  4. [ZWaveJS] Wrong leak_detector.state for NAS-WS01Z
6 Posts 2 Posters 1.5k Views 2 Watching
    Another one for you, @toggledbits.
    I have two water sensors (same device, NAS-WS01Z), but one is reporting leak_detector.state=true even if no alarm is detected (I double checked from ZWaveJS UI):
    battery_power.level=0.86
    battery_power.since=null
    x_debug.dt={"entity_class":"Notification Sensor","match":"deviceClass.generic.key=7"}
    x_zwave_values.Battery_level=86
    x_zwave_values.Binary_Sensor_Water=false
    x_zwave_values.Configuration_Alarm_Activity_Duration=5
    x_zwave_values.Configuration_Alarm_Beep=1
    x_zwave_values.Configuration_Alarm_Duration=120
    x_zwave_values.Configuration_Alarm_Interval=null
    x_zwave_values.Configuration_Basic_Set_Level=255
    x_zwave_values.Configuration_First_Alarm_Activity_Duration=null
    x_zwave_values.Configuration_Water_Detection=1
    x_zwave_values.Manufacturer_Specific_manufacturerId=600
    x_zwave_values.Manufacturer_Specific_productId=4229
    x_zwave_values.Manufacturer_Specific_productType=3
    x_zwave_values.Notification_Water_Alarm_Sensor_status=null
    x_zwave_values.Notification_alarmLevel=0
    x_zwave_values.Notification_alarmType=0
    x_zwave_values.Version_firmwareVersions=null
    x_zwave_values.Version_hardwareVersion=null
    x_zwave_values.Version_libraryType=null
    x_zwave_values.Version_protocolVersion=null
    x_zwave_values.Wake_Up_controllerNodeId=1
    x_zwave_values.Wake_Up_wakeUpInterval=43200
    zwave_device.capabilities=[48,112,113,114,128,132,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Notification Sensor"
    zwave_device.impl_sig="24225:1:22315:1"
    zwave_device.is_beaming=false
    zwave_device.is_listening=false
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.last_wakeup=1724143899220
    zwave_device.manufacturer_info=[600,3,4229]
    zwave_device.node_id=114
    zwave_device.specific_class="Notification Sensor"
    zwave_device.status=1
    zwave_device.status_text="asleep"
    zwave_device.version_info=[null,null]
    zwave_device.wakeup_interval=43200
    here's the other one, correctly report the leak status:
    battery_power.level=1
    leak_detector.state=false
    x_zwave_values.Battery_level=100
    x_zwave_values.Configuration_Alarm_Interval=1
    x_zwave_values.Configuration_First_Alarm_Activity_Duration=60
    x_zwave_values.Notification_Water_Alarm_Sensor_status=0
    x_zwave_values.Notification_alarmLevel=null
    x_zwave_values.Notification_alarmType=null
    x_zwave_values.Version_firmwareVersions=["2.54"]
    x_zwave_values.Version_hardwareVersion=48
    x_zwave_values.Version_libraryType=6
    x_zwave_values.Version_protocolVersion="4.5"
    zwave_device.last_wakeup=1724105239533
    zwave_device.node_id=113
    zwave_device.version_info=[null,"2.54"]
    Also, both seems to have no primary value. Thanks.
      In the first one, the value for the sensor is null from Z-Wave JS.
      In the second, it's not...
        But it seems to be OK under ZWaveJS UI:
        Very strange.
          Try triggering it and resetting it. It may be it's just not fully initialized internally.
            I left it (very difficult to take it and wake up manually) and after a couple of days it fixed by itself. Thanks.
              I've seen this before on some battery devices. A couple I have will also go to uninitialized after replacing batteries. Kind of a pain, but I think years of Z-Waving has conditioned us all to a few "quirks".
                146.1k
