I'm re-writing my shelly_scenecontroller mqtt template because I added a new pushbutton and I had strange results. Basically, in the last couple of days, it fired itself, because of the way the logic works. Everytime I'm pushing a button, an "S" is sent as the event, so the
button.statenever changes. I'm looking forbutton.sinceto determine if the button is pressed again.
That's good, but everytime a poll is done, thebutton.sinceattribute is updated, because it is tied totime().
So, I introduced the use of
event_cntfrom the payload, comparing the value to the stored one, in order to understand if it has been pushed again, or, in general, the number of times the button is pushed.
Updated template:events: "shellies/%topic%/input_event/%channel%": - attribute: "value_sensor.value" json_payload: true expr: "float(payload?.event_cnt)" - attribute: "button.since" json_payload: true expr: > entity.attributes?.button?.since == null || float(payload?.event_cnt) != entity.attributes?.value_sensor?.value ? time() : entity.attributes.button.since - attribute: "scene_activation.since" # just copy button.since expr: "entity?.attributes?.button?.since" - attribute: "button.state" json_payload: true expr: > payload?.event == "S" ? "single" : payload?.event == "SS" ? "double" : payload?.event == "SSS" ? "triple" : payload?.event == "L" ? "long" : "unknown" - attribute: "scene_activation.scene_id" json_payload: true expr: "payload?.event" - attribute: "x_mqtt_device.online" expr: trueThis should work, but instead I have this value:
and that's beyond strange and I can't honestly figure it out. @toggledbits any hint is appreciated. Thanks.
Debug level 5 for MQTTController and log files are your friend.
That said, I'm suspicious of the operator precedence effect on your expression. Wrap a set of parens around the conditional of the ternary operator and try it again.
No joy from the logs. I added parens but no joy. The only thing that worked was a delete of the entity/restart of Reactor.
[latest-25272]2025-09-30T14:49:47.414Z <MQTTController:5:MQTTController.js:599> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 associated with Array(1)[ "shelly_gatebutton" ] [latest-25272]2025-09-30T14:49:47.414Z <MQTTController:5:MQTTController.js:601> MQTTController#mqtt dispatching shellies/shelly-gatebutton/input_event/0 to shelly_gatebutton [latest-25272]2025-09-30T14:49:47.414Z <MQTTController:5:MQTTController.js:1152> MQTTController#mqtt handling shellies/shelly-gatebutton/input_event/0 (event shellies/shelly-gatebutton/input_event/0) for shelly_gatebutton: {"event":"","event_cnt":2} [latest-25272]2025-09-30T14:49:47.415Z <MQTTController:5:MQTTController.js:1168> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 affects entity shelly_gatebutton attributes value_sensor.value, button.since, scene_activation.since, button.state, scene_activation.scene_id, x_mqtt_device.online [latest-25272]2025-09-30T14:49:47.415Z <MQTTController:5:MQTTController.js:1274> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 setting shelly_gatebutton value_sensor.value=2 [latest-25272]2025-09-30T14:49:47.415Z <MQTTController:5:MQTTController.js:1274> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 setting shelly_gatebutton button.since={"event":"","event_cnt":0} [latest-25272]2025-09-30T14:49:47.416Z <MQTTController:5:MQTTController.js:1274> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 setting shelly_gatebutton scene_activation.since={"event":"","event_cnt":0} [latest-25272]2025-09-30T14:49:47.416Z <MQTTController:5:MQTTController.js:1274> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 setting shelly_gatebutton button.state=unknown [latest-25272]2025-09-30T14:49:47.416Z <MQTTController:5:MQTTController.js:1274> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 setting shelly_gatebutton scene_activation.scene_id= [latest-25272]2025-09-30T14:49:47.417Z <MQTTController:5:MQTTController.js:1274> MQTTController#mqtt topic shellies/shelly-gatebutton/input_event/0 setting shelly_gatebutton x_mqtt_device.online=true [latest-25272]2025-09-30T14:49:47.417Z <MQTTController:5:MQTTController.js:1905> MQTTController#mqtt _handle_ext_event() shellies/shelly-gatebutton/input_event/0 matches 0 subscriptionsMaybe it's something that when it's corrupted with json, doesn't work as expected. I'm reporting as an edge case, but it's very hard to reproduce. Thanks anyway. New build for my MQTT-contrib incoming.
Looking more deeply at your logic, I don't think it's going to work. Here's where I think you are:
The current value of
button.sinceis{"event":"", "event_cnt":0}. I assume it got set this way from prior effort leading up to this point. Now, based on what you currently have configured...When the topic
shellies/shelly-gatebutton/input_event/0arrives withevent_cnt:2in the payload, the first thing MQTTController is doing is settingvalue_sensor.valueto 2. You can see that in the log snippet.The next thing is it attempts to set
button.since, but since your expression is set up so thatbutton.sinceis only changed if if the value ofvalue_sensor.valueis different frompayload.event_cnt, which it won't be, because it just set them to the same value. So the expression simply returns the current value ofbutton.sinceand thus changes nothing.See the problem now?
You have control over the order in which the attributes are processed for the topic/event.
@toggledbits said in Strange behavior for MQTT templates using payload and attributes:
I see it! Thanks! (Never code in a hurry while doing 100 other things).
@therealdb said in Strange behavior for MQTT templates using payload and attributes:
Ummm... is there any other way?
