  4. JSON payload in MQTTController entities actions (+ reverse color mapping to RGB)
DynamicGroupController updating members issue
Bare-metal latest-26193 I have this group: "OKforLarm": name: OK för Larm select: - include_controller: vera - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state It contains the entities I expect but behaves a bit odd. When I open vera>device_10097 the entity attribute door_sensor.state changes to true but it won't show up as member in the group, when I also open vera>device_10095 they both shows as members and when I close vera>device_10095 it disappear from the group but when I close vera>device_10097 it lingers in the group until I restart Reactor.
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
9 Posts 4 Posters 2.5k Views 4 Watching
    Some background
    I'm trying to integrate a Zigbee device into the MSR using zigbee2mqtt bridge and MQTTController. The device in question is a cheap mood light that has following properties that I'd like to control:
    • switch (on/off)
    • brightness
    • color
    I'v already managed to get the switch part working and can toggle the light on/off. Also the brightness value is mapped back to MSR. In zigbee2mqtt it has a value range from 0 to 254, so this the reason for the expression:
    expr: 'payload.brightness / 254'
    Here's the entity definition (don't know whether the type should be something else than the Switch)
    zigbee-lidl-mood-light:
      name: 'Lidl Mood Light'
      friendly_name: 'Mood Light'
      type: Switch
      uses_template: lidl-moodlight
    And the corresponding template (NOTE: rgb_color has not been defined in this example):
    lidl-moodlight:
      init: "zigbee2mqtt/%friendly_name%/get/state"
      query: "zigbee2mqtt/%friendly_name%/get/state"
      capabilities:
        - power_switch
        - toggle
        - dimming
      primary_attribute: power_switch.state
      events:
        "zigbee2mqtt/%friendly_name%":
          "power_switch.state":
            json_payload: true
            expr: 'upper(payload.state) == "ON"'
          "dimming.level":
            json_payload: true
      actions:
        power_switch:
          "on":
            topic: "zigbee2mqtt/%friendly_name%/set/state"
            payload: 'ON'
          "off":
            payload: 'OFF'
          set:
            payload:
              expr: "parameters.state ? 'ON' : 'OFF'"
              type: raw
          toggle:
            payload: 'TOGGLE'
    The problem
    In order to control the brightness or the RGB color values, I would have send a JSON payload in corresponding actions. But I have no idea how to define it in the template. The reason why the switch part is working is that the zigbee2mqtt accepts also plain ON / OFF / TOGGLE string payloads in that case.
    But the brightness should be controlled with the following payload:
    {"brightness": 196}
    And the RGB color like:
    {"color":{"rgb":"46,102,150"}}
    Here's the link for the documentation (the Exposes part defines the messages).
    So how should I define the JSON payload for example for the dimming action? It definitely should be some sort of expressions since I have to map the MSR real value (0...1) to (0...254) for the zigbee2mqtt.
    actions:
        dimming:
          set:
            topic: "zigbee2mqtt/%friendly_name%/set"
            payload:
              expr: ?????
              type: json
    Another problem is the RGB value. I could use the rgb_color capability for the setting but the problem is that the zigbee2mqtt only reports the current color in hue/saturation or xy coordinates.
    Here's an example of published message after setting the color:
    Topic: zigbee2mqtt/Mood Light QoS: 0
       "brightness":254,
       "color":{
          "hue":240,
          "saturation":100,
          "x":0.1355,
          "y":0.0399
       "color_mode":"xy",
       "color_temp":574,
       "linkquality":96,
       "state":"ON"
    I would have to map those values back to RGB, but is it even possible with existing constructs in MQTTController's templates?
    Help would be appreciated @toggledbits
    br,
    • M mgvra
      Some background
      • switch (on/off)
      • brightness
      • color
        type: Switch
      lidl-moodlight:
        capabilities:
          - power_switch
          - toggle
          - dimming
        events:
              json_payload: true
            "dimming.level":
              json_payload: true
        actions:
          power_switch:
            "on":
              payload: 'ON'
            "off":
              payload: 'OFF'
            set:
              payload:
                type: raw
            toggle:
              payload: 'TOGGLE'
      The problem
      {"brightness": 196}
      actions:
          dimming:
            set:
              payload:
                expr: ?????
                type: json
         "brightness":254,
         "color":{
            "hue":240,
            "saturation":100,
            "x":0.1355,
            "y":0.0399
         "color_mode":"xy",
         "color_temp":574,
         "linkquality":96,
         "state":"ON"
      br,
      @mgvra You're on the right track. For an action like dimming.set, where a JSON payload is to be sent, you set the json type as you've done, and then you just need to make sure that the payload value is an object.
      actions:
          dimming:
            set:
              payload:
                type: json
                expr: >
                  { "brightness": parameters.level * 255 }
      That last line evaluates to an expression language object data type containing a single key brightness whose value is the result of the subexpression, which in this case is the parameter value level given to the action scaled up to the device's units (I guessed; do what works here).
