  4. Script action and custom timers
4 Posts 2 Posters 946 Views 2 Watching
    Sorry to write here without trying, but I’m flying today.
    Am I correct if i say that script action with alarm() makes it possible to execute a reaction in a given interval, lets say 15 seconds or 3.5 minutes?
    That sounds amazing, since I’ve used weird tricks, including a custom controller, just to do this.
      Yes, that's correct!
        so:
        alarm(10), true
        should fire every 10 secs? It's not working for me, maybe I have something wrong in the expression.
        EDIT: ok, setting it as pulsing every X secs indefinitely did the trick. amazing!
          Depends on what you mean by "fire". If you look at the logs (not in pulse output mode, but in the default "follow"), you will probably see it being re-evaluated every 10 seconds, but because your result is a constant true, the rule SETs and never RESETs. Changing it to pulse output, of course, changes that.
          The thing to notice, though, is that the expression IS being evaluated every 10 seconds, regardless of the output mode of the condition.
            148.3k
