  4. Log files
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Log files
8 Posts 3 Posters 1.4k Views 3 Watching
  • wmarcolinW Offline
    Hi!
    Is it possible to generate two additional log files, the first being the replica of what is displayed on screen by the Rule History widgets and the other with Recently Changed Entities?
    And could I configure the generation of one file per day, and delete the older ones? For example, store the last 5 days?
    And being more ambitious, does Windget have an icon to open these TXT files in the navigated?
    Well, we're approaching Christmas, so here's my request to Santa Claus @toggledbits 🙂
    • wmarcolinW wmarcolin
      Hi!
      @wmarcolin said in Log files:
      We can get pretty close. There should already be a placeholder Rule entry in your config/logging.yaml file. Make it look like this:
        Rule:
          level: 4
          streams:
            - type: file
              recycle: true
              keep: 4
              maxsize: 2
      This tells Reactor to log messages of INFO and higher to a file called rules.log (in the logs subdirectory). The recycle key tells the logger to start a new file on each Reactor restart. The keep: 4 tells the logger to keep the last 4 files. The maxsize: 2 limits the size of a single log file to 2MB.
      What this doesn't do is rotate the log daily. I will address that in an upcoming version.
      Note sure what you mean here. If you're talking about the log files, they are just plain text, so you can open them in NotePad or any similar tool that capable of reading/editing text files (i use NotePad++).
      wmarcolinW 1 Reply Last reply
          Rule:
            level: 4
            streams:
              - type: file
                recycle: true
                keep: 4
                maxsize: 2
        As always, you are very quick and attentive; thank you.
        The point I mentioned about Windget having an icon to open plain text would be to show the log file in a browser. To see this file today, I have to use PuTTY, log in to my VM, search for the directory, and then open the file with Nano.
        I wanted a faster way to view the file in a browser without having to install Apache or a Python SimpleHTTPServer.
          OK. I get that.
            OK. I get that.
            @toggledbits 🙂
            Instead of an icon in the widget, you could use the MSR Tools group to access these log files.
              I'm going to do something quick and dirty first, because my long-term idea for this is too much to do in the current build, which has already accumulated a lot of changes and needs to get out. I've also been alternately on standby and working on disaster relief since hurricane Helene was in Mexico, and continuing with Milton gaining strength.
              wmarcolinW tunnusT 2 Replies Last reply
                Friend Santa Claus, please take care of yourself, I'm changing my Christmas request so that you and yours are safe and well! Don't worry about my request.
                  @toggledbits godspeed Patrick!
                    2.1k
                    3.8k
                    3.3k