      The important thing to realize here is that the expression is producing an object, not a string that looks like JSON. The type: json flag will cause MQTTController to convert the object to its JSON representation, whatever that requires.
      Don't forget you can set MQTTController's log level to 5 while doing this work to troubleshoot what you are doing and see more clearly what is ultimately being sent.
      I do have functions for converting between HS(L), RGB, and XY. Currently they are only available to HubitatController, but I can easily extend them to MQTTController as well. The trick there, however, is that your device's implementation is the same (e.g. for HSL 0° is red, 120° is green, 240° is blue, etc.). There's a de facto standard, but some devices have their own way.
      M 1 Reply Last reply
        actions:
            dimming:
              set:
                payload:
                  type: json
                  expr: >
        Thanks for yet another quick reply! I'll start playing with the expressions and JSON payloads now that I know the proper syntax.
                  expr: >
        So it is this implicit parameters object that contains the value (level) to be set.
        In the case of step dimming, is this the notation?
                  expr: >
                    { "brightness": parameters.step * 255 }
        Good point!
        Well that would be really nice if it doesn't require too much effort. A new release of the MSR or just the MQTTController?
        Well I think those functions should exist even if they don't work with all possible devices. It's sure better than nothing and chances are that they work just fine.
        br,
        • M mgvra
                    expr: >
                    expr: >
          Good point!
          br,
          @mgvra said in JSON payload in MQTTController entities actions (+ reverse color mapping to RGB):
          Yes, parameters will contain the values of any parameters the action requires/defines.
          expr: > { "brightness": parameters.step * 255 }
          Well, from the look of it, no. I think your device is going to set the brightness to whatever value is in step, not increment or decrement the brightness by that amount. If your device offers another topic to increment or decrement, you will need to use that instead.
          If your device doesn't have up/down brightness topics, you need to emulate them by using what we already know about the device. The entity has the current brightness level on it, so emulating step dimming is a matter of doing the math. Here's an example with fixed 10% up/down. The entity object is loaded with the action's subject entity, so we can access the current dimming level using its attribute:
          actions:
            dimming:
              up:
                payload:
                  type: json
                  expr: >
                    { "brightness": min(1, entity.attributes.dimming.level + 0.1) * 255 }
              down:
                payload:
                  type: json
                  expr: >
                    { "brightness": max(0, entity.attributes.dimming.level - 0.1) * 255 }
          Note that the dimming capability does not have any parameters for the up and down actions.
            MQTTController 23116 is now available for download; it has hsltorgb(hue,sat,lev) and rgbtohsl(r,g,b) functions available in expressions.
              @toggledbits related to this topic, I'm trying to set color with exactly the same lamp using the following configuration (MSR build is latest-24152-3455578a, MQTT version is 24142):
              reactor.yaml
               "zigbee2mqtt_smartmood":
                        name: 'Smart Mood Light'
                        friendly_name: 'Lidl smart mood'
                        include: ["lidl_moodlight", "lidl_moodlight_rgb"]
              local_mqtt_devices.yaml
              ("lidl_moodlight" part is omitted as it's not relevant here)
              lidl_moodlight_rgb:
                  capabilities: ["rgb_color"]
                  actions:
                    rgb_color:
                      set: false
                      set_rgb:
                        payload:
                          type: json
                          expr: '{"color": {"r": parameters.red, "g": parameters.green, "b": parameters.blue} }'
              The problem is that MQTT message is sent with null values, example below.
                "color": {
                  "r": null,
                  "g": null,
                  "b": null
              which is kinda expected, as MSR UI does not "ask" for these values when you select "rgb_color.set_rgb" action
              Any hints what could be changed in the configuration?
                OK. First of all, great post. That gave me all the information right out of the gate to replicate enough of your configuration to duplicate the problem.
                Found and fixed. Try MQTTController build 24162.
                  @toggledbits thanks! First it seemed that this fix isn't working, but worked as expected after I deleted the old entity...
                    It's the same for dimming.set and power_switch.set all .set, an entity rebuild solves those too with 24162.
                    (@toggledbits Mantis ID 372)
                    • DynamicGroupController updating members issue
                      128.4k
