  4. Throttled problem
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Throttled problem
15 Posts 3 Posters 3.4k Views 3 Watching
  • wmarcolinW Offline
    Hi @toggledbits
    I found this very old post that talked about a way to limit device reading to avoid the throttled problem, because it's not a question of logic, it's that the device actually sends a lot of information, in my case the NUT ups installed in HE.
    https://smarthome.community/topic/687/flapping-device?_=1737652139854
    It mentions engine section of reactor.yaml by setting update_rate_limit, but I looked in the current MSR documentation and I can't find this information, so I don't know if it's still valid, its effect and parameters.
    My situation is simple, when I have a UPS problem the NUT is sending dozens of reports per second and then I have the throttled problem. The same rule applies when the power is normal.
    This is the rule, and the parameter that fails is the Tripp Lite UPS status.
    All error is the same scenario.
    [latest-25016]2025-01-23T12:01:32.753Z <Rule:WARN> (13) NUT Disconected (rule-l4djr0p7 in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Throttl>
    [latest-25016]2025-01-23T12:01:32.756Z <Rule:WARN> (27) Falta de Energia (rule-l4h9ceod in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Thrott>
    [latest-25016]2025-01-23T12:01:32.769Z <Rule:WARN> (73) UPS Battery Low (rule-l4hj850o in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Throttl>
    [latest-25016]2025-01-23T12:01:32.772Z <Rule:WARN> (74) UPS Comm Fail (rule-l4kbs5cp in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Throttlin>
    [latest-25016]2025-01-23T12:01:32.776Z <Rule:WARN> (76) UPS Utility Back (rule-l4hjhs6m in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Thrott>
    [latest-25016]2025-01-23T12:01:32.780Z <Rule:WARN> UPS On Battery (rule-l4hjuka5 in Datacenter) update rate 121/min exceeds limit (120/min)! Logic loop? Throttling>
    [latest-25016]2025-01-23T12:01:32.781Z <Rule:WARN> UPS Info (rule-l4gheo63 in Datacenter) update rate 121/min exceeds limit (120/min)! Logic loop? Throttling...
    [latest-25016]2025-01-23T12:01:40.757Z <Rule:WARN> (13) NUT Disconected (rule-l4djr0p7 in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Throttl>
    [latest-25016]2025-01-23T12:01:40.759Z <Rule:WARN> (27) Falta de Energia (rule-l4h9ceod in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Thrott>
    [latest-25016]2025-01-23T12:01:40.776Z <Rule:WARN> (73) UPS Battery Low (rule-l4hj850o in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Throttl>
    [latest-25016]2025-01-23T12:01:40.777Z <Rule:WARN> (74) UPS Comm Fail (rule-l4kbs5cp in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Throttlin>
    [latest-25016]2025-01-23T12:01:40.778Z <Rule:WARN> (76) UPS Utility Back (rule-l4hjhs6m in Warning) update rate 121/min exceeds limit (120/min)! Logic loop? Thrott>
    • wmarcolinW wmarcolin
      Hi @toggledbits
      @wmarcolin search the manual for "time series"
      wmarcolinW 1 Reply Last reply
        What's the UPS problem? Maybe that could be addressed in NUTController if its some odd failure mode of NUT that I can detect?
        What you likely don't want to do is allow the issue to place an even larger load on the system by increasing the throttling limit.
          @tunnus hi!
          I like what I've read, I think it could be a solution, but it's still not very clear how to configure it, since I want to save various attributes of the device.
          I'll try it out and post the result here for you, but it could be a way forward.
          Thank you.
            @toggledbits hi!
            This NUT UPS issue is something I've been unable to get to work perfectly for months, not to mention year. I even posted a message to you recently.
