  4. Reactor build 26116: empty group reaction
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
18 Posts 3 Posters 1.1k Views 3 Watching
    I have a couple of rules that has group reactions with empty conditions. I notice, in particular on one that's called every 5 secs, that it was not working. I added an empty comment as condition and it started working again.
    I don't know if saving was enough to "reset" it, but I'm reporting anyway. No errors in the logs, but the MQTT message was not published, so I had an easy path to check the rule.
    I have others like these, but not easy to test. @toggledbits maybe some stuck status data? (I restarted a couple of times after the last update). Thanks.
      Yes, I confirm the problem. I had to add a comment to a couple of empty groups.
        OK. Here's the release note I'm making on this for the next build:
        • The behavior of empty "group" conditions was changed in error. As of the next build, the behavior is as follows: group actions may have empty constraints (no conditions), and since this is not explicitly false, the group will be allowed to run; while actions may not have empty constraints (and this will be enforced by the UI/editor going forward), and if a legacy while action is encountered with no conditions, it will not execute (safe behavior). A disabled group or while action will not run.
          @toggledbits how does this pertain to rulesets that have Groups in Set Reaction for different "scenarios", if you will.
          Example:
          I'm asking because this ruleset stopped working with 26116 and I'm so strapped on personal time atm that I just broke it out into three sep rulesets and each works correctly.
          *Hubitat C-7 2.5.0.143
          Core 2026.5.3
          MSR: latest-26143-a81ae8ba
            Example:
            @gwp1 unrelated.
              @gwp1 unrelated.
              @toggledbits 👍
              I'll try to find a few minutes to grab logs. I gave a quick look and saw nothing screaming.
              Core 2026.5.3
                @toggledbits 👍
                @gwp1 Logs probably long gone if you've already modified the reaction. It would help to see the group in its original form, though.
                  @toggledbits I still have the ruleset, just disabled. Easy enough to disable the temporary ones and re-enable this one and try to trigger it. (I had a smart moment!)
                  Core 2026.5.3
                    @toggledbits fair enough. I’ve analyzed more than 100 rules and I fixed a bunch of them manually. I’ll update my second system with next build.
                      @toggledbits so, build 26120 has now a strange side effect: when I try to add a comment to an empty constraint list, the infamous "fix erros before saving" banner appears and I cannot make it to go away, no matter what constraints I add to the group. Thanks.
                        to be honest, I cannot edit any rule at the moment... every one fails with this message.
                          Ugh. So sorry. Working on it now.
                            OK. 26120 rebuilt with a UI fix and pushed. Update your container and let me know how it goes.
                              @toggledbits all good now. no need to apologize, thanks for your hard work!
                                @toggledbits maybe it's related, but right now I have a similar problem.
                                Given these groups:
                                in this case, all are called.
                                Forum extract - Party Mode false but both branches executed
                                Source: .vs/.tmp/logs/reactor.log
                                Date: 2026-05-05
                                === A) Sunset flow where both Party Mode OFF and Party Mode ON run ===
                                [latest-26120]2026-05-05T18:16:00.192Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/No vacation (rule-kwulsxqu:S-159bd6va)
                                [latest-26120]2026-05-05T18:16:00.206Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: OFF (rule-kwulsxqu:S-sjf1np7)
                                [latest-26120]2026-05-05T18:16:00.207Z <Engine:INFO> Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: OFF all actions completed.
                                [latest-26120]2026-05-05T18:16:00.207Z <Engine:INFO> Enqueueing "G-Lights-Outdoor-On-Sunset" (re-kwulrhc7)
                                [latest-26120]2026-05-05T18:16:00.243Z <Engine:NOTICE> Starting reaction G-Lights-Outdoor-On-Sunset (re-kwulrhc7)
                                [latest-26120]2026-05-05T18:16:00.244Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>89-2 with {  } by reaction G-Lights-Outdoor-On-Sunset (re-kwulrhc7) step 2
                                [latest-26120]2026-05-05T18:16:00.248Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: ON (rule-kwulsxqu:S-je98j75)
                                [latest-26120]2026-05-05T18:16:00.249Z <Engine:NOTICE> Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: ON delaying until 1778004965249<5/5/2026, 8:16:05 PM>
                                === B) Party Mode ON continuation triggers PartyMode and On-All scenes ===
                                [latest-26120]2026-05-05T18:16:05.250Z <Engine:INFO> Resuming reaction Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: ON (rule-kwulsxqu:S-je98j75) from step 2
                                [latest-26120]2026-05-05T18:16:05.251Z <Engine:INFO> Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: ON all actions completed.
                                [latest-26120]2026-05-05T18:16:05.251Z <Engine:INFO> Enqueueing "Lights-Outdoor-On-PartyMode<SET>" (rule-kwulj21d:S)
                                [latest-26120]2026-05-05T18:16:05.271Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-PartyMode<SET> (rule-kwulj21d:S)
                                [latest-26120]2026-05-05T18:16:05.271Z <Engine:INFO> Lights-Outdoor-On-PartyMode<SET> all actions completed.
