealdbT tunnusT 2 Replies Last reply
                                  I'm not seeing 24133 userauth on your download portal....
                                    @toggledbits I think you also forgot to push userauth-amd64. thanks.
                                      Just quickly tested this and yes it says initializing search. I am using Safari
                                        #46
                                        @toggledbits can confirm that this new build (24133) fixes "delete problem", i.e. global reactions can now be deleted without them reappearing. Not seeing those "Reactor Log Panic" messages, but other errors:
                                        2024/05/13 18:51:08	stdout	    at async /opt/reactor/server/lib/Rule.js:885:17
                                        2024/05/13 18:51:08	stdout	    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                        2024/05/13 18:51:08	stdout	    at Rule._evaluate (/opt/reactor/server/lib/Rule.js:943:69)
                                        2024/05/13 18:51:08	stdout	    at Timer.delayms (/opt/reactor/server/lib/Timer.js:151:132)
                                        2024/05/13 18:51:08	stdout	    at Timer.at (/opt/reactor/server/lib/Timer.js:147:381)
                                        2024/05/13 18:51:08	stdout	Error: Delay Source Traceback
                                        2024/05/13 18:51:08	stdout	[userauth-24133]2024-05-13T15:51:08.837Z <Timer:CRIT> Error: Delay Source Traceback [-]
                                        2024/05/13 18:51:08	stdout	[userauth-24133]2024-05-13T15:51:08.837Z <Timer:null> Timer#rule-ktmrcd6d just a note: I'm setting a delay of only 8ms (from 1715615468837<5/13/2024, 6:51:08 PM> to 1715615468845<5/13/2024, 6:51:08 PM>)
                                        2024/05/13 18:51:00	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:51:00	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:50:03	stdout	[userauth-24133]2024-05-13T15:50:03.915Z <wsapi:CRIT> wsapi: client "172.18.0.1#5" sending authreq
                                        2024/05/13 18:50:02	stdout	[userauth-24133]2024-05-13T15:50:02.092Z <wsapi:CRIT> wsapi: client "172.18.0.1#4" sending authreq
                                        2024/05/13 18:49:33	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:49:33	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:48:15	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:48:15	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:47:07	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:47:07	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:46:29	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:46:29	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:46:25	stdout	    at async /opt/reactor/server/lib/Rule.js:885:17
                                        2024/05/13 18:46:25	stdout	    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                        2024/05/13 18:46:25	stdout	    at Rule._evaluate (/opt/reactor/server/lib/Rule.js:943:69)
                                        2024/05/13 18:46:25	stdout	    at Timer.delayms (/opt/reactor/server/lib/Timer.js:151:132)
                                        2024/05/13 18:46:25	stdout	    at Timer.at (/opt/reactor/server/lib/Timer.js:147:381)
                                        2024/05/13 18:46:25	stdout	Error: Delay Source Traceback
                                        2024/05/13 18:46:25	stdout	[userauth-24133]2024-05-13T15:46:25.384Z <Timer:CRIT> Error: Delay Source Traceback [-]
                                        2024/05/13 18:46:25	stdout	[userauth-24133]2024-05-13T15:46:25.384Z <Timer:null> Timer#rule-ktmrcd6d just a note: I'm setting a delay of only 8ms (from 1715615185384<5/13/2024, 6:46:25 PM> to 1715615185392<5/13/2024, 6:46:25 PM>)
                                        2024/05/13 18:45:10	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:45:10	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:44:15	stdout	    at async /opt/reactor/server/lib/Rule.js:885:17
                                        2024/05/13 18:44:15	stdout	    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                        2024/05/13 18:44:15	stdout	    at Rule._evaluate (/opt/reactor/server/lib/Rule.js:943:69)
                                        2024/05/13 18:44:15	stdout	    at Timer.delayms (/opt/reactor/server/lib/Timer.js:151:132)
                                        2024/05/13 18:44:15	stdout	    at Timer.at (/opt/reactor/server/lib/Timer.js:147:381)
                                        2024/05/13 18:44:15	stdout	Error: Delay Source Traceback
                                        2024/05/13 18:44:15	stdout	[userauth-24133]2024-05-13T15:44:15.282Z <Timer:CRIT> Error: Delay Source Traceback [-]
                                        2024/05/13 18:44:15	stdout	[userauth-24133]2024-05-13T15:44:15.281Z <Timer:null> Timer#rule-grp11myuubg just a note: I'm setting a delay of only 5ms (from 1715615055281<5/13/2024, 6:44:15 PM> to 1715615055286<5/13/2024, 6:44:15 PM>)
                                        2024/05/13 18:44:00	stdout	stream /var/reactor/logs/reactor.log not open boolean false
                                        2024/05/13 18:44:00	stdout	/var/reactor/logs/reactor.log size hit rotation limit, rotating
