  4. [Dev] Inheritance in MQTT templates?
40 Posts 4 Posters 14.9k Views 4 Watching
    Yes, yes, I've already looked at the definition in Github, I need you to be more specific. What are the names you redacted at Y in your previous post.
      @toggledbits oh, my bad. I'll try to re-pro again when home, but it should be x_energy_sensor_exported for Y and the device name for X.
        OK. That helps. And problem understood. I think I have an answer. New build later today.
          OK. MQTTController build 24144 up. Adds support for a capabilities section at the top level of any template file. Format is same as for system_capabilities.yaml. See MQTTController docs, updated.
            That’s huge! Thank you!
              Ok, version 24146 of my templates is now ready, refactored with this new feature and starting to include Shelly Gen 3 (I've also used a couple of system templates as base).
              The only minor thing is that if I have a primary_attribute defined in a template, MQTTController will not use the last one in the hierarchy, but the first one, and complain. Maybe just a brief note on the docs to highlight this.
                Quick question, looking at MQTTController integrated templates for Shelly, they are in separate files. Is it possible to define all these in one yaml file? Because I'm trying to do that for common Zigbee2MQTT capabilities and getting errors in the log that I can't figure out why. If not possible I get it but if it is possible I will elaborate my issue.
                  Yes, it's possible.
                    Yes, it's possible.
                    OK, here goes.
                    [1/2]
                    Reactor latest-24152 bare metal.
                    MQTTController 24144.
                    I can't figure this out
                    "MQTTController:CRIT ReferenceError: Capability string_sensor not extended (mosquitto-mqtt>sovrumsdorr [-]"
                    reactor.log
                    [latest-24152]2024-06-05T20:20:25.153Z <app:null> Reactor build latest-24152-3455578a starting on v20.13.1 /usr/local/bin/node
                    [latest-24152]2024-06-05T20:20:25.153Z <app:null> Process ID 317180 user/group 1000/1000; bare-metal; platform linux/x64 #117-Ubuntu SMP Fri Apr 26 12:26:49 UTC 2024; locale sv_SE.utf8
                    [latest-24152]2024-06-05T20:20:25.154Z <app:null> Basedir /home/homebridge/reactor; data in /home/homebridge/reactor/storage
                    [latest-24152]2024-06-05T20:20:25.154Z <app:null> NODE_PATH=/home/homebridge/reactor
                    [latest-24152]2024-06-05T20:20:25.169Z <app:null> Resolved timezone=Europe/Stockholm, environment TZ=(undefined); offset minutes from UTC=120
                    [latest-24152]2024-06-05T20:20:25.171Z <app:null> Configured locale sv-SE; selected locale(s) sv-SE
                    [latest-24152]2024-06-05T20:20:25.177Z <app:null> Loaded locale sv-SE for sv-SE
                    [latest-24152]2024-06-05T20:20:25.178Z <app:null> Local date/time using configured timezone and locale formatting is "2024-06-05 22:20:25"
                    [latest-24152]2024-06-05T20:20:25.180Z <Structure:null> Module Structure v24110
                    [latest-24152]2024-06-05T20:20:25.181Z <Capabilities:null> Module Capabilities v23331
                    [latest-24152]2024-06-05T20:20:25.191Z <Capabilities:NOTICE> System capabilities loaded from core distribution, data version 24108 revision 1
                    [latest-24152]2024-06-05T20:20:25.197Z <Plugin:null> Module Plugin v22300
                    [latest-24152]2024-06-05T20:20:25.214Z <TimerBroker:null> Module TimerBroker v22283
                    [latest-24152]2024-06-05T20:20:25.216Z <Entity:null> Module Entity v24138
                    [latest-24152]2024-06-05T20:20:25.218Z <Controller:null> Module Controller v24099
                    [latest-24152]2024-06-05T20:20:25.232Z <default:null> Module Ruleset v24099
                    [latest-24152]2024-06-05T20:20:25.232Z <default:null> Module Rulesets v24099
                    [latest-24152]2024-06-05T20:20:25.250Z <GlobalExpression:null> Module GlobalExpression v24099
                    [latest-24152]2024-06-05T20:20:25.275Z <Predicate:null> Module Predicate v23093
                    [latest-24152]2024-06-05T20:20:25.277Z <AlertManager:null> Module AlertManager v24099
                    [latest-24152]2024-06-05T20:20:25.278Z <Rule:null> Module Rule v24149
                    [latest-24152]2024-06-05T20:20:25.280Z <GlobalReaction:null> Module GlobalReaction v24099
                    [latest-24152]2024-06-05T20:20:25.289Z <Engine:null> Module Engine v24113
                    [latest-24152]2024-06-05T20:20:25.292Z <httpapi:null> Module httpapi v24148
                    [latest-24152]2024-06-05T20:20:25.298Z <wsapi:null> Module wsapi v24148
                    [latest-24152]2024-06-05T20:20:25.299Z <app:NOTICE> Starting Structure...
