  4. Custom capabilities in MQTT templates
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
8 Posts 3 Posters 1.7k Views 3 Watching
    wrote on last edited by mgvra
    I'm trying to integrate the sonos-mqtt (https://sonos2mqtt.svrooij.io/) with the MSR and it's coming along nicely so far.
    But cannot wrap my head around how to define custom capabilities in MQTT templates. I need this for the TTS announcements and similarly for the notification sounds where I would pass the sound file as parameter.
    So this is what I have in the local_mqtt_devices.yaml
    capabilities:
      x_sonos_announcement:
        actions:
          speak:
            arguments:
              text:
                type: string
              volume:
                type: int
              delay:
                type: int
    And this is the template:
    templates:
      sonos-announcement:
        capabilities:
          - x_sonos_announcement
        actions:
            speak:
              topic: "sonos/cmd/speak"
              payload:
                expr: >
                  { "text": parameters.text, "volume": parameters.volume, "delayMs": parameters.delay, "onlyWhenPlaying": false, "engine": "neural" }
                type: json
    So the speak action should send something like this to topic sonos/cmd/speak
      "text": "message goes here",
      "volume": 50,
      "delayMs": 100,
      "engine": "neural"
    At startup the MSR seems to be quite unhappy with my configuration:
    reactor  | [latest-25016]2025-02-09T08:19:59.029Z <MQTTController:WARN> MQTTController#mqtt entity Entity#mqtt>sonos-announcement unable to configure capabilities [Array][ "x_sonos_announcement" ]
    reactor  | i18n: missing fi-FI language string: Configuration for {0:q} is incomplete because the following requested capabilities are undefined: {1}
    reactor  | i18n: missing fi-FI language string: Configuration for {0:q} has unrecognized capability {1:q} in actions
    reactor  | Trace: Configuration for {0:q} is incomplete because the following requested capabilities are undefined: {1}
    reactor  |     at _T (/opt/reactor/server/lib/i18n.js:611:28)
    reactor  |     at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:125:25)
    reactor  |     at MQTTController.sendWarning (/opt/reactor/server/lib/Controller.js:627:30)
    reactor  |     at MQTTController.start (/var/reactor/ext/MQTTController/MQTTController.js:268:26)
    reactor  |     at async Promise.allSettled (index 0)
    Configuration for "sonos-announcement" has unrecognized capability "x_sonos_announcement" in actions
    Controller: MQTTController#mqtt
    Last 10:21:37 AM
    Configuration for "sonos-announcement" is incomplete because the following requested capabilities are undefined: x_sonos_announcement
    Last 10:21:37 AM
    This is probably a pretty stupid question and the approach may not even work at all, but maybe someone or @toggledbits for sure, could point me to the right direction.
    Basically the idea is to be able to send TTS messages from reactions using entity actions. I've previously used HTTP requests to Sonos HTTP API (https://hub.docker.com/r/chrisns/docker-node-sonos-http-api/) for the same functionality, but since moving to sonos-mqtt, I need a way to send the TTS notifications using MQTTController. Along with the actual message, volume and delay must also be parameterizable.
    br,
    MSR latest-25016-d47fea38 / MQTTController [0.2.24293]
      As you can see from
      reactor-mqtt-contrib/shelly_gen1.yaml at a05d77b468d0a09fab72d2a23bee683ba2e47c82 · dbochicchio/reactor-mqtt-contrib
      this should be:
        capabilities:
            actions:
      and the way you nest and indent is very important.
      M 1 Reply Last reply
        As you can see from
        this should be:
          capabilities:
              actions:
        @therealdb
        Well thanks for your reply, but didn't get it working.
        This is my config now:
        capabilities:
            actions:
              speak:
                arguments:
                  text:
                    type: string
                  volume:
                    type: int
                  delay:
                    type: int
        templates:
          sonos-announcement:
            capabilities:
            actions:
                speak:
                  payload:
                    expr: >
                    type: json
        I just fail to see what is the problem here.
        br,
          Start by moving your capability definition into local_mqtt_capabilities.yaml and seeing how far that gets you.
          Also, you'll get complaints because your capability name doesn't start with x_mqtt, which you can either ignore, or switch to something like x_mqtt_sonos_....
            Thank you for your reply! Well this is what I mean, the answer is right in your face (local_mqtt_capabilities.yaml) and you just can't see it.
            Now it works like charm and I can even refactor my existing KNX templates using the custom capabilities.
            For anyone else who might be struggling with the same problem, here's my config:
            capabilities:
              x_mqtt_sonos_announcement:
                actions:
                  speak:
                    arguments:
                      text:
                        type: string
                      volume:
                        type: int
                        default: 50
                      delay:
                        type: int
                        default: 500
            templates:
              sonos-announcement:
                capabilities:
                 - x_mqtt_sonos_announcement
                actions:
                    speak:
                      payload:
                        expr: >
                        type: json
            UI looks like this:
            FYI there's a subtle layout issue with the login screen background image when using ultra wide monitors, just to let you know.
              Showing off all your cool toys, eh?
              Thanks for letting me know. I'll see what I can do to make it look more presentable.
                @toggledbits said in Custom capabilities in MQTT templates:
                Well I wouldn't boast with employer provided montitor, and definitely wouldn't call it cool, just damn wide. 🙂
                But speaking of showing off cool toys, this is something I bet you've never seen before, one of my weird projects:
                A custom made flow through heater for my summer cottage's outdoor shower. Based on old used Webasto ThermoTop EVO 5kW car engine diesel
                heater and controlled by ESP32 which provides WiFi AP and web UI. Fully modular, so that the heating unit can be removed before the winter.
                Wouldn't call this cool either (no pun intented) but unique. Works pretty well, at least @tunnus agrees.
                Old WIP photo
                np
                br,
                  That is cool. I really love stuff that combines simple, available IoT bits with the old greasy bits to solve problems. It appeals to my libertarian steampunk fantasy of how I'd run my home, which unfortunately far exceeds my wife's tolerance for the lower limits of luxury over sustainability. 😆
                  • Next Release?
