  4. ReferenceError with Home Assistant data & build 26140
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
6 Posts 2 Posters 312 Views 2 Watching
    Did upgrade to MSR build 26140 on Docker, and now getting errors related to one hass integration that used to work ok with 26011.
    I have the following local expression:
    Still, in the entities that attribute has data (as it has had for a long time and the same expression was fine in 26011):
    string_sensor.value="14.445"
    value_sensor.units="c/kWh"
    value_sensor.value=14.445
    x_hass.area_id=null
    x_hass.domain="sensor"
    x_hass.entity_id="sensor.nordpool_kwh_fi_eur_3_10_0"
    x_hass.services=["sensor","nordpool"]
    x_hass.source="nordpool"
    x_hass.state="14.445"
    x_hass_attr.additional_costs_current_hour=0
    x_hass_attr.average=7.086739583333333
    x_hass_attr.country="Finland"
    x_hass_attr.currency="EUR"
    x_hass_attr.current_price=14.445
    x_hass_attr.device_class="monetary"
    x_hass_attr.friendly_name="nordpool"
    x_hass_attr.icon="mdi:flash"
    x_hass_attr.low_price=false
    x_hass_attr.max=14.555
    x_hass_attr.mean=5.6175
    x_hass_attr.min=1.188
    x_hass_attr.off_peak_1=2.9290000000000003
    x_hass_attr.off_peak_2=8.195105263157895
    x_hass_attr.peak=2.8389166666666665
    x_hass_attr.price_in_cents=true
    x_hass_attr.price_percent_to_average=2.0383139284491136
    x_hass_attr.raw_today=[{"start":"2026-05-21T00:00:00+03:00","end":"2026-05-21T00:15:00+03:00","value":3.982},{"start":"2026-05-21T00:15:00+03:00","end":"2026-05-21T00:30:00+03:00","value":3.183},{"start":"2026-05-21T00:30:00+03:00","end":"2026-05-21T00:45:00+03:00","value":2.991},{"start":"2026-05-21T00:45:00+03:00","end":"2026-05-21T01:00:00+03:00","value":2.588},{"start":"2026-05-21T01:00:00+03:00","end":"2026-05-21T01:15:00+03:00","value":2.797},{"start":"2026-05-21T01:15:00+03:00","end":"2026-05-21T01:30:00+03:00","value":2.653},{"start":"2026-05-21T01:30:00+03:00","end":"2026-05-21T01:45:00+03:00","value":2.797},{"start":"2026-05-21T01:45:00+03:00","end":"2026-05-21T02:00:00+03:00","value":2.441},{"start":"2026-05-21T02:00:00+03:00","end":"2026-05-21T02:15:00+03:00","value":2.255},{"start":"2026-05-21T02:15:00+03:00","end":"2026-05-21T02:30:00+03:00","value":2.791},{"start":"2026-05-21T02:30:00+03:00","end":"2026-05-21T02:45:00+03:00","value":2.87},{"start":"2026-05-21T02:45:00+03:00","end":"2026-05-21T03:00:00+03:00","value":3.231},{"start":"2026-05-21T03:00:00+03:00","end":"2026-05-21T03:15:00+03:00","value":2.793},{"start":"2026-05-21T03:15:00+03:00","end":"2026-05-21T03:30:00+03:00","value":2.999},{"start":"2026-05-21T03:30:00+03:00","end":"2026-05-21T03:45:00+03:00","value":2.851},{"start":"2026-05-21T03:45:00+03:00","end":"2026-05-21T04:00:00+03:00","value":2.814},{"start":"2026-05-21T04:00:00+03:00","end":"2026-05-21T04:15:00+03:00","value":2.389},{"start":"2026-05-21T04:15:00+03:00","end":"2026-05-21T04:30:00+03:00","value":2.793},{"start":"2026-05-21T04:30:00+03:00","end":"2026-05-21T04:45:00+03:00","value":2.9},{"start":"2026-05-21T04:45:00+03:00","end":"2026-05-21T05:00:00+03