                    [latest-24152]2024-06-05T20:20:25.308Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
                    [latest-24152]2024-06-05T20:20:25.331Z <TaskQueue:null> Module TaskQueue 24138
                    [latest-24152]2024-06-05T20:20:25.332Z <VeraController:null> Module VeraController v24050
                    [latest-24152]2024-06-05T20:20:25.375Z <Structure:INFO> Structure#1 loading controller interface ezlo (EzloController)
                    [latest-24152]2024-06-05T20:20:25.381Z <EzloController:null> Module EzloController v23345
                    [latest-24152]2024-06-05T20:20:25.384Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                    [latest-24152]2024-06-05T20:20:25.386Z <DynamicGroupController:null> Module DynamicGroupController v24128
                    [latest-24152]2024-06-05T20:20:25.390Z <Structure:INFO> Structure#1 loading controller interface virtual (VirtualEntityController)
                    [latest-24152]2024-06-05T20:20:25.393Z <VirtualEntityController:null> Module VirtualEntityController v24147
                    [latest-24152]2024-06-05T20:20:25.395Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
                    [latest-24152]2024-06-05T20:20:25.399Z <HassController:null> Module HassController v24146
                    [latest-24152]2024-06-05T20:20:25.450Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                    [latest-24152]2024-06-05T20:20:25.452Z <SystemController:null> Module SystemController v24076
                    [latest-24152]2024-06-05T20:20:25.453Z <Structure:INFO> Structure#1 loading controller interface scheman (ScheduleController)
                    [latest-24152]2024-06-05T20:20:25.455Z <ScheduleController:null> Module ScheduleController v24097
                    [latest-24152]2024-06-05T20:20:25.455Z <Controller:INFO> Loaded ScheduleController version "0.1.24097"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com>
                    [latest-24152]2024-06-05T20:20:25.456Z <Structure:INFO> Structure#1 loading controller interface mosquitto-mqtt (MQTTController)
                    [latest-24152]2024-06-05T20:20:25.459Z <MQTTController:null> Module MQTTController v24144
                    [latest-24152]2024-06-05T20:20:25.491Z <Controller:INFO> Loaded MQTTController version "0.2.24144"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/MQTTController/
                    [latest-24152]2024-06-05T20:20:25.503Z <Structure:INFO> Structure#1 loading controller interface mqtt (MQTTController)
                    [latest-24152]2024-06-05T20:20:25.503Z <Controller:INFO> Loaded MQTTController version "0.2.24144"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/MQTTController/
                    [latest-24152]2024-06-05T20:20:25.507Z <Structure:INFO> Starting controller VeraController#vera
                    [latest-24152]2024-06-05T20:20:25.507Z <VeraController:NOTICE> VeraController#vera starting...
                    [latest-24152]2024-06-05T20:20:25.510Z <Controller:INFO> VeraController#vera loaded vera capabilities ver 22253 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.521Z <Controller:INFO> VeraController#vera loaded implementation data ver 23109 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.521Z <Structure:INFO> Starting controller EzloController#ezlo
                    [latest-24152]2024-06-05T20:20:25.523Z <Controller:INFO> EzloController#ezlo loaded ezlo capabilities ver 22266 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.528Z <Controller:INFO> EzloController#ezlo loaded implementation data ver 22344 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.528Z <Structure:INFO> Starting controller DynamicGroupController#groups
                    [latest-24152]2024-06-05T20:20:25.530Z <Controller:NOTICE> Controller DynamicGroupController#groups is now online.
                    [latest-24152]2024-06-05T20:20:25.530Z <Structure:INFO> Starting controller VirtualEntityController#virtual
                    [latest-24152]2024-06-05T20:20:25.531Z <Controller:INFO> VirtualEntityController#virtual loaded virtualentity capabilities ver 22263 rev 2 format 1
                    [latest-24152]2024-06-05T20:20:25.532Z <Controller:INFO> VirtualEntityController#virtual loaded implementation data ver 22280 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.532Z <Structure:INFO> Starting controller HassController#hass
                    [latest-24152]2024-06-05T20:20:25.532Z <HassController:NOTICE> HassController#hass starting...
