  4. Widget deletion does not work and landing page (status) is empy
4 Posts 3 Posters 1.4k Views 3 Watching
    wrote on last edited by mgvra
    It seems that the widget deletion does not work. I tried to drag the widget to the left (as explained in here https://smarthome.community/topic/1071/deleting-widgets?_=1744037333660)
    but it does not delete it. Anyone else experiencing the same problem?
    Also the landing page after login is empty and seems be have some JS issues on the dev console:
    Using dockerized version of Reactor (Multi-hub) latest-25082-3c348de6 on Chromium 135.0.7049.52 (Official Build) snap (64-bit)
    br,
      This change was also mentioned in the release notes for build 24343.
        Well my bad and classic RTFM case. Actually I also tried to drag it to the top but it seems that you have to hit the top bar on the spot in order to trigger the deletion, which is fine when you know it. And well right after the post, new release came out which fixed the landing page problem - nice work!
        br,
        • M mgvra
          br,
          @mgvra the landing page issue was addressed here as a side note in another issue thread: https://smarthome.community/post/16764
            151.9k
