  4. [ZwaveJS] Position and cover not working for Roller Shutter 1/2/3
37 Posts 2 Posters 12.9k Views 3 Watching
    Ok, here we go.
    In details:
    • OK: cover.close/open
    • KO: cover.stop, position.*
    Taken from zwawejs.log
    [latest-24212]2024-08-20T14:54:29.867Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.open on Cover#zwavejs>4-0 with [Object]{  }
    [latest-24212]2024-08-20T14:54:29.869Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs action cover.open set node 4 endpoint 0 value 38:targetValue:(undefined) = 99
    [latest-24212]2024-08-20T14:54:29.871Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 99 }
    [latest-24212]2024-08-20T14:54:33.806Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.close on Cover#zwavejs>4-0 with [Object]{  }
    [latest-24212]2024-08-20T14:54:33.808Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs action cover.close set node 4 endpoint 0 value 38:targetValue:(undefined) = 0
    [latest-24212]2024-08-20T14:54:33.809Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 0 }
    [latest-24212]2024-08-20T14:54:36.322Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.open on Cover#zwavejs>4-0 with [Object]{  }
    [latest-24212]2024-08-20T14:54:36.323Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs action cover.open set node 4 endpoint 0 value 38:targetValue:(undefined) = 99
    [latest-24212]2024-08-20T14:54:36.323Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 99 }
    [latest-24212]2024-08-20T14:55:02.507Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.increase on Cover#zwavejs>4-0 with [Object]{ "amount": 0.1 }
    [latest-24212]2024-08-20T14:55:04.523Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.increase on Cover#zwavejs>4-0 with [Object]{ "amount": 0.1 }
    [latest-24212]2024-08-20T14:55:10.073Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.relative on Cover#zwavejs>4-0 with [Object]{ "amount": 0.5 }
    [latest-24212]2024-08-20T14:55:13.023Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.set on Cover#zwavejs>4-0 with [Object]{ "value": 0.3 }
      btw, maybe it's related to the device being a Motor Control Class B and not Motor Control Class C? Looking at zwavejs_devices.yaml, there seems to be a different implementation.
        Class B doesn't have position, per Z-Wave specs. So that's the manufacturer providing the wrong device class data. Fibaro does a lot of this. Their firmware is trash. Also, this is a different device than previously reported (node 4 vs node 148), so you are moving the goal posts on me. So go back to 148 and tell me what's going on there, then we'll worry about 4 (different version of similar device).
          @toggledbits sorry. node 148 is working as expected. this is a RS3. node 4 is a RS2.
          here's node 4:
          cover.state=true
          energy_sensor.units="kWh"
          energy_sensor.value=6.58
          position.value=null
          power_sensor.units="W"
          power_sensor.value=0
          power_switch.state=true
          x_debug.dt={"0":769,"1":4097,"entity_class":"Cover","match":"deviceClass.generic.key=17;deviceClass.specific.key=6","capabilities":["cover","toggle","position"],"primary_attribute":"cover.state","manufacturerId":271,"productType":770,"productId":4096}
          x_zwave_values.Binary_Switch_currentValue=true
          x_zwave_values.Binary_Switch_targetValue=null
          x_zwave_values.Configuration_Delay_Time_After_S2=10
          x_zwave_values.Configuration_Energy_Reports=10
          x_zwave_values.Configuration_Forced_Roller_Shutter_Calibration=0
          x_zwave_values.Configuration_Lamellas_Positioning_Mode=1
          x_zwave_values.Configuration_Managing_Lamellas_in_Response_to_Alarm=0
          x_zwave_values.Configuration_Motor_Operation_Detection=0
          x_zwave_values.Configuration_Motor_Operation_Time=240
          x_zwave_values.Configuration_Periodic_Power_or_Energy_Reports=3600
          x_zwave_values.Configuration_Power_Reports=10
          x_zwave_values.Configuration_Reports_Type=0
          x_zwave_values.Configuration_Response_to_General_Alarm=0
          x_zwave_values.Configuration_Response_to_Smoke_CO_CO2_Alarm=0
          x_zwave_values.Configuration_Response_to_Temperature_Alarm=0
          x_zwave_values.Configuration_Response_to_Water_Flood_Alarm=0
          x_zwave_values.Configuration_Roller_Shutter_Operating_Modes=1