            I tried to use an old solution from the HE community instead of the MSR solution. The information it returns is much simpler, I had to add attributes to the drive, but the problem turns out to be the same, the NUT stops working, the communication between the UPS and the VM where the NUT is located is not stable. HE upsd drive result: Satale date.
            dev:1572025-01-24 08:21:16.586 PMinfo
            connected to upsd on 192.168.50.8:3493 - monitoring TrippLite every 30 seconds
            dev:1572025-01-24 08:21:01.183 PMinfo
            dev:1572025-01-24 08:20:31.149 PMerror
            telnet connect error: java.net.ConnectException: Connection refused (Connection refused)
            dev:1572025-01-24 08:20:01.110 PMinfo
            disconnected from upsd
            dev:1572025-01-24 08:20:00.082 PMerror
            telnet status: send error: Broken pipe (Write failed)
            dev:1572025-01-24 08:11:15.553 PMinfo
            dev:1572025-01-24 08:10:45.514 PMerror
            dev:1572025-01-24 08:10:30.421 PMerror
            dev:1572025-01-24 08:10:00.277 PMinfo
            dev:1572025-01-24 08:10:00.252 PMerror
            telnet status: receive error: Stream is closed
            dev:1572025-01-24 08:10:00.228 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:10:00.216 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:10:00.203 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:10:00.122 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:10:00.111 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:10:00.098 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:10:00.069 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:09:30.112 PMwarn
            upsd: Stale data
            dev:1572025-01-24 08:09:30.101 PMwarn
            upsd: Stale data
            In other words, after switching from MSR to HE control, the problem continues, changing the error Throttled to ECONNREFUSED.
            Making a new test, returning to the MSR's NUTControl configuration below, with the same parameters as the HE drive.
              - id: nut
                enabled: true
                implementation: NUTController
                name: NUT UPS Controller
                  server: 192.168.50.8  # modify the IP address as needed
                  port: 3493            # optional, default shown
                  username: "Reactor"   # optional, no user auth if not set
                  password: "Mac1967"   # optional, must be specified if username is used
            The error.log log on MSR is:
            [latest-25016]2025-01-25T02:10:03.776Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:05.800Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:07.807Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:07.815Z <Controller:ERR> Controller NUTController#nut is off-line!
            [latest-25016]2025-01-25T02:10:09.907Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:11.924Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:13.927Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:15.939Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:18.124Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:20.128Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:22.150Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:24.172Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            [latest-25016]2025-01-25T02:10:26.182Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
            IMPORTANT, even with this error log, the NUT control in the MSR does not stop working, it persists until it manages to communicate and collect the data, but this error scenario overloads the MSR.
            Perhaps the time solution indicated by @tunnus could help.
            In addition, parts of the ro reactor.log:
            [latest-25016]2025-01-25T02:06:46.777Z <Structure:INFO> Structure#1 loading controller interface nut (NUTController)
            [latest-25016]2025-01-25T02:06:46.779Z <NUTController:null> Module NUTController v24303
            [latest-25016]2025-01-25T02:06:46.779Z <Controller:INFO> Loaded NUTController version "0.1.24303"; Patrick Rigney/Kedron Holdings LLC <patrick@toggledbits.com> https://reactor.toggledbits.com/docs/NUTC>
            [latest-25016]2025-01-25T02:06:46.847Z <Structure:INFO> Starting controller NUTController#nut
            [latest-25016]2025-01-25T02:06:47.394Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "1/24/2025 9:06:47 PM" (TZ offset -300 mins from UTC)
            [latest-25016]2025-01-25T02:06:47.395Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
            [latest-25016]2025-01-25T02:06:47.397Z <HubitatController:NOTICE> HubitatController#hubitatC7 performing initial connection and inventory
            [latest-25016]2025-01-25T02:06:47.398Z <HubitatController:NOTICE> HubitatController#hubitatC8 performing initial connection and inventory
            [latest-25016]2025-01-25T02:06:47.405Z <NUTController:INFO> NUTController#nut connected
            [latest-25016]2025-01-25T02:06:47.455Z <NUTController:INFO> NUTController#nut setting client username (Reactor) and password
            [latest-25016]2025-01-25T02:06:47.460Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.50.9
            [latest-25016]2025-01-25T02:06:47.511Z <Controller:NOTICE> Controller NUTController#nut is now online.