                    [latest-24152]2024-06-05T20:20:25.533Z <Controller:INFO> HassController#hass loaded hass capabilities ver 23289 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.536Z <Controller:INFO> HassController#hass loaded implementation data ver 24146 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.536Z <Structure:INFO> Starting controller SystemController#reactor_system
                    [latest-24152]2024-06-05T20:20:25.537Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
                    [latest-24152]2024-06-05T20:20:25.580Z <Structure:INFO> Starting controller ScheduleController#scheman
                    [latest-24152]2024-06-05T20:20:25.580Z <ScheduleController:INFO> ScheduleController#scheman Sun Information entity is reactor_system>sun
                    [latest-24152]2024-06-05T20:20:25.582Z <Controller:NOTICE> Controller ScheduleController#scheman is now online.
                    [latest-24152]2024-06-05T20:20:25.582Z <Structure:INFO> Starting controller MQTTController#mosquitto-mqtt
                    [latest-24152]2024-06-05T20:20:25.583Z <Controller:INFO> MQTTController#mosquitto-mqtt loaded mqtt capabilities ver 22353 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.583Z <Controller:INFO> MQTTController#mosquitto-mqtt loaded implementation data ver 24122 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.583Z <Structure:INFO> Starting controller MQTTController#mqtt
                    [latest-24152]2024-06-05T20:20:25.583Z <MQTTController:WARN> mqtt_capabilities redefines existing x_mqtt
                    [latest-24152]2024-06-05T20:20:25.584Z <MQTTController:WARN> mqtt_capabilities redefines existing x_mqtt_device
                    [latest-24152]2024-06-05T20:20:25.584Z <Capabilities:INFO> [Capabilities][object Object] overriding capability x_mqtt
                    [latest-24152]2024-06-05T20:20:25.584Z <Capabilities:INFO> [Capabilities][object Object] overriding capability x_mqtt_device
                    [latest-24152]2024-06-05T20:20:25.584Z <Controller:INFO> MQTTController#mqtt loaded mqtt capabilities ver 22353 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.584Z <Controller:INFO> MQTTController#mqtt loaded implementation data ver 24122 rev 1 format 1
                    [latest-24152]2024-06-05T20:20:25.587Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
                    [latest-24152]2024-06-05T20:20:25.587Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
                    [latest-24152]2024-06-05T20:20:25.588Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
                    [latest-24152]2024-06-05T20:20:25.588Z <EzloController:WARN> EzloController: implementation of capability battery_maintenance does not provide attribute state
                    [latest-24152]2024-06-05T20:20:25.589Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
                    [latest-24152]2024-06-05T20:20:25.602Z <EzloController:INFO> EzloController#ezlo: connecting to hub "xxxxxx" via anonymous local connection to wss://xxx.xxx.xxx.xxx
                    [latest-24152]2024-06-05T20:20:25.605Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Dyr El (dyrEl)
                    [latest-24152]2024-06-05T20:20:25.612Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Solar Production Forecast (solar_production_forecast)
                    [latest-24152]2024-06-05T20:20:25.617Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged
                    [latest-24152]2024-06-05T20:20:25.617Z <HassController:NOTICE> HassController#hass connecting to ws://xxx.xxx.xxx.xxx/api/websocket
                    [latest-24152]2024-06-05T20:20:25.622Z <MQTTController:WARN> MQTTController#mqtt file my_tasmota_generic_relay.yaml in /home/homebridge/reactor/config/mqtt_templates/my_tasmota_generic_relay.yaml overrides existing template definition my_tasmota_generic_relay
                    [latest-24152]2024-06-05T20:20:25.622Z <MQTTController:WARN> MQTTController#mqtt file shelly_plug_s.yaml in /home/homebridge/reactor/config/mqtt_templates/shelly_plug_s.yaml overrides existing template definition shelly_plug_s
                    [latest-24152]2024-06-05T20:20:25.622Z <MQTTController:WARN> MQTTController#mqtt file tasmota_sensor_lyw.yaml in /home/homebridge/reactor/config/mqtt_templates/tasmota_sensor_lyw.yaml overrides existing template definition tasmota_sensor_lyw
                    [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file wallbox_pulsar_plus.yaml in /home/homebridge/reactor/config/mqtt_templates/wallbox_pulsar_plus.yaml overrides existing template definition wallbox_pulsar_plus
                    [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file xiaofang_motion_light_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/xiaofang_motion_light_sensor.yaml overrides existing template definition xiaofang_motion_light_sensor
                    [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_availability
                    [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_availability_no_get
                    [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_lqi
                    [latest-24152]2024-06-05T20:20:25.623Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_ota
                    [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_power_switch
                    [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_dimming
                    [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_common.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml overrides existing template definition zigbee2mqtt_battery_power
                    [latest-24152]2024-06-05T20:20:25.624Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_control_outlet.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_control_outlet.yaml overrides existing template definition zigbee2mqtt_tradfri_control_outlet
                    [latest-24152]2024-06-05T20:20:25.625Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb
                    [latest-24152]2024-06-05T20:20:25.625Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_d
                    [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_ws
                    [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_ikea_tradfri_light_bulb_ws.yaml overrides existing template definition zigbee2mqtt_tradfri_light_bulb_ws_d
                    [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_door_sensor.yaml overrides existing template definition zigbee2mqtt_tuya_door_sensor
                    [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_light_bulb_rgbcw.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_light_bulb_rgbcw.yaml overrides existing template definition zigbee2mqtt_tuya_light_bulb_rgbcw
                    [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_tuya_motion_light_sensor
                    [latest-24152]2024-06-05T20:20:25.626Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_tuya_light_motion_sensor
                    [latest-24152]2024-06-05T20:20:25.627Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_smart_plug_pm.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_smart_plug_pm.yaml overrides existing template definition zigbee2mqtt_tuya_smart_plug_pm
                    [latest-24152]2024-06-05T20:20:25.628Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online.
