  4. Expose MSR entities
HA 2025.9.4 Supported Yet?
Rule Set UI bug - RESOLVED
[Reactor] Copy&Paste of Rules
Expose MSR entities
Comment in Globa Expressions
Tom_DT
Gradually turn on lights.
Tom_DT
Can't customize home page
Error After Upgrade
Expose MSR entities
11 Posts 3 Posters 961 Views 3 Watching
    Any thoughts?
    TIA
    toggledbitsT CatmanV2C 3 Replies Last reply
      Any thoughts?
      TIA
      @CatmanV2 said in Expose MSR entities:
      Yeah, sorry. It's not at all clear to me what you're asking here. I'm reading "I have an owntracks_sensor in Home Assistant... is there any way to expose that sensor (which comes from Home Assistant) to Home Assistant trivially?" Uh... what?
        Any thoughts?
        TIA
        Yes that was stupid of me! Sorry!
        MSR! Not HA!
        So the owntracks_sensor exists in MSR and works great. I'm wondering if there's an easy way to expose to HA
        What a buffoon
          If you are using MQTT you can echo the entity in the MSR config and create a MQTT entity in Home Assistant
            I am still completely confused. Yes, Reactor will publish the sensor from HA. I use that myself. But since the Reactor sensor entity comes from HA, why would want to publish Reactor's entity back to HA then?
              I believe the owntracks_sensor only exists in Reactor.
                Any thoughts?
                TIA
                Currently I am using the owntracks_sensor for tracking phones being in region in HA and it works great.
                I'm reading this as "it's coming from HA."
                Is it actually an MQTT entity created using the owntracks_in_region template of MQTTController? Because there's nothing natively called owntracks_sensor in Reactor.
                  Sorry I tried to make it clear. For the avoidance of doubt the original post should (and shortly will) read
                  'Currently I am using the owntracks_sensor for tracking phones being in region in MSR and it works great.'
                    @toggledbits this is precisely what it is, yes
                      Whew. OK. Then yes, this is the way to go.
                        You are both gents!
                          6.8k
                        • Shelly Wall Display XL
                          8.8k
                        • HA 2025.9.4 Supported Yet?
                        • Rule Set UI bug - RESOLVED
