  4. [Solved] Local expression evaluation
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
13 Posts 3 Posters 2.4k Views 3 Watching
  • V Offline
    V Offline
    Trying to understand what cause a local expresssion to be evaluated. I have read the manual but I am still not clear about it. Using the test rule below, I can see in the log that the rule is being automatically evaluated every time the temperature entity is changing. That is great...
    What I am trying to understand is why the expression is not evaluated based on time as well since the "case" statement has time dependencies.
    Any help would be appreciated
    I have the following test rule:
    Here is the expressioncode:
    vFrom1 = "09:25:00",
    vFrom2 = "09:30:00",
    vFrom3 = "09:41:00",
    vTo = "10:55:00",
    # Get current time (format HH:MM:SS)
    vToDay = strftime("%H:%M:%S"),
    #Get current house temperature
    CurrentHouseTemp = getEntity( "hass>Thermostat2 " ).attributes.temperature_sensor.value,
    case
      when CurrentHouseTemp <= 19 and vToDay >= vFrom1 && vToDay <= vTo: "true1"   # From1
      when CurrentHouseTemp <= 20 and vToDay >= vFrom2 && vToDay <= vTo: "true2"     # From2
      when CurrentHouseTemp < 26  and vToDay >= vFrom3 && vToDay <= vTo: "true3"  # From3
      else "false"
    Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
      Time is never a trigger for expressions. It would basically require re-evaluation every second. There's no way for the expression evaluator to determine your intent in the expressions and find an "edge" where it would know that your conditions are changing. This is unlike the Date/Time and related conditions in the triggers, where it is usually possible to determine when the next event will occur. You should probably be using Date/Time conditions rather than expressions for logic like this.
      TL;DR: that's by design. Time functions don't cause frequent re-evaluations.
      Tip: you can use an Interval condition to force your rule to re-evaluate on the given interval, at which time, your local expressions will also be re-evaluated (local expressions are updated before triggers are scanned when a rule evaluation takes place).
      Also: it's not correct to compare a time string to another time string. Basically, everything about this expression won't work.
      V 1 Reply Last reply
      • V Offline
        V Offline
        Roger that. Up to this point I was really thinking that It would work like Date/Time.
        Thank you.
          V Offline
          V Offline
          @toggledbits said in [Solved] Local expression evaluation:
          I understand that, as you explained, expression cannot auto evaluate based on time. However when manually trigger, the expression do work as intended with time and all.
          I Know that your not in the business of teaching others how to code but does it means that, inside an expression, we should never attempt to perform actions based on time like:
          if strftime("%H:%M:%S") < "08:00:00" then
            If you use Unix epoch format, you can compare two values as they are numbers
              At best, comparing numbers within strings is considered bad style. As @tunnus says, you're better off using epoch time format in many cases, which we could say more broadly as, there are numeric forms available that will work better (and show good programming discipline/style).
              Now, your particular tests can be done in epoch time, but that may not be the best approach, since epoch time is absolute from Jan 1 1970 UTC, and you are really just looking at particular daily events. Within Reactor itself, similar calculations are done in MSM form, or Minutes Since Midnight.
              Looking at your "edges" (the points in time where things change), you could set them in MSM form like this:
              vFrom1 = 09 * 60 + 25,
              vFrom2 = 09 * 60 + 30,
              vFrom3 = 09 * 60 + 41,
              vTo = 10 * 60 + 55,
              You can see I am multiplying the hour by 60 and then adding the minutes, which gives minutes since midnight for each event time.
              To get the current time in MSM, you can:
              p=dateparts(), vToDay= p.hour * 60 + p.minute,
              From there, the rest of your expression should work as you wrote it, but it will now be comparing numbers (MSM):
              CurrentHouseTemp = getEntity( "hass>Thermostat2" ).attributes.temperature_sensor.value,
              case
                else "false"
              This doesn't change the fact that this expression won't be evaluated periodically on its own. You still need to use an Interval condition to stimulate its re-evaluation.
              • V Offline
                V Offline
                @tunnus @toggledbits Thank you both for all your explanation.
                Much appreciated.
                  Continuing this discussion, I've noticed that if I have local expressions that contain "getEntity(...)" type of variables, these expressions are evaluated every time entity changes. This happens regardless of triggers.
                  But if I have the same expressions where "getEntity(...)" is replaced by a global variable / expression (and this global variable contains getEntity-structure), these kind of local expressions are not evaluated even if global variable changes. For clarity, expressions would be evaluated if rule is triggered.
                  @toggledbits, is this behaviour by design? Using build 25060 on Docker.
                    Try restarting after any edits to rules or expressions. I do this kind of structure a lot and I don't see issues, but I'm always willing to look at any reproducible test case you can give me.
                      @toggledbits well I guess the following test cases should either prove my point or prove me wrong 😬
                      Rule 1: (no real triggers, only comments etc)
                      local expressions:
                      TempOutside = getEntity( "..." ).attributes.temperature_sensor.value
                      Rule 2: (no real triggers, only comments etc)
                      local expressions:
                      TempOutside = g_TempOutside
                      (where g_TempOutside = getEntity( "..." ).attributes.temperature_sensor.value)
                      So in my case "Rule 2" -type of local expressions won't be evaluated unless rule is triggered. I'm pretty sure it used to work differently with earlier builds, about a year ago.
                        local expressions:
                        local expressions:
                        This case is easy to reproduce, only the question is if this happens by design?
                        Screenshot 2025-03-11 at 21.47.44.png ("TempOutside" is also a global variable, although its naming is a bit misleading)
                          It's more a reflection of a limitation in the language implementation and integration. It's incredibly hard to get the dependency scan right, and what I really need to do at this point is go back and remake the expression parser specifically for Reactor, rather than using it as a standalone library (which I nonetheless author, but I was trying to keep it isolated). It's a tricky business, and even changing behavior at this point to make it work the way you think it should will probably goof up somebody else's rules and expressions. I'll add it to the wish list. It's definitely an interesting problem that I'd like to tackle, but it's not going to come painlessly.
                          Workaround for the moment, and I realize it's not great, is to integrate changes conditions for those global variables into the rule's triggers.
                            @toggledbits the main thing is that now I know that this behaviour is not a bug and there's a clear alternative (not using global variables when rule does not trigger often enough).
                            Anyway, MSR is a great software and thanks for your continued support!
                              97.6k
                            • Next Release?