                    [latest-24152]2024-06-05T20:20:25.642Z <ScheduleController:INFO> ScheduleController#scheman entity ValueSensor#scheman>weekends edge "22:00" active, setting primary attribute value to natt
                    [latest-24152]2024-06-05T20:20:25.651Z <HassController:NOTICE> HassController#hass connected, starting protocol
                    [latest-24152]2024-06-05T20:20:25.654Z <HassController:INFO> HassController#hass successful authentication with ws://xxx.xxx.xxx.xxx; fetching initial data...
                    [latest-24152]2024-06-05T20:20:25.658Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_mini_switch.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_mini_switch.yaml overrides existing template definition zigbee2mqtt_aqara_mini_switch
                    [latest-24152]2024-06-05T20:20:25.658Z <HassController:INFO> HassController#hass Hass reports version "2024.5.5" location Hem timezone Europe/Stockholm state RUNNING safe_mode false
                    [latest-24152]2024-06-05T20:20:25.661Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_aqara_motion_light_sensor
                    [latest-24152]2024-06-05T20:20:25.661Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_occupancy_illuminance.yaml overrides existing template definition zigbee2mqtt_aqara_light_motion_sensor
                    [latest-24152]2024-06-05T20:20:25.664Z <MQTTController:INFO> MQTTController#mosquitto-mqtt instance topic ident is mosquitto-mqtt
                    [latest-24152]2024-06-05T20:20:25.669Z <Controller:INFO> MQTTController#mosquitto-mqtt 0 dead entities older than 86400000s purged
                    [latest-24152]2024-06-05T20:20:25.669Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt connecting to broker at mqtt://127.0.0.1:1885/
                    [latest-24152]2024-06-05T20:20:25.686Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml overrides existing template definition zigbee2mqtt_aqara_sensor_temperature_humidity
                    [latest-24152]2024-06-05T20:20:25.686Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_xiaomi_aqara.zip/zigbee2mqtt_xiaomi_aqara_temperature_humidity.yaml overrides existing template definition zigbee2mqtt_aqara_sensor_humidity_temperature
                    [latest-24152]2024-06-05T20:20:25.687Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt
                    [latest-24152]2024-06-05T20:20:25.689Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged
                    [latest-24152]2024-06-05T20:20:25.689Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://127.0.0.1:1888/
                    [latest-24152]2024-06-05T20:20:25.690Z <app:NOTICE> Starting HTTP server and API...
                    [latest-24152]2024-06-05T20:20:25.692Z <httpapi:NOTICE> [HTTPAPI]#1 starting HTTP service on port 8111
                    [latest-24152]2024-06-05T20:20:25.695Z <app:NOTICE> Starting Reaction Engine...
                    [latest-24152]2024-06-05T20:20:25.695Z <Engine:INFO> Reaction Engine starting
                    [latest-24152]2024-06-05T20:20:25.696Z <Engine:INFO> Checking rule sets...
                    [latest-24152]2024-06-05T20:20:25.697Z <Engine:INFO> Checking rules...
                    [latest-24152]2024-06-05T20:20:25.750Z <Engine:INFO> Data check complete; no corrections.
                    --- Rules redacted to posting limits
                    [latest-24152]2024-06-05T20:20:25.883Z <httpapi:NOTICE> [HTTPAPI]#1 HTTP server listening on "0.0.0.0":8111
                    [latest-24152]2024-06-05T20:20:25.896Z <httpapi:INFO> [HTTPAPI]#1 local docs found in /home/homebridge/reactor/docs/html; setting up static service
                    [latest-24152]2024-06-05T20:20:25.897Z <app:NOTICE> Starting WSAPI...