:00","value":3.381},{"start":"2026-05-21T05:00:00+03:00","end":"2026-05-21T05:15:00+03:00","value":2.84},{"start":"2026-05-21T05:15:00+03:00","end":"2026-05-21T05:30:00+03:00","value":3.735},{"start":"2026-05-21T05:30:00+03:00","end":"2026-05-21T05:45:00+03:00","value":4.999},{"start":"2026-05-21T05:45:00+03:00","end":"2026-05-21T06:00:00+03:00","value":5.689},{"start":"2026-05-21T06:00:00+03:00","end":"2026-05-21T06:15:00+03:00","value":2.838},{"start":"2026-05-21T06:15:00+03:00","end":"2026-05-21T06:30:00+03:00","value":4.999},{"start":"2026-05-21T06:30:00+03:00","end":"2026-05-21T06:45:00+03:00","value":6.19},{"start":"2026-05-21T06:45:00+03:00","end":"2026-05-21T07:00:00+03:00","value":10.661},{"start":"2026-05-21T07:00:00+03:00","end":"2026-05-21T07:15:00+03:00","value":1.188},{"start":"2026-05-21T07:15:00+03:00","end":"2026-05-21T07:30:00+03:00","value":4.259},{"start":"2026-05-21T07:30:00+03:00","end":"2026-05-21T07:45:00+03:00","value":9.804},{"start":"2026-05-21T07:45:00+03:00","end":"2026-05-21T08:00:00+03:00","value":13.01},{"start":"2026-05-21T08:00:00+03:00","end":"2026-05-21T08:15:00+03:00","value":10.39},{"start":"2026-05-21T08:15:00+03:00","end":"2026-05-21T08:30:00+03:00","value":10.726},{"start":"2026-05-21T08:30:00+03:00","end":"2026-05-21T08:45:00+03:00","value":12.032},{"start":"2026-05-21T08:45:00+03:00","end":"2026-05-21T09:00:00+03:00","value":12.654},{"start":"2026-05-21T09:00:00+03:00","end":"2026-05-21T09:15:00+03:00","value":12.743},{"start":"2026-05-21T09:15:00+03:00","end":"2026-05-21T09:30:00+03:00","value":11.514},{"start":"2026-05-21T09:30:00+03:00","end":"2026-05-21T09:45:00+03:00","value":10.952},{"start":"2026-05-21T09:45:00+03:00","end":"2026-05-21T10:00:00+03:00","value":10.273},{"start":"2026-05-21T10:00:00+03:00","end":"2026-05-21T10:15:00+03:00","value":11.009},{"start":"2026-05-21T10:15:00+03:00","end":"2026-05-21T10:30:00+03:00","value":9.09},{"start":"2026-05-21T10:30:00+03:00","end":"2026-05-21T10:45:00+03:00","value":8.448},{"start":"2026-05-21T10:45:00+03:00","end":"2026-05-21T11:00:00+03:00","value":7.698},{"start":"2026-05-21T11:00:00+03:00","end":"2026-05-21T11:15:00+03:00","value":9.599},{"start":"2026-05-21T11:15:00+03:00","end":"2026-05-21T11:30:00+03:00","value":8.059},{"start":"2026-05-21T11:30:00+03:00","end":"2026-05-21T11:45:00+03:00","value":6.586},{"start":"2026-05-21T11:45:00+03:00","end":"2026-05-21T12:00:00+03:00","value":5.546},{"start":"2026-05-21T12:00:00+03:00","end":"2026-05-21T12:15:00+03:00","value":7.348},{"start":"2026-05-21T12:15:00+03:00","end":"2026-05-21T12:30:00+03:00","value":5.544},{"start":"2026-05-21T12:30:00+03:00","end":"2026-05-21T12:45:00+03:00","value":4.164},{"start":"2026-05-21T12:45:00+03:00","end":"2026-05-21T13:00:00+03:00","value":3},{"start":"2026-05-21T13:00:00+03:00","end":"2026-05-21T13:15:00+03:00","value":5.23},{"start":"2026-05-21T13:15:00+03:00","end":"2026-05-21T13:30:00+03:00","value":4.887},{"start":"2026-05-21T13:30:00+03:00","end":"2026-05-21T13:45:00+03:00","value":3.942},{"start":"2026-05-21T13:45:00+03:00","end":"2026-05-21T14:00:00+03:00","value":2.924},{"start":