  4. [Solved] Entities error when updating MQTTController from 24120 to 24142
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
6 Posts 2 Posters 1.2k Views 2 Watching
    [Solution: Reactor 24115 is not compatible with MQTTController > 24120]
    Reactor latest-24115 bare metal.
    All MQTT entities stop working after updating MQTTController to 24142, downgrade to 24120 and they are back. Templates and configured entities has not been changed between versions.
    I'm not sure if uses_template should be replaced by ìnclude in entity configuration in reactor.yaml but I guess not, I've tried it and it did not do any difference.
    I have not tried to update Reactor to userauth version.
    Example entity in reactor.yaml that uses MQTTController included template:
    entities:
      "takflakt_kallare":
        topic: "Källartemp"
        unit: ""
        uses_template: tasmota_generic_relay
        init: "cmnd/%topic%/POWER%unit%"
    Any hints? Do you need more info, please let me know.
    Log from startup:
    [latest-24115]2024-05-28T14:42:35.995Z <app:null> Reactor build latest-24115-55b591da starting on v20.13.1
    [latest-24115]2024-05-28T14:42:35.996Z <app:null> Process ID 38403 user/group 1000/1000; bare-metal; platform linux/x64 #117-Ubuntu SMP Fri Apr 26 12:26:49 UTC 2024; locale sv_SE.utf8
    [latest-24115]2024-05-28T14:42:35.996Z <app:null> Basedir /home/homebridge/reactor; data in /home/homebridge/reactor/storage
    [latest-24115]2024-05-28T14:42:35.996Z <app:null> NODE_PATH=/home/homebridge/reactor
    [latest-24115]2024-05-28T14:42:36.010Z <app:null> Resolved timezone=Europe/Stockholm, environment TZ=(undefined); offset minutes from UTC=120
    [latest-24115]2024-05-28T14:42:36.012Z <app:null> Configured locale sv-SE; selected locale(s) sv-SE
    [latest-24115]2024-05-28T14:42:36.018Z <app:null> Loaded locale sv-SE for sv-SE
    [latest-24115]2024-05-28T14:42:36.018Z <app:null> Local date/time using configured timezone and locale formatting is "2024-05-28 16:42:36"
    [latest-24115]2024-05-28T14:42:36.020Z <Structure:null> Module Structure v24099
    [latest-24115]2024-05-28T14:42:36.021Z <Capabilities:null> Module Capabilities v23331
    [latest-24115]2024-05-28T14:42:36.028Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 24108 revision 1
    [latest-24115]2024-05-28T14:42:36.035Z <Plugin:null> Module Plugin v22300
    [latest-24115]2024-05-28T14:42:36.038Z <TimerBroker:null> Module TimerBroker v22283
    [latest-24115]2024-05-28T14:42:36.039Z <Entity:null> Module Entity v24108
    [latest-24115]2024-05-28T14:42:36.041Z <Controller:null> Module Controller v24099
    [latest-24115]2024-05-28T14:42:36.047Z <default:null> Module Ruleset v24099
    [latest-24115]2024-05-28T14:42:36.047Z <default:null> Module Rulesets v24099
    [latest-24115]2024-05-28T14:42:36.050Z <GlobalExpression:null> Module GlobalExpression v24099
    [latest-24115]2024-05-28T14:42:36.056Z <Predicate:null> Module Predicate v23093
    [latest-24115]2024-05-28T14:42:36.058Z <AlertManager:null> Module AlertManager v24099
    [latest-24115]2024-05-28T14:42:36.060Z <Rule:null> Module Rule v24115
    [latest-24115]2024-05-28T14:42:36.061Z <GlobalReaction:null> Module GlobalReaction v24099
    [latest-24115]2024-05-28T14:42:36.062Z <Engine:null> Module Engine v24099
    [latest-24115]2024-05-28T14:42:36.064Z <httpapi:null> Module httpapi v24099
    [latest-24115]2024-05-28T14:42:36.072Z <wsapi:null> Module wsapi v24115
    [latest-24115]2024-05-28T14:42:36.072Z <app:NOTICE> Starting Structure...