                                [latest-26120]2026-05-05T18:16:05.288Z <Engine:INFO> Enqueueing "G-Lights-Outdoor-On-All" (re-kwueqcud)
                                [latest-26120]2026-05-05T18:16:05.303Z <Engine:NOTICE> Starting reaction G-Lights-Outdoor-On-All (re-kwueqcud)
                                [latest-26120]2026-05-05T18:16:05.304Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>169-1 with {  } by reaction G-Lights-Outdoor-On-All (re-kwueqcud) step 2
                                === C) Same Sunset rule run also enters Vacation branch ===
                                [latest-26120]2026-05-05T18:16:05.343Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/Vacation (rule-kwulsxqu:S-159bdlwb)
                                [latest-26120]2026-05-05T18:16:05.343Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>70-1 with {  } by reaction Lights-Outdoor-On-Sunset<SET>/Vacation (rule-kwulsxqu:S-159bdlwb) step 1
                                === D) Later retrigger (18:19) of G-Lights-Outdoor-On-Sunset ===
                                [latest-26120]2026-05-05T18:19:27.156Z <Engine:INFO> Enqueueing "G-Lights-Outdoor-On-Sunset" (re-kwulrhc7)
                                [latest-26120]2026-05-05T18:19:27.160Z <Engine:NOTICE> Starting reaction G-Lights-Outdoor-On-Sunset (re-kwulrhc7)
                                [latest-26120]2026-05-05T18:19:27.161Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>89-2 with {  } by reaction G-Lights-Outdoor-On-Sunset (re-kwulrhc7) step 2
                                [latest-26120]2026-05-05T18:19:27.597Z <Engine:NOTICE> Starting reaction G-Lights-Outdoor-On-Sunset/Green Mode (re-kwulrhc7-vxmf6qa)
                                [latest-26120]2026-05-05T18:19:27.598Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>89-1 with {  } by reaction G-Lights-Outdoor-On-Sunset/Green Mode (re-kwulrhc7-vxmf6qa) step 1
                                [latest-26120]2026-05-05T18:19:28.007Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>70-1 with {  } by reaction G-Lights-Outdoor-On-Sunset/Green Mode (re-kwulrhc7-vxmf6qa) step 2
                                [latest-26120]2026-05-05T18:19:28.104Z <Engine:NOTICE> Starting reaction G-Lights-Outdoor-On-Sunset/Terrazzo (re-kwulrhc7-v80fyx6)
                                [latest-26120]2026-05-05T18:19:28.105Z <Engine:INFO> Engine#1 perform power_switch.on on Switch#zwavejs>85-1 with {  } by reaction G-Lights-Outdoor-On-Sunset/Terrazzo (re-kwulrhc7-v80fyx6) step 1
                                === E) MQTT scene-related reevaluations nearby (possible retrigger context) ===
                                [latest-26120]2026-05-05T18:19:28.174Z <Rule:INFO> Rule#rule-l20ceesq re-evaluating local variable close for dependency notification from GlobalExpression#scenefrommqtt
                                [latest-26120]2026-05-05T18:19:28.175Z <Rule:INFO> Rule#rule-l3jpxetn re-evaluating local variable allup for dependency notification from GlobalExpression#scenefrommqtt
                                [latest-26120]2026-05-05T18:19:28.270Z <Rule:INFO> Tasks-MQTT-ResetScene (rule-l2vqcz3z in System Tasks) starting rule state evaluation; because predicate-state-changed Predicate#rule-l2vqcz3z/trig
                                [latest-26120]2026-05-05T18:19:28.271Z <Rule:INFO> Tasks-MQTT-ResetScene (rule-l2vqcz3z in System Tasks) evaluated; rule state transition from RESET to 'SET'
                                this rule group is inside another rule group.
                                  Build 26127 just posted has a small change that hit the issue responsible for the misbehavior. If not, there's additional logging that may help point me in the right direction.