          x_zwave_values.Configuration_Scenes_Associations_Activation=1
          x_zwave_values.Configuration_Self_Measurement=0
          x_zwave_values.Configuration_Switch_Type=0
          x_zwave_values.Configuration_Turning_Time_Delay_Time=150
          x_zwave_values.Manufacturer_Proprietary_fibaro_venetianBlindsPosition=99
          x_zwave_values.Manufacturer_Specific_manufacturerId=271
          x_zwave_values.Manufacturer_Specific_productId=4096
          x_zwave_values.Manufacturer_Specific_productType=770
          x_zwave_values.Meter_reset=null
          x_zwave_values.Meter_value_65537=6.58
          x_zwave_values.Meter_value_66049=0
          x_zwave_values.Multilevel_Sensor_Power=0
          x_zwave_values.Multilevel_Switch_Close=null
          x_zwave_values.Multilevel_Switch_Open=null
          x_zwave_values.Multilevel_Switch_currentValue=99
          x_zwave_values.Multilevel_Switch_duration=null
          x_zwave_values.Multilevel_Switch_restorePrevious=null
          x_zwave_values.Multilevel_Switch_targetValue=99
          x_zwave_values.Protection_exclusiveControlNodeId=null
          x_zwave_values.Protection_local=0
          x_zwave_values.Protection_rf=0
          x_zwave_values.Protection_timeout=null
          x_zwave_values.Version_firmwareVersions=["25.25"]
          x_zwave_values.Version_protocolVersion="3.52"
          zwave_device.capabilities=[37,38,49,50,112,114,117,134,145]
          zwave_device.endpoint=0
          zwave_device.failed=false
          zwave_device.generic_class="Multilevel Switch"
          zwave_device.impl_sig="24233:1:24233:1"
          zwave_device.is_beaming=false
          zwave_device.is_listening=true
          zwave_device.is_routing=true
          zwave_device.is_secure=false
          zwave_device.manufacturer_info=[271,770,4096]
          zwave_device.node_id=4
          zwave_device.specific_class="Motor Control Class B"
          zwave_device.status=4
          zwave_device.version_info=[null,"25.25"]
            Here's node 148 for reference:
            cover.state=true
            energy_sensor.value=0.41
            position.value=0.92
            x_debug.dt={"entity_class":"Cover","match":"deviceClass.generic.key=17;deviceClass.specific.key=6","capabilities":["cover","toggle","position"],"primary_attribute":"cover.state","description":"Roller Shutter 3","model":"FGR223","default_name":"Roller Shutter 3","values":[{"match":{"endpoint":[1,2],"commandClass":38,"property":"currentValue"},"entity_class":"Cover","primary_attribute":"cover.state","capabilities":{"cover":{"attributes":{"state":{"expr":"value !== 0"}},"actions":{"open":{"valueId":"+targetValue:#","value":99},"close":{"valueId":"+targetValue:#","value":0},"stop":{"valueId":"+Up:","value":false}}},"position":{"attributes":{"value":{"expr":"round( value / 99, 2 )"}},"actions":{"set":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( parameters.value ?# 0 ), 0 ) ) )"}},"increase":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"decrease":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) - ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"relative":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}}}},"toggle":{"actions":{"toggle":{"valueId":"+targetValue:#","value":{"expr":"entity.attributes.cover.state ? 0 : 99"}}}}}}],"manufacturerId":271,"productType":771,"productId":4096}
            x_zwave_values.Meter_value_65537=0.41
            x_zwave_values.Multilevel_Switch_Down=null
            x_zwave_values.Multilevel_Switch_Up=null
            x_zwave_values.Multilevel_Switch_currentValue=91
            x_zwave_values.Multilevel_Switch_duration="unknown"
            x_zwave_values.Multilevel_Switch_targetValue=91
            x_zwave_values.Notification_Power_Management_Over_current_status=0
            x_zwave_values.Notification_System_Hardware_status=0
            x_zwave_values.Notification_alarmLevel=null
            x_zwave_values.Notification_alarmType=null
            zwave_device.capabilities=[38,50,113]
            zwave_device.endpoint=1
            zwave_device.failed=null
            zwave_device.manufacturer_info=null
            zwave_device.node_id=148
              OK. That's easy to fix, I think. Pull the updated zwavejs_data.zip file from the server and put in your config directory, restart Reactor, and let's see if 4 behaves better (I just applied the exceptions for the 223 to the 222, adjusted for a single endpoint).
