  4. Time series documentation
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
11 Posts 2 Posters 1.1k Views 2 Watching
      @tunnus Not entirely. I need to spend some time on that. As the post suggested, comment out or remove your retention configuration value. It will be computed from interval and depth.
      Simple moving average:
                name: "Outdoor Temperature Average"
                capabilities:
                  value_sensor:
                      value:
                        model: time series
                        entity: "weather>home"
                        attribute: "wx.temperature"
                        aggregate: sma
                        interval: 60  # minutes
                        depth: 5
                        precision: 2
                primary_attribute: value_sensor.value
                type: ValueSensor
      Rate:
                name: "Garage Humidity Change Rate"
                capabilities:
                  value_sensor:
                      value:
                        model: time series
                        entity: "mqtt>garage_handt"
                        attribute: "humidity_sensor.value"
                        aggregate: rate
                        interval: 30  # minutes
                        depth: 3  # last three samples, t-0, t-30, t-60
                        precision: 2
                      units: "%/min"
                type: ValueSensor
                  capabilities:
                    value_sensor:
                        value:
                          model: time series
                          aggregate: sma
                          depth: 5
                          precision: 2
                  type: ValueSensor
        Rate:
                  capabilities:
                    value_sensor:
                        value:
                          model: time series
                          aggregate: rate
                          precision: 2
                        units: "%/min"
                  type: ValueSensor
        @toggledbits I cannot get "accel" (acceleration) method to work. It used to work at some point, but at least with the latest builds (now using 25328) I'm getting "null" as a value. Entity values below:
        value_sensor.units=null
        value_sensor.value=null
        x_virtualentity.last_request_time=null
        x_virtualentity.request_failures=null
        x_virtualentity.template=null
        x_virtualentity.timeseries_aggregate="accel"
        x_virtualentity.timeseries_debug=[{"time":1766248080000,"value":694},{"time":1766248380000,"value":694},{"time":1766248680000,"value":694},{"time":1766248980000,"value":701},{"time":1766249280000,"value":701},{"time":1766249580000,"value":691},{"time":1766249880000,"value":691},{"time":1766250180000,"value":691},{"time":1766250480000,"value":696},{"time":1766250780000,"value":696},{"time":1766251080000,"value":696},{"time":1766251380000,"value":707},{"time":1766251680000,"value":707}]
        x_virtualentity.timeseries_depth=null
        x_virtualentity.timeseries_interval=5
        x_virtualentity.timeseries_length=13
        x_virtualentity.timeseries_nextsample=1766251980000
        x_virtualentity.timeseries_retention=60
        And configuration from reactor.yaml:
                  name: "Netatmo CO2 change rate"
                  capabilities:
                    value_sensor:
                        value:
                          model: time series
                          entity: "hass>sensor_carbon_dioxide"
                          attribute: "value_sensor.value"
                          interval: 5
                          aggregate: accel
                          retention: 60
                          precision: 2
                  type: ValueSensor
        When I tried to drop "retention" and used "depth" instead, got the following error:
        Unable to configure time series "value_sensor.value" on "virtual9": missing required configuration 'retention'
        Controller: VirtualEntityController#virtual
        Last 15:56:17
        Looking at the entity values, there's "x_virtualentity.timeseries_depth=null", and if depth is needed in the calculation, that could be the culprit?
          You have to wait for the time series to fill before acceleration can be computed. depth is used in the calculation, as well as retention... that's a peculiarity of this aggregate (accel). There need to be at least 2*depth-1 samples collected before the calculation can occur.
          I have updated the documentation in the online version just yesterday, so check here.
            @toggledbits this configuration has been running for hours (retention being 60 min), and still "null"
              @tunnus OK. Let's start here: copy-paste the device attributes for that VEC entity (remember to use fenced code block formatting when pasting in reply).
                @toggledbits those were already in my previous post, or was something missing?
                  The previous post shows depth as null or not provided. Please specify both depth and retention, restart and wait at least one full interval, then copy-paste the attributes if a value hasn't been calculated.
                    @toggledbits ok, when I get back home I’ll try that. But wasn’t depth optional, i.e. defaults to 2 if not specified?
                      In the version you are using, it is still required; that's the docs leading the released code by a step (sorry). The version you are using also doesn't enforce limits well, so it allows values that could produce no result, or store more data than needed.
                      For example, given your retention of 60 and interval of 5, there would be r/i+1 = 13 samples in the series. But if you specify depth of 2, then only the most recent 2d-1 = 3 samples are considered... the other 10 samples don't contribute to the result value. A depth of 7 would be the best match for the given interval and retention (just mathematically, ignoring your semantic goals).
                        @toggledbits adding depth did the trick, thanks again!
                        • Next Release?