"2026-05-21T14:00:00+03:00","end":"2026-05-21T14:15:00+03:00","value":4.408},{"start":"2026-05-21T14:15:00+03:00","end":"2026-05-21T14:30:00+03:00","value":4.004},{"start":"2026-05-21T14:30:00+03:00","end":"2026-05-21T14:45:00+03:00","value":3.398},{"start":"2026-05-21T14:45:00+03:00","end":"2026-05-21T15:00:00+03:00","value":3.082},{"start":"2026-05-21T15:00:00+03:00","end":"2026-05-21T15:15:00+03:00","value":3.071},{"start":"2026-05-21T15:15:00+03:00","end":"2026-05-21T15:30:00+03:00","value":3.753},{"start":"2026-05-21T15:30:00+03:00","end":"2026-05-21T15:45:00+03:00","value":3.429},{"start":"2026-05-21T15:45:00+03:00","end":"2026-05-21T16:00:00+03:00","value":3.114},{"start":"2026-05-21T16:00:00+03:00","end":"2026-05-21T16:15:00+03:00","value":2.647},{"start":"2026-05-21T16:15:00+03:00","end":"2026-05-21T16:30:00+03:00","value":2.456},{"start":"2026-05-21T16:30:00+03:00","end":"2026-05-21T16:45:00+03:00","value":4.836},{"start":"2026-05-21T16:45:00+03:00","end":"2026-05-21T17:00:00+03:00","value":6.734},{"start":"2026-05-21T17:00:00+03:00","end":"2026-05-21T17:15:00+03:00","value":2.741},{"start":"2026-05-21T17:15:00+03:00","end":"2026-05-21T17:30:00+03:00","value":6.63},{"start":"2026-05-21T17:30:00+03:00","end":"2026-05-21T17:45:00+03:00","value":8.838},{"start":"2026-05-21T17:45:00+03:00","end":"2026-05-21T18:00:00+03:00","value":9.839},{"start":"2026-05-21T18:00:00+03:00","end":"2026-05-21T18:15:00+03:00","value":5.414},{"start":"2026-05-21T18:15:00+03:00","end":"2026-05-21T18:30:00+03:00","value":8.412},{"start":"2026-05-21T18:30:00+03:00","end":"2026-05-21T18:45:00+03:00","value":10.386},{"start":"2026-05-21T18:45:00+03:00","end":"2026-05-21T19:00:00+03:00","value":11.874},{"start":"2026-05-21T19:00:00+03:00","end":"2026-05-21T19:15:00+03:00","value":10.273},{"start":"2026-05-21T19:15:00+03:00","end":"2026-05-21T19:30:00+03:00","value":10.775},{"start":"2026-05-21T19:30:00+03:00","end":"2026-05-21T19:45:00+03:00","value":12.398},{"start":"2026-05-21T19:45:00+03:00","end":"2026-05-21T20:00:00+03:00","value":14.145},{"start":"2026-05-21T20:00:00+03:00","end":"2026-05-21T20:15:00+03:00","value":11.399},{"start":"2026-05-21T20:15:00+03:00","end":"2026-05-21T20:30:00+03:00","value":11.592},{"start":"2026-05-21T20:30:00+03:00","end":"2026-05-21T20:45:00+03:00","value":12.992},{"start":"2026-05-21T20:45:00+03:00","end":"2026-05-21T21:00:00+03:00","value":14.555},{"start":"2026-05-21T21:00:00+03:00","end":"2026-05-21T21:15:00+03:00","value":13.434},{"start":"2026-05-21T21:15:00+03:00","end":"2026-05-21T21:30:00+03:00","value":13.697},{"start":"2026-05-21T21:30:00+03:00","end":"2026-05-21T21:45:00+03:00","value":13.671},{"start":"2026-05-21T21:45:00+03:00","end":"2026-05-21T22:00:00+03:00","value":13.851},{"start":"2026-05-21T22:00:00+03:00","end":"2026-05-21T22:15:00+03:00","value":13.753},{"start":"2026-05-21T22:15:00+03:00","end":"2026-05-21T22:30:00+03:00","value":13.662},{"start":"2026-05-21T22:30:00+03:00","end":"2026-05-21T22:45:00+03:00","value":12.542},{"start":"2026-05-21T22:45:00+03:00","end":"2026-05-21T23:00:00+03:00","value":10.853},{"start":"2026-05-21T23:00:00+03:00","end":"2026-05-21T23:15:00+03:00","value":14.445},{"start":"2026-05-21T23:15:00+03:00","end":"2026-05-21T23:30:00+03:00","value":12.675},{"start":"2026-05-21T23:30:00+03:00","end":"2026-05-21T23:45:00+03:00","value":10.164},{"start":"2026-05-21T23:45:00+03:00","end":"2026-05-22T00:00:00+03:00","value":8.316}]
