  4. Problem after upgrading to 25067
4 Posts 3 Posters 1.2k Views 3 Watching
    retireditguy
    wrote on last edited by retireditguy
    MSR had been running fine, but I decided to follow the message to upgrade to 25067. Since the upgrade, I have received the message "Controller "<name>" (HubitatController hubitat2) could not be loaded at startup. Its ID is not unique." MSR throws the message on every restart. Has anyone else encountered this problem?
    I am running MSR on a Raspberry Pi4 connecting to two Hubitat units over an OpenVPN tunnel. One C8 and a C8 Pro. Both are up-to-date. It appears that despite the error message that MSR may be operating properly.
      Have you checked the logs for more information?
      R 1 Reply Last reply
        It's telling you you have an error in your config.
          retireditguy
          I reviewed my Reactor configuration file. Some time ago I had duplicated one of the hubitat device sections in anticipation of making changes to my extended LAN. While one entry was marked as "enabled: false", it seems that MSR did not like the duplicate ID even though the duplicate was disabled. I added and "X" to the "id" and "name" of the duplicated entry and the error messages ceased.
          Thanks for the help
            154.2k