    [latest-24115]2024-05-28T14:42:36.075Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
    [latest-24115]2024-05-28T14:42:36.092Z <TaskQueue:null> Module TaskQueue 21351
    [latest-24115]2024-05-28T14:42:36.093Z <VeraController:null> Module VeraController v24050
    [latest-24115]2024-05-28T14:42:36.144Z <Structure:INFO> Structure#1 loading controller interface ezlo (EzloController)
    [latest-24115]2024-05-28T14:42:36.150Z <EzloController:null> Module EzloController v23345
    [latest-24115]2024-05-28T14:42:36.153Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
    [latest-24115]2024-05-28T14:42:36.155Z <DynamicGroupController:null> Module DynamicGroupController v22313
    [latest-24115]2024-05-28T14:42:36.159Z <Structure:INFO> Structure#1 loading controller interface virtual (VirtualEntityController)
    [latest-24115]2024-05-28T14:42:36.162Z <VirtualEntityController:null> Module VirtualEntityController v24076
    [latest-24115]2024-05-28T14:42:36.164Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
    [latest-24115]2024-05-28T14:42:36.168Z <HassController:null> Module HassController v24115
    [latest-24115]2024-05-28T14:42:36.217Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
    [latest-24115]2024-05-28T14:42:36.218Z <SystemController:null> Module SystemController v24076
    [latest-24115]2024-05-28T14:42:36.220Z <Structure:INFO> Structure#1 loading controller interface mosquitto-mqtt (MQTTController)
    [latest-24115]2024-05-28T14:42:36.223Z <MQTTController:null> Module MQTTController v24144
    [latest-24115]2024-05-28T14:42:36.252Z <Controller:INFO> Loaded MQTTController version "0.2.24144"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/MQTTController/
    [latest-24115]2024-05-28T14:42:36.263Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
    [latest-24115]2024-05-28T14:42:36.263Z <Controller:INFO> Loaded MQTTController version "0.2.24144"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/MQTTController/
    [latest-24115]2024-05-28T14:42:36.267Z <Structure:INFO> Starting controller VeraController#vera
    [latest-24115]2024-05-28T14:42:36.268Z <VeraController:NOTICE> VeraController#vera starting...
    [latest-24115]2024-05-28T14:42:36.270Z <Controller:INFO> VeraController#vera loaded vera capabilities ver 22253 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.283Z <Controller:INFO> VeraController#vera loaded implementation data ver 23109 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.283Z <Structure:INFO> Starting controller EzloController#ezlo
    [latest-24115]2024-05-28T14:42:36.284Z <Controller:INFO> EzloController#ezlo loaded ezlo capabilities ver 22266 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.288Z <Controller:INFO> EzloController#ezlo loaded implementation data ver 22344 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.288Z <Structure:INFO> Starting controller DynamicGroupController#groups
    [latest-24115]2024-05-28T14:42:36.290Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
    [latest-24115]2024-05-28T14:42:36.290Z <Structure:INFO> Starting controller VirtualEntityController#virtual
    [latest-24115]2024-05-28T14:42:36.291Z <Controller:INFO> VirtualEntityController#virtual loaded virtualentity capabilities ver 22263 rev 2 format 1
    [latest-24115]2024-05-28T14:42:36.291Z <Controller:INFO> VirtualEntityController#virtual loaded implementation data ver 22280 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.291Z <Structure:INFO> Starting controller HassController#hass
    [latest-24115]2024-05-28T14:42:36.291Z <HassController:NOTICE> HassController#hass starting...
