  4. Difficulty defining repeating annual period
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 4 Posters 729 Views 4 Watching
    retireditguy
    wrote on last edited by retireditguy
    CatmanV2C G 2 Replies Last reply
    • R retireditguy
      @retireditguy Hmm, not sure if it's much help, or a parallel use case, but I have a couple of reactions that only work during the festive period. More explicitly there are additional actions which are constrained
      Here's one of my constraint groups which has been working fine this year and untouched since last year.
      And the second
        Can’t you just use “after Dec 15th” and then add an OR for just “before Jan 15th”?
        I have a global variable named ChristmasTime that’s set daily, so it’s easier to use in multiple reactions. Just a suggestion to simplify things.
          @therealdb oh that sounds like a neat idea. Might well upgrade to that. Thanks for the suggestion
          • R retireditguy
            @retireditguy here's my xmas which is tricky because it moves year-to-year based on starting the day after Thanksgiving:
            And here's my Thanksgiving which is tricky because it moves year-to-year, being based on the "fourth Thursday of November":
            And here's a more "traditional" one for a set date:
              162.9k