                                        2024/05/13 18:43:44	stdout	[userauth-24133]2024-05-13T15:43:44.182Z <wsapi:CRIT> wsapi: client "172.18.0.1#3" sending authreq
                                        2024/05/13 18:43:36	stdout	[userauth-24133]2024-05-13T15:43:36.850Z <wsapi:CRIT> wsapi: client "172.18.0.1#2" sending authreq
                                        2024/05/13 18:43:27	stdout	[userauth-24133]2024-05-13T15:43:27.574Z <default:null> Module NotifyTelegram v21221
                                        2024/05/13 18:43:27	stdout	[userauth-24133]2024-05-13T15:43:27.564Z <wsapi:CRIT> wsapi: client "172.18.0.1#1" sending authreq
                                        2024/05/13 18:43:27	stdout	[userauth-24133]2024-05-13T15:43:27.293Z <Notifier:null> Module Notifier v22283
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.989Z <SystemController:null> Module SystemController v24076
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.980Z <OWMWeatherController:null> Module OWMWeatherController v22294
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.893Z <HubitatController:null> Module HubitatController v24076
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.830Z <HassController:null> Module HassController v24128
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.526Z <MQTTController:null> Module MQTTController v24120
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.488Z <VirtualEntityController:null> Module VirtualEntityController v24117
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.431Z <VeraController:null> Module VeraController v24050
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.431Z <TaskQueue:null> Module TaskQueue 24113
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.416Z <InfluxFeed:null> Module InfluxFeed v23341
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.312Z <wsapi:null> Module wsapi v24115
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.284Z <httpapi:null> Module httpapi v24121
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.275Z <Engine:null> Module Engine v24113
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.273Z <GlobalReaction:null> Module GlobalReaction v24099
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.268Z <Rule:null> Module Rule v24115
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.265Z <AlertManager:null> Module AlertManager v24099
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.259Z <Predicate:null> Module Predicate v23093
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.243Z <GlobalExpression:null> Module GlobalExpression v24099
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.232Z <default:null> Module Rulesets v24099
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.231Z <default:null> Module Ruleset v24099
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.219Z <Controller:null> Module Controller v24099
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.215Z <Entity:null> Module Entity v24108
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.208Z <TimerBroker:null> Module TimerBroker v22283
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.180Z <Plugin:null> Module Plugin v22300
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.115Z <Capabilities:null> Module Capabilities v23331
                                        2024/05/13 18:43:21	stdout	[userauth-24133]2024-05-13T15:43:21.112Z <Structure:null> Module Structure v24110
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.999Z <app:null> Local date/time using configured timezone and locale formatting is "5/13/2024, 6:43:20 PM"
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.998Z <app:null> Loaded locale en-US for en-US
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.969Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.966Z <app:null> Resolved timezone=Europe/Helsinki, environment TZ=Europe/Helsinki; offset minutes from UTC=180
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.814Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.814Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.813Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined)
                                        2024/05/13 18:43:20	stdout	[userauth-24133]2024-05-13T15:43:20.770Z <app:null> Reactor build userauth-24133-a2bf8846 starting on v20.10.0 /usr/local/bin/node
                                        2024/05/13 18:43:20	stdout	NODE_PATH /opt/reactor:/opt/reactor/node_modules
                                        2024/05/13 18:43:20	stdout	Reactor userauth-24133-a2bf8846 app 24127 configuration from /var/reactor/config
                                        Also that manual/docs related problem ("initializing search") is still there, but that was expected as there were no mention of it being fixed.
                                          #47
                                          @tunnus The log snippets you are posting appear to be from something other than the log files produced by Reactor. This looks like console log for a container, and I'm not interested in looking at that, mostly because they are a limited subset of message severity and, as I said earlier, drop a lot of other context is valuable to me in evaluating what I'm seeing. Reactor produces its own log files for a reason. If you want to post snippets from that, with context in accordance with the posting guidelines, I'm ready to look at those any time.
                                            162.0k