                    [latest-24152]2024-06-05T20:20:25.898Z <wsapi:NOTICE> wsapi: starting version 24148
                    [latest-24152]2024-06-05T20:20:25.919Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "2024-06-05 22:20:25" (TZ offset 120 mins from UTC)
                    [latest-24152]2024-06-05T20:20:25.966Z <Controller:INFO> VeraController#vera 0 dead entities older than 86400000s purged
                    [latest-24152]2024-06-05T20:20:25.968Z <Controller:NOTICE> Controller VeraController#vera is now online.
                    [latest-24152]2024-06-05T20:20:25.973Z <MQTTController:INFO> MQTTController#mosquitto-mqtt connected; opening subscriptions
                    [latest-24152]2024-06-05T20:20:25.978Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_supervisor_update
                    [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_core_update
                    [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.terminal_ssh_update
                    [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.esphome_update
                    [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.file_editor_update
                    [latest-24152]2024-06-05T20:20:25.979Z <HassController:NOTICE> HassController#hass no signature match for update.home_assistant_operating_system_update
                    [latest-24152]2024-06-05T20:20:25.980Z <HassController:NOTICE> HassController#hass no signature match for conversation.home_assistant
                    [latest-24152]2024-06-05T20:20:25.980Z <HassController:NOTICE> HassController#hass no signature match for sun.sun
                    [latest-24152]2024-06-05T20:20:25.982Z <HassController:NOTICE> HassController#hass no signature match for remote.samsung_vardagsrummet
                    [latest-24152]2024-06-05T20:20:26.005Z <HassController:NOTICE> HassController#hass no signature match for update.infopanel_hall_firmware
                    [latest-24152]2024-06-05T20:20:26.009Z <Controller:INFO> HassController#hass 0 dead entities older than 86400000s purged
                    [latest-24152]2024-06-05T20:20:26.020Z <MQTTController:INFO> MQTTController#mosquitto-mqtt sending inits and going online!
                    [latest-24152]2024-06-05T20:20:26.021Z <Controller:NOTICE> Controller MQTTController#mosquitto-mqtt is now online.
                    [latest-24152]2024-06-05T20:20:26.025Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyix3-98CDAC2F5883/online) for ljussensor
                    [latest-24152]2024-06-05T20:20:26.026Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyplug-s-80646F811E35/online) for server
                    [latest-24152]2024-06-05T20:20:26.029Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending shellies/shellyplug-s-80646F811E35/command with 6 byte payload to server
                    [latest-24152]2024-06-05T20:20:26.033Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending shellies/shellyuni-C45BBE6C6DE8/command with 6 byte payload to poolvarmepump
                    [latest-24152]2024-06-05T20:20:26.034Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Datarummet/get with 12 byte payload to datarummet
                    [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Sovrummet/get with 12 byte payload to sovrummet
                    [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Milia/get with 12 byte payload to milia
                    [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Hallen 1/get with 12 byte payload to hallen1
                    [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Hallen 2/get with 12 byte payload to hallen2
                    [latest-24152]2024-06-05T20:20:26.035Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Hallen 3/get with 12 byte payload to hallen3
                    [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Fönster köket/get with 12 byte payload to fonster_koket
                    [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Soffan/get with 12 byte payload to soffan
                    [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Framsida/get with 12 byte payload to framsida
                    [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Skänk/get with 12 byte payload to skank
                    [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Baksida/get with 12 byte payload to baksida
                    [latest-24152]2024-06-05T20:20:26.036Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa spel/get with 12 byte payload to lampa_spel
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Ellas rum/get with 12 byte payload to lampa_ella
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa gym/get with 12 byte payload to lampa_gym
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa TV/get with 12 byte payload to lampa_tv
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Vitrinskåp/get with 12 byte payload to vitrinskap
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending shellies/shelly1-34945471EBCF/relay/0/command with 6 byte payload to vvb
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Framsida/get with 12 byte payload to jul_framsida
                    [latest-24152]2024-06-05T20:20:26.037Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Köket/get with 12 byte payload to jul_köket
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Sovrummet/get with 12 byte payload to jul_sovrummet
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Jul Datarummet/get with 12 byte payload to jul_datarummet
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Element gillestugan/get with 12 byte payload to element_gillestugan
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Växtbelysning källare/get with 12 byte payload to vaxtbelysning_kallare
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Kompressor/get with 12 byte payload to kompressor
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Luftrenare/get with 12 byte payload to luftrenare
                    [latest-24152]2024-06-05T20:20:26.038Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Uttag uterummet/get with 12 byte payload to uttag_uterummet
                    [latest-24152]2024-06-05T20:20:26.039Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Entrebelysning/get with 12 byte payload to entrebelysning
                    [latest-24152]2024-06-05T20:20:26.039Z <MQTTController:INFO> MQTTController#mosquitto-mqtt x_mqtt_device.poll action sending zigbee2mqtt/Lampa uterummet/get with 12 byte payload to lampa_uterummet
                    [latest-24152]2024-06-05T20:20:26.050Z <Controller:NOTICE> Controller HassController#hass is now online.