    [latest-24115]2024-05-28T14:42:36.292Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23289 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.295Z <Controller:INFO> HassController#hass loaded implementation data ver 24004 rev 3 format 1
    [latest-24115]2024-05-28T14:42:36.295Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-24115]2024-05-28T14:42:36.296Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-24115]2024-05-28T14:42:36.337Z <Structure:INFO> Starting controller MQTTController#mosquitto-mqtt
    [latest-24115]2024-05-28T14:42:36.338Z <Controller:INFO> MQTTController#mosquitto-mqtt loaded mqtt capabilities ver 22353 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.338Z <Controller:INFO> MQTTController#mosquitto-mqtt loaded implementation data ver 24122 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.338Z <Structure:INFO> Starting controller MQTTController#mqtt
    [latest-24115]2024-05-28T14:42:36.338Z <MQTTController:WARN> mqtt_capabilities redefines existing x_mqtt
    [latest-24115]2024-05-28T14:42:36.338Z <MQTTController:WARN> mqtt_capabilities redefines existing x_mqtt_device
    [latest-24115]2024-05-28T14:42:36.338Z <Capabilities:INFO> [Capabilities][object Object] overriding capability x_mqtt
    [latest-24115]2024-05-28T14:42:36.339Z <Capabilities:INFO> [Capabilities][object Object] overriding capability x_mqtt_device
    [latest-24115]2024-05-28T14:42:36.339Z <Controller:INFO> MQTTController#mqtt loaded mqtt capabilities ver 22353 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.339Z <Controller:INFO> MQTTController#mqtt loaded implementation data ver 24122 rev 1 format 1
    [latest-24115]2024-05-28T14:42:36.341Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
    [latest-24115]2024-05-28T14:42:36.341Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
    [latest-24115]2024-05-28T14:42:36.342Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
    [latest-24115]2024-05-28T14:42:36.342Z <EzloController:WARN> EzloController: implementation of capability battery_maintenance does not provide attribute state
    [latest-24115]2024-05-28T14:42:36.343Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
    [latest-24115]2024-05-28T14:42:36.343Z <HassController:WARN> HassController: implementation of capability light_effect does not provide attribute speed
    [latest-24115]2024-05-28T14:42:36.344Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state
    [latest-24115]2024-05-28T14:42:36.344Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values
    [latest-24115]2024-05-28T14:42:36.355Z <EzloController:INFO> EzloController#ezlo: connecting to hub "xxxxxxxx" via anonymous local connection to wss://xxx.xxx.xxx.xxx
    [latest-24115]2024-05-28T14:42:36.358Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Dyr El (dyrEl)
    [latest-24115]2024-05-28T14:42:36.365Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Solar Production Forecast (solar_production_forecast)
    [latest-24115]2024-05-28T14:42:36.369Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged
    [latest-24115]2024-05-28T14:42:36.369Z <HassController:NOTICE> HassController#hass connecting to ws://xxx.xxx.xxx.xxx/api/websocket
    [latest-24115]2024-05-28T14:42:36.371Z <MQTTController:WARN> MQTTController#mqtt file my_tasmota_generic_relay.yaml in /home/homebridge/reactor/config/mqtt_templates/my_tasmota_generic_relay.yaml overrides existing template definition my
    [latest-24115]2024-05-28T14:42:36.372Z <MQTTController:WARN> MQTTController#mqtt file shelly_plug_s.yaml in /home/homebridge/reactor/config/mqtt_templates/shelly_plug_s.yaml overrides existing template definition shelly_plug_s
    [latest-24115]2024-05-28T14:42:36.372Z <MQTTController:WARN> MQTTController#mqtt file tasmota_sensor_lyw.yaml in /home/homebridge/reactor/config/mqtt_templates/tasmota_sensor_lyw.yaml overrides existing template definition tasmota_sensor
    _lyw
    [latest-24115]2024-05-28T14:42:36.372Z <MQTTController:WARN> MQTTController#mqtt file wallbox_pulsar_plus.yaml in /home/homebridge/reactor/config/mqtt_templates/wallbox_pulsar_plus.yaml overrides existing template definition wallbox_puls
    ar_plus
    [latest-24115]2024-05-28T14:42:36.372Z <MQTTController:WARN> MQTTController#mqtt file xiaofang_motion_light_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/xiaofang_motion_light_sensor.yaml overrides existing template defin
    ition xiaofang_motion_light_sensor
    [latest-24115]2024-05-28T14:42:36.374Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online.
    [latest-24115]2024-05-28T14:42:36.394Z <HassController:NOTICE> HassController#hass connected, starting protocol
    [latest-24115]2024-05-28T14:42:36.396Z <HassController:INFO> HassController#hass successful authentication with ws://xxx.xxx.xxx.xxx; fetching initial data...