    x_hass_attr.raw_tomorrow=[{"start":"2026-05-22T00:00:00+03:00","end":"2026-05-22T00:15:00+03:00","value":11.153},{"start":"2026-05-22T00:15:00+03:00","end":"2026-05-22T00:30:00+03:00","value":8.285},{"start":"2026-05-22T00:30:00+03:00","end":"2026-05-22T00:45:00+03:00","value":6.982},{"start":"2026-05-22T00:45:00+03:00","end":"2026-05-22T01:00:00+03:00","value":6.393},{"start":"2026-05-22T01:00:00+03:00","end":"2026-05-22T01:15:00+03:00","value":7.771},{"start":"2026-05-22T01:15:00+03:00","end":"2026-05-22T01:30:00+03:00","value":7.223},{"start":"2026-05-22T01:30:00+03:00","end":"2026-05-22T01:45:00+03:00","value":6.893},{"start":"2026-05-22T01:45:00+03:00","end":"2026-05-22T02:00:00+03:00","value":6.303},{"start":"2026-05-22T02:00:00+03:00","end":"2026-05-22T02:15:00+03:00","value":7.21},{"start":"2026-05-22T02:15:00+03:00","end":"2026-05-22T02:30:00+03:00","value":6.925},{"start":"2026-05-22T02:30:00+03:00","end":"2026-05-22T02:45:00+03:00","value":6.774},{"start":"2026-05-22T02:45:00+03:00","end":"2026-05-22T03:00:00+03:00","value":6.661},{"start":"2026-05-22T03:00:00+03:00","end":"2026-05-22T03:15:00+03:00","value":6.927},{"start":"2026-05-22T03:15:00+03:00","end":"2026-05-22T03:30:00+03:00","value":6.876},{"start":"2026-05-22T03:30:00+03:00","end":"2026-05-22T03:45:00+03:00","value":6.769},{"start":"2026-05-22T03:45:00+03:00","end":"2026-05-22T04:00:00+03:00","value":6.89},{"start":"2026-05-22T04:00:00+03:00","end":"2026-05-22T04:15:00+03:00","value":7.25},{"start":"2026-05-22T04:15:00+03:00","end":"2026-05-22T04:30:00+03:00","value":6.887},{"start":"2026-05-22T04:30:00+03:00","end":"2026-05-22T04:45:00+03:00","value":6.74},{"start":"2026-05-22T04:45:00+03:00","end":"2026-05-22T05:00:00+03:00","value":6.724},{"start":"2026-05-22T05:00:00+03:00","end":"2026-05-22T05:15:00+03:00","value":6.679},{"start":"2026-05-22T05:15:00+03:00","end":"2026-05-22T05:30:00+03:00","value":6.786},{"start":"2026-05-22T05:30:00+03:00","end":"2026-05-22T05:45:00+03:00","value":6.762},{"start":"2026-05-22T05:45:00+03:00","end":"2026-05-22T06:00:00+03:00","value":7.254},{"start":"2026-05-22T06:00:00+03:00","end":"2026-05-22T06:15:00+03:00","value":8.086},{"start":"2026-05-22T06:15:00+03:00","end":"2026-05-22T06:30:00+03:00","value":8.887},{"start":"2026-05-22T06:30:00+03:00","end":"2026-05-22T06:45:00+03:00","value":9.137},{"start":"2026-05-22T06:45:00+03:00","end":"2026-05-22T07:00:00+03:00","value":12.066},{"start":"2026-05-22T07:00:00+03:00","end":"2026-05-22T07:15:00+03:00","value":9.283},{"start":"2026-05-22T07:15:00+03:00","end":"2026-05-22T07:30:00+03:00","value":11.21},{"start":"2026-05-22T07:30:00+03:00","end":"2026-05-22T07:45:00+03:00","value":12.509},{"start":"2026-05-22T07:45:00+03:00","end":"2026-05-22T08:00:00+03:00","value":13.006},{"start":"2026