            [latest-25016]2025-01-25T02:06:47.511Z <NUTController:INFO> NUTController#nut client ready
            [latest-25016]2025-01-25T02:06:47.516Z <wsapi:INFO> wsapi: connection from ::ffff:192.168.50.133
            [latest-25016]2025-01-25T02:10:03.774Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
            [latest-25016]2025-01-25T02:10:03.776Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (1 fails)
            [latest-25016]2025-01-25T02:10:03.777Z <NUTController:NOTICE> NUTController#nut connection closed
            [latest-25016]2025-01-25T02:10:03.777Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (1 fails)
            [latest-25016]2025-01-25T02:10:05.799Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
            [latest-25016]2025-01-25T02:10:05.801Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (2 fails)
            [latest-25016]2025-01-25T02:10:05.801Z <NUTController:NOTICE> NUTController#nut connection closed
            [latest-25016]2025-01-25T02:10:05.802Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (2 fails)
            [latest-25016]2025-01-25T02:10:07.803Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
            [latest-25016]2025-01-25T02:10:07.816Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (3 fails)
            [latest-25016]2025-01-25T02:10:07.829Z <NUTController:NOTICE> NUTController#nut connection closed
            [latest-25016]2025-01-25T02:10:07.830Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (3 fails)
            IN SUMMARY:
            • the connection parameters IP, login and password are correct, in the log you can see that it connects.
            • NUTControl works until it starts a sequence of failures.
            • In order to re-establish the service, I put a stop and start process in the crontab every 10 minutes, the problem is that it can remain idle all this time and fail.
            • I've tried changing all the synchronization and reading times in the NUT parameters, I've even increased them to 90 seconds for data collection(ie. POLLFREQALERT 30 // HOSTSYNC 30), and it doesn't change the scenario, at a certain point there's saturation and the UPS stops responding.2
            So I think the idea of making the MSR have a different collection time, longer than other devices, can at least reduce the error log, but it doesn't solve the problem.
              @toggledbits hi!
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
              upsd: Stale data
                - id: nut
                  enabled: true
              IN SUMMARY:
              @wmarcolin here's something I've used for a sensor that updates too frequently:
                        capabilities:
                          temperature_sensor:
                              value:
                                model: time series
                                entity: "mqtt>layzspa_states"
                                attribute: "temperature_sensor.value"
                                interval: 1  # minutes
                                retention: 1  # minutes
                                aggregate: sma
                                precision: 0
                        type: ValueSensor
              Now I can use this virtual entity instead of a real one in a rule without throttling or logging problems (log files rotating too often etc)
                Somewhere between...
                and
                is another message I need to see. NUTController will log the reason for a disconnect prior to reconnecting.
                Using a time series is a band-aid that may mask the symptom but won't fix the problem. I don't recommend it, because it really doesn't reduce the system load -- it still needs to handle the change notifications, it's just doing it in a different subsystem.
                  @wmarcolin pull the 25026 release of NUTController. I made some changes to the recovery discipline and added more info messages. Let's see if it helps us get to the bottom of this.
                    @toggledbits download and test now.
                        Hi @toggledbits !!
                        I installed the new version, and at the same time created a log file specifically for NUTController, below is what I captured in the first 20 minutes, remembering that every 10 minutes I stop and restart the service to mitigate the problem.
                        [latest-25016]2025-01-27T18:42:31.243Z <NUTController:null> Module NUTController v25026
                        [latest-25016]2025-01-27T18:42:31.840Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:42:31.848Z <NUTController:INFO> NUTController#nut connected to "192.168.50.8":3493
                        [latest-25016]2025-01-27T18:42:31.848Z <NUTController:INFO> NUTController#nut setting client username (Reactor) and password
                        [latest-25016]2025-01-27T18:42:31.887Z <NUTController:INFO> NUTController#nut client ready after authentication
                        [latest-25016]2025-01-27T18:42:31.960Z <NUTController:INFO> NUTController#nut initial query succeeded with 1 items returned
                        [latest-25016]2025-01-27T18:42:32.007Z <NUTController:INFO> NUTController#nut initializing TrippLite
                        [latest-25016]2025-01-27T18:50:01.750Z <NUTController:NOTICE> NUTController#nut connection closed; attempting reconnect...
