  4. Reset attribute value of entity in event handler
5 Posts 2 Posters 2.0k Views 3 Watching
    RHCPNG
    Hi all,
    I have successfully created an event handler for the interactive notifications of HA, see: https://smarthome.community/post/15414
    However, I'm not able to reset the value that the event has set.
    This is my event handler:
    event_targets:
            interactive_notification_responses:
              name: "Handle notification responses"
              capabilities:
              - string_sensor
              events:
              - event:
                  event_type: mobile_app_notification_action
                  data:
                    action: "LAUNDRY_INSIDE"
                response:
                  "string_sensor.value":
                    expr: "event.data.action"
    I have only 1 button in the notification, so the value is the same every time.
    Because of this my rule does not trigger a second time, because the value is the same.
    My solution was to use an entity action and do a set_attribute to reset the value of the entity. But this does not seem to work.
    This is my set reaction part:
    Shouldn't this be working? And maybe there is a smarter way?
      RHCPNG
      Additional question:
      • The entity value is not changing, because the value doesn't change, right? Or is the event not even triggered? (I don't see the entity flashing in the entities section, when I try to trigger the event)
      • Can I add attribute metadata to the rule trigger to see if there was an update?
        There are other capabilities that are more useful for things like this. You could use either button or scene_activation, for example, both of which provide a timestamp attribute that your event can modify:
        event_targets:
                  capabilities:
                  - scene_activation
                  events:
                  - event:
                      data:
                    response:
                      "scene_activation.scene_id":
                      "scene_activation.since":
                        expr: "time()"
        That's right. Adding a check to see if since changes will address this.
        You could do that as well, but it's more complicated because right now, the metadata is only accessible in expressions, so you'd need to make a local variable in your rule to grab that metadata.
        R 1 Reply Last reply
          event_targets:
                    capabilities:
                    - scene_activation
                    events:
                    - event:
                        data:
                      response:
                          expr: "time()"
          RHCPNG
          @toggledbits Thanks, this is great. I will try it out!
            RHCPNG
            Seems to be working perfectly. Thanks! Should have thought of that myself.
              158.4k
