  4. [Reactor] Assignment to alarm ignored -- expression-driven global cannot be set by assignment
4 Posts 2 Posters 1.1k Views 2 Watching
    I have lots of logs with this:
    <Engine:ERR> Assignment to alarm ignored -- expression-driven global cannot be set by assignment
    Any hints to where look at to avoid this? Thanks.
      Only expression-less global variables can be set by an assignment. You have a script/expression somewhere that's attempting to change the value. The lines leading up to that message may provide a clue what actions are occurring.
        I found it, but I had to search inside the json's rules with VS code. I had a local variable with the same name of global one. Not easy to be found, since it was a local variable in a local expression and nothing was logged before to give me context. Thanks!
          The error message will be improved, but for reference for future readers, there are two ways to fix this when it happens:
          1. Change the name of your local variable.
          2. Explicitly declare and initialize your local variable at the start of your expression as explicitly local. For example, assuming alpha is the name of a global expression/variable but we want to use it as a local variable name:
             local alpha=0, each e in matchEntities( { capability: 'dimming' } ): alpha = alpha + 1
            136.0k
