  4. Help resolve change in behaviour post update
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
12 Posts 2 Posters 1.1k Views 2 Watching
    Current set up: Bare metal (virtualised) on Debian 10.2
    MSR 25310
    Updated over the weekend and two reactions that have worked for literally years have changed. I'm pretty sure it was due to the 'nuances' in previous versions of evaluating global variables, so just looking for some help to 'fix'?
    I have two reactions that are dependant in large part on the global variable GlobalAlarmTime This is set in the Alarm Clock plugin of Openluup.
    One reaction turns the heating on one hour before the alarm goes off. The other turns the outside lights on one hour before the alarm goes off.
    Typically I change GlobalAlarmTime depending on the day of the week and the plans of the day ahead.
    GlobalAlarmTime is a string, current value (string) "05:40:00"
    Local variable HeatTime is calculated:
    time(GlobalAlarmTime) - 3600000
    Currently that has a value of 1762749600000
    Which is (quite correctly) 04:40:00 GMT 10th November. It's this because I changed the value of GlobalAlarmTime checking stuff out this morning, and HeatTime was re-evaluated at 09:37:17
    The challenge that I'm facing is that prior to the upgrade, HeatTime would be re-evaluated every 15 minutes (triggered by the 'Interval' function and come midnight (or at worst 00:15:00) HeatTime would re-evaluate to time(GlobalAlarmTime) - 3600000 today (if you get my point)
    That update to 'today' no longer happens. So the heating never comes on.
    [latest-25310]2025-11-10T00:00:00.025Z <Rule:INFO> Holiday Shutdown (rule-l8ys5tzy in Heating Control) starting rule state evaluation; because timer-trigger Timer#rule-l8ys5tzy
    [latest-25310]2025-11-10T00:00:00.031Z <Rule:INFO> Holiday Heating (rule-ltsdvzi8 in Heating Control) starting rule state evaluation; because timer-trigger Timer#rule-ltsdvzi8
    [latest-25310]2025-11-10T00:00:00.051Z <Rule:INFO> Holiday Lights (rule-ltse0zb4 in Heating Control) starting rule state evaluation; because timer-trigger Timer#rule-ltse0zb4
    [latest-25310]2025-11-10T00:00:00.058Z <Rule:INFO> Set Greeting to Evening (rule-lioalha1 in Test Bed) starting rule state evaluation; because timer-trigger Timer#rule-lioalha1
    [latest-25310]2025-11-10T00:00:00.068Z <Rule:INFO> Set Greeting to Evening (rule-lioalha1 in Test Bed) evaluated; rule state transition from SET to 'RESET'
    [latest-25310]2025-11-10T00:00:00.084Z <Rule:INFO> Garden lights on when the doors are open (rule-lb2h69nb in Outside Lights) starting rule state evaluation; because timer-trigger Timer#rule-lb2h69nb
    [latest-25310]2025-11-10T00:00:00.086Z <Rule:INFO> Set Greeting to Afternoon (rule-lioanahk in Test Bed) starting rule state evaluation; because timer-trigger Timer#rule-lioanahk
    [latest-25310]2025-11-10T00:00:00.095Z <Rule:INFO> Evening Lights are On (rule-l5senfyv in Outside Lights) starting rule state evaluation; because timer-trigger Timer#rule-l5senfyv
    [latest-25310]2025-11-10T00:00:00.096Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) starting rule state evaluation; because timer-trigger Timer#rule-l6gxvycu
    [latest-25310]2025-11-10T00:00:00.102Z <Rule:INFO> Rule#rule-l6gxvycu local LightTime is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.102Z <Rule:INFO> Rule#rule-l6gxvycu local LightTime has object dependency
    [latest-25310]2025-11-10T00:00:00.102Z <Rule:INFO> Rule#rule-l6gxvycu local LightOn is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.103Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) evaluated; rule state transition from RESET to 'SET'
    [latest-25310]2025-11-10T00:00:00.139Z <Engine:INFO> Enqueueing "Morning Lights are on<SET>" (rule-l6gxvycu:S)
    [latest-25310]2025-11-10T00:00:00.140Z <Engine:NOTICE> Starting reaction Set Greeting to Morning<SET> (rule-lioajm6q:S)
    [latest-25310]2025-11-10T00:00:00.147Z <Engine:INFO> Set Greeting to Morning<SET> all actions completed.