                        [latest-25016]2025-01-27T18:50:01.808Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:50:01.810Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T18:50:01.811Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (1 fails)
                        [latest-25016]2025-01-27T18:50:03.811Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:50:03.812Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T18:50:03.812Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (2 fails)
                        [latest-25016]2025-01-27T18:50:05.897Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:50:05.898Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T18:50:05.911Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (3 fails)
                        . repeat same fail 4....28
                        [latest-25016]2025-01-27T18:50:58.732Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:50:58.733Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T18:50:58.734Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (29 fails)
                        [latest-25016]2025-01-27T18:51:00.740Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:51:00.741Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T18:51:00.742Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (30 fails)
                        [latest-25016]2025-01-27T18:51:02.762Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T18:51:02.764Z <NUTController:INFO> NUTController#nut connected to "192.168.50.8":3493
                        [latest-25016]2025-01-27T18:51:02.764Z <NUTController:INFO> NUTController#nut setting client username (Reactor) and password
                        [latest-25016]2025-01-27T18:51:02.764Z <NUTController:INFO> NUTController#nut client ready after authentication
                        [latest-25016]2025-01-27T18:51:02.826Z <NUTController:INFO> NUTController#nut initial query succeeded with 1 items returned
                        [latest-25016]2025-01-27T18:51:02.875Z <NUTController:INFO> NUTController#nut initializing TrippLite
                        [latest-25016]2025-01-27T19:00:01.389Z <NUTController:NOTICE> NUTController#nut connection closed; attempting reconnect...
                        [latest-25016]2025-01-27T19:00:01.440Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T19:00:01.440Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T19:00:01.441Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (1 fails)
                        [latest-25016]2025-01-27T19:00:03.441Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T19:00:03.444Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T19:00:03.445Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (2 fails)
                        [latest-25016]2025-01-27T19:00:05.454Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T19:00:05.455Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T19:00:05.462Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (3 fails)
                        [latest-25016]2025-01-27T19:00:58.245Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T19:00:58.246Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T19:00:58.246Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (29 fails)
                        [latest-25016]2025-01-27T19:01:00.246Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T19:01:00.248Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.50.8":3493: [Error] connect ECONNREFUSED 192.168.50.8:3493 [-]
                        [latest-25016]2025-01-27T19:01:00.248Z <NUTController:INFO> NUTController#nut recycling/reconnecting in 2000ms (30 fails)
                        [latest-25016]2025-01-27T19:01:02.250Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.168.50.8":3493; waiting for ready...
                        [latest-25016]2025-01-27T19:01:02.250Z <NUTController:INFO> NUTController#nut connected to "192.168.50.8":3493
                        [latest-25016]2025-01-27T19:01:02.250Z <NUTController:INFO> NUTController#nut setting client username (Reactor) and password
                        [latest-25016]2025-01-27T19:01:02.251Z <NUTController:INFO> NUTController#nut client ready after authentication
                        [latest-25016]2025-01-27T19:01:02.310Z <NUTController:INFO> NUTController#nut initial query succeeded with 1 items returned
                        [latest-25016]2025-01-27T19:01:02.367Z <NUTController:INFO> NUTController#nut initializing TrippLite
                          Hi @toggledbits !!
                          @wmarcolin said in Throttled problem:
                          OK. So basically, the log is showing exactly that. It's showing that every 10 minutes, the NUT service is closing the connection, and the service takes 60 seconds, almost exactly, to restart before NUTController can connect to it.
                          Try turning off the 10 minute restart and see what it does.
                            I removed the crontab stop and restart process with a set time, and then restarted the MSR to follow the new logs, below.