                                    @toggledbits unfortunately, this is still occurring with the new build. here's the log:
                                    Reactor Support Report - Outdoor Lights Sunset Logic
                                    1) Dev instrumentation context before event
                                    [latest-26127]2026-05-07T18:06:07.950Z <Engine:INFO> Engine#1 performing startup eval of global partymode
                                    [latest-26127]2026-05-07T18:07:09.232Z <Rule:NOTICE> Lights-Outdoor-On-Sunset (rule-kwulsxqu in Lights-Outdoor) configuration changed; reloading
                                    [latest-26127]2026-05-07T18:07:09.232Z <Engine:INFO> Engine#1 rule Rule#rule-kwulsxqu changed; reloading and restarting it
                                    2) Sunset rule starts and enters No vacation
                                    [latest-26127]2026-05-07T18:07:37.303Z <Engine:INFO> Enqueueing "Lights-Outdoor-On-Sunset<SET>" (rule-kwulsxqu:S)
                                    [latest-26127]2026-05-07T18:07:37.307Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET> (rule-kwulsxqu:S)
                                    [latest-26127]2026-05-07T18:07:37.310Z <Rule:INFO> Rule#rule-kwulsxqu evaluating reaction group constraints No vacation (rule-kwulsxqu:S-159bdlwb-cons)
                                    [latest-26127]2026-05-07T18:07:37.319Z <Rule:INFO> Rule#rule-kwulsxqu reaction group No vacation (rule-kwulsxqu:S-159bdlwb-cons) constraints result=true
                                    3) Party Mode OFF evaluated true and executed
                                    [latest-26127]2026-05-07T18:07:37.334Z <Rule:INFO> Rule#rule-kwulsxqu evaluating reaction group constraints Party Mode: OFF (rule-kwulsxqu:S-sjf1np7-cons)
                                    [latest-26127]2026-05-07T18:07:37.337Z <Rule:INFO> Rule#rule-kwulsxqu reaction group Party Mode: OFF (rule-kwulsxqu:S-sjf1np7-cons) constraints result=true
                                    [latest-26127]2026-05-07T18:07:37.353Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: OFF (rule-kwulsxqu:S-sjf1np7)
                                    4) Party Mode ON also evaluated true in same flow
                                    [latest-26127]2026-05-07T18:08:17.332Z <Rule:INFO> Rule#rule-kwulsxqu evaluating reaction group constraints Party Mode: ON (rule-kwulsxqu:S-sjf1np7-cons)
                                    [latest-26127]2026-05-07T18:08:17.334Z <Rule:INFO> Rule#rule-kwulsxqu reaction group Party Mode: ON (rule-kwulsxqu:S-sjf1np7-cons) constraints result=true
                                    [latest-26127]2026-05-07T18:08:17.358Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/No vacation/Party Mode: ON (rule-kwulsxqu:S-je98j75)
                                    5) Follow-up party path triggers On-All scene
                                    [latest-26127]2026-05-07T18:08:22.377Z <Engine:INFO> Enqueueing "Lights-Outdoor-On-PartyMode<SET>" (rule-kwulj21d:S)
                                    [latest-26127]2026-05-07T18:08:22.508Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-PartyMode<SET> (rule-kwulj21d:S)
                                    [latest-26127]2026-05-07T18:08:22.525Z <Engine:INFO> Enqueueing "G-Lights-Outdoor-On-All" (re-kwueqcud)
                                    6) Same top-level run also executes Vacation branch
                                    [latest-26127]2026-05-07T18:08:22.585Z <Rule:INFO> Rule#rule-kwulsxqu evaluating reaction group constraints Vacation (rule-kwulsxqu:S-159bdlwb-cons)
                                    [latest-26127]2026-05-07T18:08:22.586Z <Rule:INFO> Rule#rule-kwulsxqu reaction group Vacation (rule-kwulsxqu:S-159bdlwb-cons) constraints result=true
                                    [latest-26127]2026-05-07T18:08:22.603Z <Engine:NOTICE> Starting reaction Lights-Outdoor-On-Sunset<SET>/Vacation (rule-kwulsxqu:S-159bdlwb)
                                    Dev Instrumentation Lines (Most Relevant)
                                    These are the strongest lines showing the engine handling multiple conflicting groups as true:
                                    [latest-26127]2026-05-07T18:07:37.320Z <Engine:INFO> Engine#1 reaction rule-kwulsxqu:S handling group No vacation (rule-kwulsxqu:S-159bd6va) constraints result state true
                                    [latest-26127]2026-05-07T18:07:37.339Z <Engine:INFO> Engine#1 reaction rule-kwulsxqu:S-159bd6va handling group Party Mode: OFF (rule-kwulsxqu:S-sjf1np7) constraints result state true
                                    [latest-26127]2026-05-07T18:08:17.334Z <Engine:INFO> Engine#1 reaction rule-kwulsxqu:S-159bd6va handling group Party Mode: ON (rule-kwulsxqu:S-je98j75) constraints result state true
                                    [latest-26127]2026-05-07T18:08:22.587Z <Engine:INFO> Engine#1 reaction rule-kwulsxqu:S handling group Vacation (rule-kwulsxqu:S-159bdlwb) constraints result state true
                                    Additional Context
                                    [latest-26127]2026-05-07T18:08:22.553Z <Engine:INFO> Engine#1 perform x_mqtt.publish ... topic "dbdomoticz/cmd/sceniclightsprogram" ... by reaction Lights-Outdoor-On-Sunset<SET>/No vacation
                                    [latest-26127]2026-05-07T18:08:22.372Z <Rule:INFO> Rule#rule-l20ceesq re-evaluating local variable close for dependency notification from GlobalExpression#scenefrommqtt
                                    [latest-26127]2026-05-07T18:08:22.374Z <Rule:INFO> Rule#rule-l3jpxetn re-evaluating local variable allup for dependency notification from GlobalExpression#scenefrommqtt
                                      OK. Please turn on log level 5 for that rule only. Run the rule to show the issue, and upload the entire Rule log file as well as reactor.log, the rule storage files (dval and json). Link for upload in your DMs
                                        119.0k