    [latest-25310]2025-11-10T00:00:00.162Z <Engine:NOTICE> Starting reaction Morning Lights are on<SET> (rule-l6gxvycu:S)
    [latest-25310]2025-11-10T00:00:00.163Z <VeraController:INFO> VeraController#vera perform action power_switch.on on Switch#vera>device_20170 with {  }
    [latest-25310]2025-11-10T00:00:00.170Z <VeraController:INFO> VeraController#vera perform action power_switch.set on Switch#vera>device_20170 with { "state": true }
    [latest-25310]2025-11-10T00:00:00.173Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) starting rule state evaluation; because timer-trigger Timer#rule-l60fkpo3
    [latest-25310]2025-11-10T00:00:00.178Z <Rule:INFO> Rule#rule-l60fkpo3 local AlarmTime has object dependency
    [latest-25310]2025-11-10T00:00:00.179Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatTime is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.179Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatTime has object dependency
    [latest-25310]2025-11-10T00:00:00.179Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatOn is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.180Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatOff is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.185Z <Rule:INFO> Morning Lights are on (rule-l6gxvycu in Outside Lights) starting rule state evaluation; because timer-trigger Timer#rule-l6gxvycu
    [latest-25310]2025-11-10T00:00:00.192Z <Rule:INFO> Rule#rule-l6gxvycu local LightTime is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.193Z <Rule:INFO> Rule#rule-l6gxvycu local LightTime has object dependency
    [latest-25310]2025-11-10T00:00:00.193Z <Rule:INFO> Rule#rule-l6gxvycu local LightOn is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.195Z <Rule:INFO> Morning Heating (rule-l60fkpo3 in Heating Control) starting rule state evaluation; because timer-trigger Timer#rule-l60fkpo3
    [latest-25310]2025-11-10T00:00:00.196Z <Rule:INFO> Rule#rule-l60fkpo3 local AlarmTime has object dependency
    [latest-25310]2025-11-10T00:00:00.196Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatTime is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.196Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatTime has object dependency
    [latest-25310]2025-11-10T00:00:00.196Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatOn is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.196Z <Rule:INFO> Rule#rule-l60fkpo3 local HeatOff is a dependency of another variable
    [latest-25310]2025-11-10T00:00:00.233Z <VeraController:NOTICE> VeraController#vera action power_switch.set({ "state": true }) on Switch#vera>device_20170 succeeded
    [latest-25310]2025-11-10T00:00:00.234Z <Engine:INFO> Resuming reaction Morning Lights are on<SET> (rule-l6gxvycu:S) from step 1
    [latest-25310]2025-11-10T00:00:00.234Z <VeraController:INFO> VeraController#vera perform action power_switch.on on Switch#vera>device_20090 with {  }
    [latest-25310]2025-11-10T00:00:00.234Z <VeraController:INFO> VeraController#vera perform action power_switch.set on Switch#vera>device_20090 with { "state": true }
    [latest-25310]2025-11-10T00:00:00.289Z <VeraController:NOTICE> VeraController#vera action power_switch.set({ "state": true }) on Switch#vera>device_20090 succeeded
    [latest-25310]2025-11-10T00:00:00.289Z <Engine:INFO> Resuming reaction Morning Lights are on<SET> (rule-l6gxvycu:S) from step 2
    [latest-25310]2025-11-10T00:00:00.290Z <Engine:INFO> Morning Lights are on<SET> all actions completed.
    [latest-25310]2025-11-10T00:00:43.383Z <Engine:INFO> Engine#1 master timer tick, local time "10/11/2025 00:00:43" (TZ offset 0 mins from UTC)
    [latest-25310]2025-11-10T00:00:43.452Z <Rule:INFO> Internet Check (rule-m6z41xhd in Office Environment) starting rule state evaluation; because entity-changed System#reactor_system>system
    [latest-25310]2025-11-10T00:00:43.463Z <httpapi:INFO> HTTPAPI(#1) API request from ::ffff:192.168.70.249: GET /api/v1/netstatus
    [latest-25310]2025-11-10T00:00:43.476Z <Rule:INFO> Internet Check (rule-m6z41xhd in Office Environment) starting rule state evaluation; because entity-changed System#reactor_system>system
    [latest-25310]2025-11-10T00:00:43.488Z <Rule:INFO> Internet Check (rule-m6z41xhd in Office Environment) starting rule state evaluation; because entity-changed System#reactor_system>system
    [latest-25310]2025-11-10T00:00:43.490Z <Rule:INFO> Internet Check (rule-m6z41xhd in Office Environment) starting rule state evaluation; because entity-changed System#reactor_system>system
    [latest-25310]2025-11-10T00:00:43.510Z <Rule:INFO> Internet Check (rule-m6z41xhd in Office Environment) starting rule state evaluation; because entity-changed System#reactor_system>system
    [latest-25310]2025-11-10T00:00:43.516Z <HassController:NOTICE> HassController#hass websocket closing, 1006
    I'm going to guess I need to use the new alarm function.
    I'm further guessing that I'd set up a new global variable to replace HeatTime and have something like
    GlobalHeatTime = alarm ( 900) , time(GlobalAlarmTime) - 3600000 ?
    Am I on the right lines?
    TIA
      MSR 25310
      TIA
      @CatmanV2 said in Help resolve change in behaviour post update:
      You're on the right track. If I understand your description, something like this should work (all globals):
      gAlarmTime = getEntity( ... )
      gHeatTime = time(gAlarmTime) - 3600000
      gHeatOn = alarm(900), time() >= gHeatTime
      gAlarmTime will be updated any time the dependent entity changes. gHeatTime will change any time gAlarmTime changes (reference to another variable creates a dependency on that variable). gHeatOn will be updated by the periodic alarm() tripping.
        Super. I think I can understand that. Will I see it updating in the logs?
          Yes, and on the Expressions page.
            @toggledbits Thanks so much
            I've now got this
            With GlobalHeatOn as one of my conditions in the reaction.
            My assumption is it will go false at, or immediately after midnight?
            I'm guessing I can lose the Interval statement as well?
            Cheers
              I've now got this
              Cheers
              No. If your GlobalAlarmTime will always show time only (no date components), then you can safely add an alarm() call to GlobalHeatTime as well.
                @toggledbits Ahh super
                GlobalAlarmTime is never date (or I guess we'd not have this issue!)
                I do appreciate you thinking down to my level 🙂
                  I'm working for you. You also gave me an idea that I think could create a very useful alternative way to get to where you want to go. More to come...
                    Very grateful as ever. Looks like this is mostly working (although I also need to change HeatOff to a global variable to update. Expectation for tomorrow morning is good...
                    ... which is just as well as I will be away and Mrs C will be 'displeased' 🙂
                      Very happy that everything worked correctly this morning. At least for the heating. Just need to sort the outside lights, but that will be simple as the globals are in place.
                      Thanks again! More drams required 🙂
                        You should be able to go back to something similar to what you were doing originally, just in Script conditions. Give it a try!
                          I shall have a play!
                            963
                            2.0k
                            3.7k
                            3.3k