                    [latest-24152]2024-06-05T20:20:26.051Z <MQTTController:INFO> MQTTController#mqtt connected; opening subscriptions
                    [latest-24152]2024-06-05T20:20:26.062Z <MQTTController:ERR> MQTTController#mosquitto-mqtt event handler failed for zigbee2mqtt/Rörelse förrådet on rorelse_forradet: [ReferenceError] Capability string_sensor not extended (mosquitto-mqtt>rorelse_forradet [-]
                    [latest-24152]2024-06-05T20:20:26.062Z <MQTTController:CRIT> ReferenceError: Capability string_sensor not extended (mosquitto-mqtt>rorelse_forradet [-]
                        at Entity.setAttribute (/home/homebridge/reactor/server/lib/Entity.js:465:19)
                        at MQTTController.handle_event (/home/homebridge/reactor/config/ext/MQTTController/MQTTController.js:1240:19)
                        at MqttClient.<anonymous> (/home/homebridge/reactor/config/ext/MQTTController/MQTTController.js:591:38)
                        at MqttClient.emit (node:events:519:28)
                        at MqttClient.emit (node:domain:488:12)
                        at MqttClient._handlePublish (/home/homebridge/reactor/config/ext/MQTTController/node_modules/mqtt/lib/client.js:1551:12)
                        at MqttClient._handlePacket (/home/homebridge/reactor/config/ext/MQTTController/node_modules/mqtt/lib/client.js:533:12)
                        at work (/home/homebridge/reactor/config/ext/MQTTController/node_modules/mqtt/lib/client.js:436:12)
                        at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
                    [latest-24152]2024-06-05T20:20:26.063Z <MQTTController:ERR> MQTTController#mosquitto-mqtt event handler failed for zigbee2mqtt/Sovrumsdörr on sovrumsdorr: [ReferenceError] Capability string_sensor not extended (mosquitto-mqtt>sovrumsdörr [-]
                    [latest-24152]2024-06-05T20:20:26.063Z <MQTTController:CRIT> ReferenceError: Capability string_sensor not extended (mosquitto-mqtt>sovrumsdorr [-]
                    [latest-24152]2024-06-05T20:20:26.071Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyuni-C45BBE6C6DE8/online) for poolvarmepump
                    [latest-24152]2024-06-05T20:20:26.072Z <MQTTController:NOTICE> MQTTController#mosquitto-mqtt received LWT (shellies/shellyplug-s-80646F811E35/online) for server
                    [latest-24152]2024-06-05T20:20:26.074Z <MQTTController:INFO> MQTTController#mqtt sending inits and going online!
                    [latest-24152]2024-06-05T20:20:26.075Z <Controller:NOTICE> Controller MQTTController#mqtt is now online.
                    reactor.yaml
                    "sovrumsdorr":
                      topic: "Sovrumsdörr"
                      include: zigbee2mqtt_tuya_door_sensor
                      OK, here goes.
                      [1/2]
                      reactor.log
                      reactor.yaml
                      "sovrumsdorr":
                      [2/2]