                Still not working. position.value is still null.
                Logs:
                [latest-24212]2024-08-20T15:19:14.892Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.relative on Cover#zwavejs>4-0 with [Object]{ "amount": 0.5 }
                [latest-24212]2024-08-20T15:19:20.349Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.relative on Cover#zwavejs>4-0 with [Object]{ "amount": 0.5 }
                [latest-24212]2024-08-20T15:19:29.900Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.close on Cover#zwavejs>4-0 with [Object]{  }
                [latest-24212]2024-08-20T15:19:29.901Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs action cover.close set node 4 endpoint 0 value 38:targetValue:(undefined) = 0
                [latest-24212]2024-08-20T15:19:29.903Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 0 }
                [latest-24212]2024-08-20T15:19:32.172Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.close on Cover#zwavejs>4-0 with [Object]{  }
                [latest-24212]2024-08-20T15:19:32.173Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs action cover.close set node 4 endpoint 0 value 38:targetValue:(undefined) = 0
                [latest-24212]2024-08-20T15:19:32.174Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 0 }
                [latest-24212]2024-08-20T15:19:34.602Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.stop on Cover#zwavejs>4-0 with [Object]{  }
                [latest-24212]2024-08-20T15:19:36.567Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing cover.open on Cover#zwavejs>4-0 with [Object]{  }
                [latest-24212]2024-08-20T15:19:36.568Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs action cover.open set node 4 endpoint 0 value 38:targetValue:(undefined) = 99
                [latest-24212]2024-08-20T15:19:36.570Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 99 }
                [latest-24212]2024-08-20T15:19:45.548Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing position.relative on Cover#zwavejs>4-0 with [Object]{ "amount": 0.5 }
                  OK. You're talking about an attribute, but showing me actions in a log. On my system, the FGR222 is now showing position.value correctly for any value in range.
                  Here's what my log looks like (position.set to 0.45 on device 4, using your configuration):
                  [###BUILDVERSION###]2024-08-20T15:25:04.586Z <ZWaveJSController#zwstatic:INFO> ZWaveJSController#zwstatic performing position.set on Cover#zwstatic>4-0 with [Object]{ "value": 0.45 }
                  [###BUILDVERSION###]2024-08-20T15:25:04.587Z <ZWaveJSController#zwstatic:5:ZWaveJSController.js:2135> ZWaveJSController#zwstatic def [Object]{ "endpoint": 0, "commandClass": 38, "property": "currentValue", "propertyKey": --undef--, "impl": { "valueId": "+targetValue:#", "value": { "expr": "max( 0, min( 99, round( 100 * ( parameters.value ?# 0 ), 0 ) ) )" } } }
                  [###BUILDVERSION###]2024-08-20T15:25:04.591Z <ZWaveJSController#zwstatic:INFO> ZWaveJSController#zwstatic action position.set set node 4 endpoint 0 value 38:targetValue:(null) = 45
                  [###BUILDVERSION###]2024-08-20T15:25:04.593Z <ZWaveJSController#zwstatic:5:ZWaveJSController.js:1760> ZWaveJSController#zwstatic _set_value(4,0,38,targetValue,(null),45)
                  [###BUILDVERSION###]2024-08-20T15:25:04.594Z <ZWaveJSController#zwstatic:INFO> ZWaveJSController#zwstatic setting value [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 45 }
                  [###BUILDVERSION###]2024-08-20T15:25:04.596Z <ZWaveJSController#zwstatic:5:ZWaveJSController.js:335> ZWaveJSController#zwstatic sending #1724167504595<8/20/2024, 11:25:04 AM>: [Object]{ "command": "node.set_value", "nodeId": 4, "valueId": { "endpoint": 0, "commandClass": 38, "property": "targetValue" }, "value": 45, "messageId": 1724167504595 }
                  So both are working for me. I would try deleting the entity in MSR and restarting to recreate it. Then test again.