                            [latest-25016]2025-01-28T14:28:58.785Z <NUTController:null> Module NUTController v25026
                            [latest-25016]2025-01-28T14:28:59.438Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.16>
                            [latest-25016]2025-01-28T14:28:59.444Z <NUTController:INFO> NUTController#nut connected to "192.168.50.8":3493
                            [latest-25016]2025-01-28T14:28:59.444Z <NUTController:INFO> NUTController#nut setting client username (Reactor) >
                            [latest-25016]2025-01-28T14:28:59.544Z <NUTController:INFO> NUTController#nut client not yet ready; waiting
                            [latest-25016]2025-01-28T14:28:59.544Z <NUTController:INFO> NUTController#nut client ready after authentication
                            [latest-25016]2025-01-28T14:29:00.631Z <NUTController:INFO> NUTController#nut initial query succeeded with 1 ite>
                            [latest-25016]2025-01-28T14:29:00.688Z <NUTController:INFO> NUTController#nut initializing TrippLite
                            [latest-25016]2025-01-28T15:04:17.580Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:04:17.580Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:04:27.602Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:04:27.603Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:04:37.610Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:04:37.610Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:04:47.618Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:04:47.619Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:04:57.682Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:04:57.682Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:05:07.687Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:05:07.687Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:05:18.056Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:05:18.056Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:05:28.059Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:05:28.059Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T15:05:38.068Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T15:05:38.068Z <NUTController:CRIT> !DATA-STALE
                            . start the DAT-STALE
                            [latest-25016]2025-01-28T16:59:13.198Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T16:59:23.199Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T16:59:23.200Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T16:59:33.202Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T16:59:33.203Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T16:59:43.213Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T16:59:43.214Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T16:59:53.227Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T16:59:53.227Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:00:03.330Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:00:03.330Z <NUTController:CRIT> !DATA-STALE
                            . nothing change than I restart the process (
                            #systemctl restart nut-driver.service
                            #systemctl restart nut-server.service
                            #systemctl restart nut-monitor.service
                            [latest-25016]2025-01-28T17:00:13.332Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:00:13.332Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:00:23.336Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:00:23.336Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:00:33.362Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:00:33.363Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:00:43.414Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:00:43.414Z <NUTController:CRIT> !DRIVER-NOT-CONNECTED
                            [latest-25016]2025-01-28T17:00:44.544Z <NUTController:NOTICE> NUTController#nut connection closed; attempting re>
                            [latest-25016]2025-01-28T17:00:44.596Z <NUTController:NOTICE> NUTController#nut starting NUT client with "192.16>
                            [latest-25016]2025-01-28T17:00:44.597Z <NUTController:INFO> NUTController#nut connected to "192.168.50.8":3493
                            [latest-25016]2025-01-28T17:00:44.597Z <NUTController:INFO> NUTController#nut setting client username (Reactor) >
                            [latest-25016]2025-01-28T17:00:44.598Z <NUTController:INFO> NUTController#nut client ready after authentication
                            [latest-25016]2025-01-28T17:00:44.648Z <NUTController:INFO> NUTController#nut initial query succeeded with 1 ite>
                            [latest-25016]2025-01-28T17:00:54.705Z <NUTController:INFO> NUTController#nut initial query succeeded with 1 ite>
                            [latest-25016]2025-01-28T17:00:54.748Z <NUTController:INFO> NUTController#nut initializing TrippLite
                            [latest-25016]2025-01-28T17:28:37.934Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:28:37.934Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:28:47.942Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:28:47.942Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:28:57.945Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:28:57.946Z <NUTController:CRIT> !DATA-STALE
                            [latest-25016]2025-01-28T17:29:07.959Z <NUTController:ERR> NUTController#nut failed to get detail for TrippLite:>
                            [latest-25016]2025-01-28T17:29:07.960Z <NUTController:CRIT> !DATA-STALE
                            . but after 8min DATA-STALE again
                            When it failed I consulted upsc directly and the answer I got was the one below.
                            root@main:/home/wilson/reactor/logs# upsc TrippLite@192.168.50.8
                            Init SSL without certificate database
                            Error: Data stale
                            Importantly, in MSR the NUT service does not crash, but it stops updating.
                            See that the device goes into an uninformed/excluded status.
                            I don't think the problem lies with the MSR/NUTConttoler, it's a matter of the NUT itself managing the UPS. I've been in this situation for more than a year and I can't get out of the problem loop, so some time ago I adopted the stop and restart crontab to alleviate the problem.
                              Error: Data stale
                              Looking for a solution, I implement this script.
                              #!/bin/bash
                              # Nome do UPS configurado em /etc/nut/ups.conf
                              UPS_NAME="TrippLite"
                              # Comando para verificar o status do UPS
                              if upsc "$UPS_NAME@localhost" | grep -q "DATA-STALE"; then
                                  echo "$(date): DATA-STALE detectado. Reiniciando o serviço NUT." >> /var/log/monitor_nut.log
                              else
                                  echo "$(date): Serviço funcionando normalmente." >> /var/log/monitor_nut.log
                              fi
                              We'll see if it eases the problem, but here's the situation with the NUT.
                                OK. That's enough info to determine it's a NUT problem (or driver problem), at least.
                                You may want to look at this. You should be troubleshooting at the Network UPS Tools level, looking at your (operating) system log files. Restarting the service isn't going to fix it.
                                  118.3k