                      # Requires: "topic".
                      # Optional: "prefix" (default: zigbee2mqtt).
                      # mqtt_device.online requires "availability: true" in Zigbee2MQTT config.
                      # https://www.zigbee2mqtt.io/guide/configuration/device-availability.html
                      description: "Zigbee2MQTT base templates"
                      author: "@Crille, Smart Home Community"
                      license: MIT
                      repository: "https://github.com/calmen77/MSR-mqtt_templates"
                      version: 24155
                      templates:
                        # Availability with query
                        zigbee2mqtt_availability:
                          capabilities: [x_mqtt_device]
                          requires: [topic]
                          query:
                            topic: "%prefix:zigbee2mqtt%/%topic%/get"
                            payload:
                              state: ""
                            type: json
                          events:
                            "%prefix:zigbee2mqtt%/%topic%/availability":
                              "x_mqtt_device.online":
                                if_expr: '! isnull(payload)'
                                expr: 'lower(payload) == "online"'
                        # Availability without query for device not supporting /get
                        zigbee2mqtt_availability_no_get:
                          requires: [topic]
                          events:
                        # Link quality in lqi
                        zigbee2mqtt_lqi:
                          capabilities: [value_sensor]
                          requires: [topic]
                          events:
                            "%prefix:zigbee2mqtt%/%topic%":
                              "value_sensor.value":
                                json_payload: true
                                expr: 'payload.linkquality'
                              "value_sensor.units": "lqi"
                      # String sensor for available OTA update for device
                        zigbee2mqtt_ota:
                          capabilities: [string_sensor]
                          requires: [topic]
                          events:
                              "string_sensor.value":
                                json_payload: true
                                expr: 'payload?.update_available ? "OTA firmware update available!" : "no update available"'
                        # Power switch capability
                        zigbee2mqtt_power_switch:
                          capabilities:
                            - power_switch
                            - toggle
                          requires: [topic]
                          events:
                              "power_switch.state":
                                json_payload: true
                                expr: 'payload?.state == "ON"'
                          actions:
                            power_switch:
                              "on":
                                topic: "%prefix:zigbee2mqtt%/%topic%/set"
                                payload: "ON"
                              "off":
                                payload: "OFF"
                              set:
                                payload:
                                  expr: "parameters.state ? 'on' : 'off'"
                                  type: raw
                        # Dimming capability
                        zigbee2mqtt_dimming:
                          capabilities: [dimming]
                          requires: [topic]
                          events:
                              "dimming.level":
                                json_payload: true
                                expr: 'round(payload?.brightness / 100 / 2.55 , 2)'
                          actions:
                            dimming:
                              set:
                                payload:
                                  expr: '{"brightness": round(parameters.level * 100 * 2.55 , 2)}'
                                  type: json
                        # Battery level
                        zigbee2mqtt_battery_power:
                          capabilities: [battery_power]
                          requires: [topic]
                          events:
                              "battery_power.level":
                                json_payload: true
                                expr: 'payload?.battery / 100'
                              "battery_power.since":
                                expr: 'time()'
                          actions:
                            x_mqtt_device:
                              poll: false
                      # https://www.zigbee2mqtt.io/devices/SNZB-04.html
                      description: "Zigbee2MQTT template for TuYa Smart Door Sensor."
                      license: MIT
                      version: 24155
                      templates:
                        zigbee2mqtt_tuya_door_sensor:
                          #type:
                          capabilities:
                            - door_sensor
                          primary_attribute: door_sensor.state
                          requires: [topic]
                          include:
                            - zigbee2mqtt_availability_no_get
                            - zigbee2mqtt_lqi
                            - zigbee2mqtt_battery_power
                          events:
                              "door_sensor.state":
                                json_payload: true
                                expr: 'payload?.contact'
                        Turn debug level 5 on for MQTTController. It will show you how it's loading the templates and building the final entity configuration. The message fragment you'll want to look for is merged template for sovrumsdorr... then work backwards in the log from there to configuring entity sovrumsdorr. Everything in between is the setup.
                        Also examine the debug messages at startup for where it's finding templates and loading them... make sure everything it's loading is what's intended, and you don't have a stray old file sitting around somewhere that it's sucking in.
                        Edit: your logs are showing a lot of duplicate definitions in the startup messages...
                          It seems to merge the events: section of string_sensor and power_switch in ...common.yaml and wrap value_sensor.units in string_sensor capability.
                          I've looked for strange characters that could cause it but found nothing, validated all files OK in yamllint.