    [latest-24115]2024-05-28T14:42:36.400Z <HassController:INFO> HassController#hass Hass reports version "2024.5.5" location Hem timezone Europe/Stockholm state RUNNING safe_mode false
    [latest-24115]2024-05-28T14:42:36.402Z <HassController:ERR> HassController#hass reported Hass version "2024.5.5" is not supported!
    [latest-24115]2024-05-28T14:42:36.403Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_control_outlet.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_trad
    fri.zip/zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_control_outlet.yaml overrides existing template definition zigbee2mqtt_tradfri_control_outlet
    [latest-24115]2024-05-28T14:42:36.405Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_light_bulb.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri.
    zip/zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_light_bulb.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb
    zip/zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_light_bulb.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_d
    [latest-24115]2024-05-28T14:42:36.416Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_supervisor_update
    [latest-24115]2024-05-28T14:42:36.417Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_core_update
    [latest-24115]2024-05-28T14:42:36.417Z <HassController:NOTICE> HassController#hass no signature match for update.terminal_ssh_update
    [latest-24115]2024-05-28T14:42:36.417Z <HassController:NOTICE> HassController#hass no signature match for update.esphome_update
    [latest-24115]2024-05-28T14:42:36.417Z <HassController:NOTICE> HassController#hass no signature match for update.file_editor_update
    [latest-24115]2024-05-28T14:42:36.418Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_operating_system_update
    [latest-24115]2024-05-28T14:42:36.418Z <HassController:NOTICE> HassController#hass no signature match for sun.sun
    [latest-24115]2024-05-28T14:42:36.420Z <HassController:NOTICE> HassController#hass no signature match for conversation.home_assistant
    [latest-24115]2024-05-28T14:42:36.420Z <HassController:NOTICE> HassController#hass no signature match for remote.samsung_vardagsrummet
    [latest-24115]2024-05-28T14:42:36.457Z <HassController:NOTICE> HassController#hass no signature match for update.infopanel_hall_firmware
    [latest-24115]2024-05-28T14:42:36.465Z <Controller:INFO> HassController#hass 0 dead entities older than 86400000s purged
    [latest-24115]2024-05-28T14:42:36.466Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradf
    ri.zip/zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_ws
    ri.zip/zigbee2mqtt_ikea_tradfri/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_ws_d
    [latest-24115]2024-05-28T14:42:36.466Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_door_sensor.yaml overrides existing temp
    late definition zigbee2mqtt_tuya_door_sensor
    [latest-24115]2024-05-28T14:42:36.467Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_tuya_light_bulb_rgbcw.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_light_bulb_rgbcw.yaml overrides exi
    sting template definition zigbee2mqtt_tuya_light_bulb_rgbcw
    [latest-24115]2024-05-28T14:42:36.467Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_tuya_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_occupancy_illuminance.yaml ove
    rrides existing template definition zigbee2mqtt_tuya_motion_light_sensor
    rrides existing template definition zigbee2mqtt_tuya_light_motion_sensor
    [latest-24115]2024-05-28T14:42:36.467Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_tuya_smart_plug_pm.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_smart_plug_pm.yaml overrides existing
    template definition zigbee2mqtt_tuya_smart_plug_pm
    [latest-24115]2024-05-28T14:42:36.528Z <Controller:INFO> VeraController#vera 0 dead entities older than 86400000s purged
    [latest-24115]2024-05-28T14:42:36.529Z <Controller:NOTICE> Controller VeraController#vera is now online.
    [latest-24115]2024-05-28T14:42:36.531Z <Controller:NOTICE> Controller HassController#hass is now online.