                    I don't know what to say. I've deleted all the ZWaveJS entities, restarted and still no luck.
                      What is the impl_sig attribute on device 4?
                        zwave_device.impl_sig="24233:1:24233:2"
                          Are you using position.set directly, or using the relative actions?
                            position.set.
                              That's wonderful. I have a FGR222 (previous fw) that's working. Here's node 3:
                              cover.state=false
                              position.value=0
                              x_debug.dt={"entity_class":"Cover","match":"deviceClass.generic.key=17;deviceClass.specific.key=6","capabilities":["cover","toggle","position"],"primary_attribute":"cover.state","description":"Roller Shutter","model":"FGRM222","default_name":"Roller Shutter","values":[{"match":{"commandClass":38,"property":"currentValue"},"capabilities":{"cover":{"attributes":{"state":{"expr":"value !== 0"}},"actions":{"open":{"valueId":"+targetValue:#","value":99},"close":{"valueId":"+targetValue:#","value":0},"stop":{"valueId":"+Up:","value":false}}},"position":{"attributes":{"value":{"expr":"round( value / 99, 2 )"}},"actions":{"set":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( parameters.value ?# 0 ), 0 ) ) )"}},"increase":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"decrease":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) - ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}},"relative":{"valueId":"+targetValue:#","value":{"expr":"max( 0, min( 99, round( 100 * ( ( entity.attributes.position?.value ?# 0 ) + ( parameters.amount ?# 0.10 ) ), 0 ) ) )"}}}},"toggle":{"actions":{"toggle":{"valueId":"+targetValue:#","value":{"expr":"entity.attributes.cover.state ? 0 : 99"}}}}}}],"manufacturerId":271,"productType":769,"productId":4097}
                              x_zwave_values.Configuration_Motor_Operation_Detection=1
                              x_zwave_values.Configuration_Roller_Shutter_Operating_Modes=0
                              x_zwave_values.Manufacturer_Specific_productId=4097
                              x_zwave_values.Manufacturer_Specific_productType=769
                              x_zwave_values.Multilevel_Switch_currentValue=0
                              x_zwave_values.Multilevel_Switch_targetValue=0
                              x_zwave_values.Version_firmwareVersions=["24.24"]
                              zwave_device.manufacturer_info=[271,769,4097]
                              zwave_device.node_id=3
                              zwave_device.version_info=[null,"24.24"]
                                OK. I think I see it. #4 has a different type and ID, and the alias has an error. Pull the new data ZIP and try again.
                                  That did the trick. Two things. position.value is now incosistent, whereas dimming.level was ok before. I tried to set node 4 to .9, and it's now reporting .31. A refresh is updating the position (to .91), but now power_switch.state=null.
                                  power_sensor.value is still 0.
                                    What are you comparing it to? For node 4, the last data you show have the Meter class value (meterType 1, property value, propertyKey 66049) at 0, and the Multilevel Sensor with sensorType=4 (Power) also 0. What are you expecting the value to be? Again, can you show more context, too? Post all the attributes? These things are moving targets, so more data is better than less.
                                      I'm getting the values from ZWaveJS UI and checking on the reported values from MSR:
                                      Position
                                      Watts reading seems to be more related to the device not refreshing itself (or refreshing randomly), as it was doing on Vera. I'll keep debugging the ZWaveJS part, since it seems that if I refresh the device, the values is passed onto Reactor.
                                      Thanks for the help!
                                        Sorry, but the image looks like you're showing position, not watts. I would like to understand which of the two power values provided by the device you are trying to reconcile.
                                        That said, a position of 0.91 would be correct, as the scale of the position.value attribute in Reactor is 0.0 to 1.0, computed from the device range of 0 to 99 (90/99 = 0.91 rounded to two digits).
                                          @toggledbits said in [ZwaveJS] Position and cover not working for Roller Shutter 1/2/3:
                                          no screenshot. As I've said, I'm finding that the device is not reporting that well. I'm 100% sure it was OK under Vera, and maybe it was part of the custom code they wrote for the device, Idk.
                                          ok, but I've asked for 0.90 via Reactor and I got 0.91 inside Reactor and 0.90 inside ZWaveJS. Imagine something that tries to position the device until it is OK...
                                            1.0k
                                            157.1k
