  4. Rule Execution Sequence
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
6 Posts 3 Posters 2.0k Views 3 Watching
  • wmarcolinW Offline
    Hi, @toggledbits!
    I have a question about the execution behavior. See the code below, and I'll explain the situation.
    This is a routine that, at a certain point, determines that the desktop on which the VM hosting the Reactor is located receives an instruction to perform a shutdown (Shell Command).
    When this happens, the desktop is turned off, and then Hubitat detects by a "ping" that the VM has been down, waits 15 seconds, turns off the power to this desktop, and then 15 seconds later turns on the desktop with the Reactor VM again.
    After restarting the desktop, the VM is loaded, and the Reactor is triggered. Still, the following problem occurs: I expected that when the rule was continued to be executed again, the next step would be executed, that of the 900-second delay after shutdown, but the Shell command is executed again, and then it goes into a loop, the rule does not advance.
    To break the loop, I first have to make the VM not load, change the desktop password, and then start the VM. In this case, Reactor generates an error when trying to execute the Shell Command because of the invalid password and then finishes the routine following the 900 delay step.
    Is my interpretation that when it returns, the routine should continue to the next step that has not yet been executed incorrectly? Or does Reactor, through the shutdown command, interpret that it hasn't finished this step and keep trying, which is the correct reaction?
    Thanks for clarifying.
      Why don’t you divide this into two rules?
      • wmarcolinW wmarcolin
        Hi, @toggledbits!
        @wmarcolin said in Rule Execution Sequence:
        This depends on the shutdown shell command. If it doesn't return until its work is done, then it would seem that this command didn't complete, and Reactor would want to do it over on restart. If it was returning, then Reactor would know it was delayed until a certain time (the end time of the delay is determined when it starts and preserved across restarts) and continue to delay until that time (or not at all if it has then passed).
        There should be a way to get Windows to launch that command in a subshell. You may have to have the command run in a script to do that and use the Shell Command action to run the script. The gist is, Reactor needs to start the delay before the shutdown occurs, or you'll get the behavior you're observing.
        wmarcolinW 1 Reply Last reply
          @toggledbits I understood, and I really understand that since the shutdown command doesn't return anything, this scenario is invalid and will remain in a constant loop.
          Breaking the action as @tunnus commented doesn't work either, the effect is the same.
          Ok, I'll try something then, like triggering a script that gives a return to the Reactor so that it understands that it has completed the task to continue.
          Is there any chance that the shell command triggered by the reactor might not wait for a return to proceed?
          Thank you.
          toggledbitsT tunnusT 2 Replies Last reply
            Thank you.
            Yes, that's what I mean. This is something you can do yourself. You can start the net command in a subshell. The Windows command processor has a command to do that... start I think... start net rpc ...etc..
              Thank you.
              @wmarcolin what if you do this like below:
              Rule 1: commands/reactions up to (and including) shutdown
              Rule 2: triggers when rule 1 is true with a long delay reset value (or maybe latching), and commands/reactions start with 900 s delay and the rest of the reactions
                163.1k