    [latest-24115]2024-05-28T14:42:36.533Z <EzloController:INFO> EzloController#ezlo: successful unauthenticated local connection to "xxxxxxx"
    [latest-24115]2024-05-28T14:42:36.534Z <EzloController:INFO> EzloController#ezlo starting hub inventory
    [latest-24115]2024-05-28T14:42:36.535Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_xiaomi_aqara_mini_switch.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_a
    qara_mini_switch.yaml overrides existing template definition zigbee2mqtt_aqara_mini_switch
    [latest-24115]2024-05-28T14:42:36.537Z <MQTTController:WARN> MQTTController#mosquitto-mqtt file zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqt
    t_xiaomi_aqara_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_aqara_motion_light_sensor
    t_xiaomi_aqara_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_aqara_light_motion_sensor
    [latest-24115]2024-05-28T14:42:36.538Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt
    [latest-24115]2024-05-28T14:42:36.540Z <MQTTController:ERR> MQTTController#mqtt error initializing entity takflakt_kallare: [TypeError] Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.540Z <MQTTController:CRIT> TypeError: Cannot read properties of undefined (reading 'length') [-]
        at MQTTController.start (/home/homebridge/reactor/config/ext/MQTTController/MQTTController.js:250:30)
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        at async Promise.allSettled (index 7)
    [latest-24115]2024-05-28T14:42:36.541Z <MQTTController:ERR> MQTTController#mqtt error initializing entity kaminflakt: [TypeError] Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.541Z <MQTTController:CRIT> TypeError: Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.542Z <MQTTController:ERR> MQTTController#mqtt error initializing entity kallartemp: [TypeError] Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.542Z <MQTTController:CRIT> TypeError: Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.543Z <MQTTController:ERR> MQTTController#mqtt error initializing entity fasadvedbod: [TypeError] Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.543Z <MQTTController:CRIT> TypeError: Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.544Z <MQTTController:ERR> MQTTController#mqtt error initializing entity fasadgarage: [TypeError] Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.544Z <MQTTController:CRIT> TypeError: Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.545Z <MQTTController:ERR> MQTTController#mqtt error initializing entity draneringspump: [TypeError] Cannot read properties of undefined (reading 'length') [-]
    [latest-24115]2024-05-28T14:42:36.545Z <MQTTController:CRIT> TypeError: Cannot read properties of undefined (reading 'length') [-]
    "same error for all configured MQTT entities"
    [latest-24115]2024-05-28T14:42:36.642Z <Controller:INFO> MQTTController#mosquitto-mqtt 0 dead entities older than 86400000s purged
    [latest-24115]2024-05-28T14:42:36.642Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt connecting to broker at mqtt://xxx.xxx.xxx.xxx/
    [latest-24115]2024-05-28T14:42:36.643Z <app:NOTICE> Starting HTTP server and API...
    [latest-24115]2024-05-28T14:42:36.645Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111
    [latest-24115]2024-05-28T14:42:36.647Z <app:NOTICE> Starting Reaction Engine...
    [latest-24115]2024-05-28T14:42:36.648Z <Engine:INFO> Reaction Engine starting
    [latest-24115]2024-05-28T14:42:36.648Z <Engine:INFO> Checking rule sets...
    [latest-24115]2024-05-28T14:42:36.649Z <Engine:INFO> Checking rules...
    [latest-24115]2024-05-28T14:42:36.692Z <Engine:INFO> Data check complete; no corrections.
      MQTTController build 24142 is intended to be used only with the userauth branch of Reactor, which is why I announced its availability there rather than in the general Announcements thread (but I see I probably should have been more clear about that).
      Downgrading MQTTController is the correct response.
      The userauth build has been folded into mainline development on my end and is ready to be released, I've just been really busy and have held off letting such a major build go out when I know I won't have time in the 48-72 hours after to address issues and help with upgrade questions. Hopefully, today wraps up my external dependencies and I can get a new latest build out tomorrow.
        Ah, that's my mistake then! I downloaded the wrong file and installed 24144 instead of 24142. Verified now and no issues with 24142.
          Correction, no errors in Reactor UI but same errors in logfile and entities not working...
            That makes sense, and I actually typo'd the version number in my post reply (now edited/corrected). Stay on 24120 until the new latest build comes out, and don't upgrade any templates from other developers if they are using new MQTTController features.
            Also, side note, the localization data/language file has been updated early in anticipation of the release.
              Understood! Reverted to 24120. All good.
              Thanks for the heads up on the localization file.
                116.7k