                          [latest-24152]2024-06-06T06:29:11.699Z <MQTTController:5:MQTTController.js:146> MQTTController#mosquitto-mqtt configuring entity sovrumsdorr
                          [latest-24152]2024-06-06T06:29:11.699Z <MQTTController:5:MQTTController.js:205> MQTTController#mosquitto-mqtt merged template for sovrumsdorr (from /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml/zigbee2mqtt_common.yaml):
                              "capabilities": [
                                  "door_sensor",
                                  "x_mqtt_device",
                                  "value_sensor",
                                  "battery_power"
                              "primary_attribute": "door_sensor.state",
                              "requires": [
                                  "topic"
                              "include": [
                                  "zigbee2mqtt_availability_no_get",
                                  "zigbee2mqtt_lqi",
                                  "zigbee2mqtt_battery_power",
                                  "zigbee2mqtt_tuya_door_sensor"
                              "events": {
                                  "%prefix:zigbee2mqtt%/%topic%": {
                                      "door_sensor.state": {
                                          "json_payload": true,
                                          "expr": "payload?.contact"
                                      "value_sensor.value": {
                                          "if_expr": "! isnull(payload)",
                                          "expr": "payload.linkquality",
                                          "attribute": "value_sensor.value"
                                      "value_sensor.units": "lqi",
                                      "string_sensor.value": {
                                          "expr": "payload?.update_available ? \"OTA firmware update available!\" : \"no update available\"",
                                          "attribute": "string_sensor.value"
                                      "power_switch.state": {
                                          "expr": "payload?.state == \"ON\"",
                                          "attribute": "power_switch.state"
                                      "battery_power.level": {
                                          "expr": "payload?.battery / 100",
                                          "attribute": "battery_power.level"
                                      "battery_power.since": {
                                          "expr": "time()",
                                          "attribute": "battery_power.since"
                                  "%prefix:zigbee2mqtt%/%topic%/availability": {
                                      "x_mqtt_device.online": {
                                          "expr": "lower(payload) == \"online\"",
                                          "attribute": "x_mqtt_device.online"
                              "__source": "/home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_common.yaml/zigbee2mqtt_common.yaml",
                              "actions": {
                                  "x_mqtt_device": {
                                      "poll": false
                              "name": "Sovrumsdörr",
                              "topic": "Sovrumsdörr"
                          [latest-24152]2024-06-06T06:29:11.699Z <MQTTController:5:MQTTController.js:264> MQTTController#mosquitto-mqtt set primary attribute of door_sensor.state to Entity#mosquitto-mqtt>sovrumsdorr
                          [latest-24152]2024-06-06T06:29:11.700Z <MQTTController:5:MQTTController.js:289> MQTTController#mosquitto-mqtt registering event handler %prefix:zigbee2mqtt%/%topic% for sovrumsdorr
                          [latest-24152]2024-06-06T06:29:11.700Z <MQTTController:5:MQTTController.js:289> MQTTController#mosquitto-mqtt registering event handler %prefix:zigbee2mqtt%/%topic%/availability for sovrumsdorr
                          [latest-24152]2024-06-06T06:29:11.700Z <MQTTController:5:MQTTController.js:368> MQTTController#mosquitto-mqtt registering action x_mqtt_device.poll for sovrumsdorr
                          Regarding the duplicates, it could be the templates with different primary_attribute: and it is on my roadmap to bring it up for discussion if attributes also could be parameterized with defaults like %primary_attribute:[temperature / humidity / power_switch / dimming / motion / light]% or %temperature_sensor.units:[C / F]%.
                          EDIT: Or is caused by the mystery of this issue? e.g. string_sensor and power_switch is somehow included in all templates.
                            @Crille at some point I had similar problems, I fixed them and I reported here. Now I cannot repro it again, but it seems very similar and related to primary attributes in base templates. It seems like the first one is used and that’s causing troubles along the hierarchy, but, as I said, I’m not able to repro it again.
                              It also looks like something may be getting a shallow copy when it needs a deep copy, and it's being modified later and polluting the other references. I'm really tied up today, but I'll look at this as soon as I can.
                              Did you address the template redefinitions that were being logged at startup? That has nothing to do with primary attributes; the entire template is trying to be redefined.
                                No rush!
                                @toggledbits said in [Dev] Inheritance in MQTT templates?:
                                You mean this?
                                If so I don't know what to do about it, it's just the template provided in my earlier post and there is no reference/copy of it in the reactor folder/subfolders that I know of.
                                  With debug level 5, that message will have another message that follows it to tell you what file originally defined it.
                                    This?
                                    [latest-24152]2024-06-06T19:29:35.079Z <MQTTController:5:MQTTController.js:941> MQTTController#mqtt loading template defs, considering zigbee2mqtt_tuya_door_sensor.yaml
                                    [latest-24152]2024-06-06T19:29:35.079Z <MQTTController:5:MQTTController.js:987> MQTTController#mqtt loading YAML template data from /home/homebridge/reactor/config/mqtt_templates/zigbee2mqt
                                    [latest-24152]2024-06-06T19:29:35.080Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_do
                                    [latest-24152]2024-06-06T19:29:35.080Z <MQTTController:5:MQTTController.js:918> MQTTController#mqtt previously defined in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_doo
                                    r_sensor.yaml/zigbee2mqtt_tuya_door_sensor.yaml
                                      Uh yes... 😆
                                      Digging in now...
                                        I need the config for all of your zigbee2mqtt-related entities. Just looking at the one sovrumsdorr, I'm not able to reproduce the problem.
                                          Config as in reactor.yaml?
                                            1.0k
                                            157.4k
