  4. Runtime error latest-24366 when Create New Reaction
6 Posts 3 Posters 1.4k Views 3 Watching
  • B Offline
    B Offline
    basai
    Reactor (Multi-hub) latest-24366-3de60836
    Running on Proxmox 8 VM
    Ubuntu 22.04.5 LTS
    Docker version 27.5.0, build a187fa5
    Docker Compose version v2.32.3
    Browsers being used on Mac OS Sequoia: Safari, Firefox also occurs with Safari on iPhone 16 Pro 18.2.1
    This occurs on two different instances of MSR running at two different locations having the same environment detailed above.
    When I select "Reactions->Create Reaction" I get an error window with a red “Runtime Error:” banner. Note that I can edit and save existing Reactions
    —-------------------<SNIP>————————————
    Runtime Error:
    @http://192.168.119.137:8111/reactor/en-US/lib/js/reactor-ui-reactions.js:445:34
    You may report this error, but do not screen shot it. Copy-paste the complete text. Remember to include a description of the operation you were performing in as much detail as possible. Report using the Reactor Bug Tracker (in your left navigation) or at the SmartHome Community.
    ---------------------</SNIP>————————
    apt update, apt upgrade, reboot have been performed as well as
    docker system prune -a
    docker compose down
    docker compose up -d
    Many thanks in advance,
    -bh
    • CrilleC Online
      CrilleC Online
      I'm getting the same on Ubuntu bare metal latest- 24366, both in chrome and edge on Windows.
      TypeError: this.editReaction is not a function
      at HTMLButtonElement.<anonymous> (http://[ip]:8111/reactor/en-US/lib/js/reactor-ui-reactions.js:445:22)
        Confirmed. Sit tight. Patch build coming.
        Also, between the "Runtime Error" and the line listed, there should have been an actual error message. Please make sure you include that when posting. Mine shows:
            at HTMLButtonElement.<anonymous> (http://192.168.0.164:8111/reactor/en-US/lib/js/reactor-ui-reactions.js:446:22)
        B 1 Reply Last reply
          B Offline
          B Offline
          basai
          @toggledbits Howdy, the error is as I posted and doesn't show that information. I took the instructions not to upload a screen shot too literally I suppose, apologies.
          Here is what it looks like on my end on Safari, and Firefox in OS X Sequoia.
          Thanks,
          -bh
            OK. Let me know if 25016 resolved it for you.
            And no, you posted correctly. Text rather than screen shot is usually better for these. I'll ask for screen shots if I need them.
            • B Offline
              B Offline
              basai
              Confirming that 25016 has indeed resolved the error.
              Thank you !!
                146.9k