-05-22T08:00:00+03:00","end":"2026-05-22T08:15:00+03:00","value":12.383},{"start":"2026-05-22T08:15:00+03:00","end":"2026-05-22T08:30:00+03:00","value":13.465},{"start":"2026-05-22T08:30:00+03:00","end":"2026-05-22T08:45:00+03:00","value":12.571},{"start":"2026-05-22T08:45:00+03:00","end":"2026-05-22T09:00:00+03:00","value":11.12},{"start":"2026-05-22T09:00:00+03:00","end":"2026-05-22T09:15:00+03:00","value":13.85},{"start":"2026-05-22T09:15:00+03:00","end":"2026-05-22T09:30:00+03:00","value":12.649},{"start":"2026-05-22T09:30:00+03:00","end":"2026-05-22T09:45:00+03:00","value":11.639},{"start":"2026-05-22T09:45:00+03:00","end":"2026-05-22T10:00:00+03:00","value":9.4},{"start":"2026-05-22T10:00:00+03:00","end":"2026-05-22T10:15:00+03:00","value":11.78},{"start":"2026-05-22T10:15:00+03:00","end":"2026-05-22T10:30:00+03:00","value":10.428},{"start":"2026-05-22T10:30:00+03:00","end":"2026-05-22T10:45:00+03:00","value":7.958},{"start":"2026-05-22T10:45:00+03:00","end":"2026-05-22T11:00:00+03:00","value":5.408},{"start":"2026-05-22T11:00:00+03:00","end":"2026-05-22T11:15:00+03:00","value":9.257},{"start":"2026-05-22T11:15:00+03:00","end":"2026-05-22T11:30:00+03:00","value":6.292},{"start":"2026-05-22T11:30:00+03:00","end":"2026-05-22T11:45:00+03:00","value":1.849},{"start":"2026-05-22T11:45:00+03:00","end":"2026-05-22T12:00:00+03:00","value":1.618},{"start":"2026-05-22T12:00:00+03:00","end":"2026-05-22T12:15:00+03:00","value":4.873},{"start":"2026-05-22T12:15:00+03:00","end":"2026-05-22T12:30:00+03:00","value":4.017},{"start":"2026-05-22T12:30:00+03:00","end":"2026-05-22T12:45:00+03:00","value":3.653},{"start":"2026-05-22T12:45:00+03:00","end":"2026-05-22T13:00:00+03:00","value":2.654},{"start":"2026-05-22T13:00:00+03:00","end":"2026-05-22T13:15:00+03:00","value":3.284},{"start":"2026-05-22T13:15:00+03:00","end":"2026-05-22T13:30:00+03:00","value":3.198},{"start":"2026-05-22T13:30:00+03:00","end":"2026-05-22T13:45:00+03:00","value":2.795},{"start":"2026-05-22T13:45:00+03:00","end":"2026-05-22T14:00:00+03:00","value":2.256},{"start":"2026-05-22T14:00:00+03:00","end":"2026-05-22T14:15:00+03:00","value":3.038},{"start":"2026-05-22T14:15:00+03:00","end":"2026-05-22T14:30:00+03:00","value":2.813},{"start":"2026-05-22T14:30:00+03:00","end":"2026-05-22T14:45:00+03:00","value":2.384},{"start":"2026-05-22T14:45:00+03:00","end":"2026-05-22T15:00:00+03:00","value":2.063},{"start":"2026-05-22T15:00:00+03:00","end":"2026-05-22T15:15:00+03:00","value":2.467},{"start":"2026-05-22T15:15:00+03:00","end":"2026-05-22T15:30:00+03:00","value":2.154},{"start":"2026-05-22T15:30:00+03:00","end":"2026-05-22T15:45:00+03:00","value":1.811},{"start":"2026-05-22T15:45:00+03:00","end":"2026-05-22T16:00:00+03:00","value":1.7},{"start":"2026-05-22T16:00:00+03:00","end":"2026-05-22T16:15:00+03:00","value":1.592},{"start":"2026-05-22T16:15:00+03:00","end":"2026-05-22T16:30:00+03:00","value":1.61},{"start":"2026-05-22T16:30:00+03:00","end":"2026-05-22T16:45:00+03:00","value":2.401},{"start":"2026-05-22T16:45:00+03:00","end":"2026-05-22T17:00:00+03:00","value":5.093},{"start":"2026-05-22T17:00:00+03:00","end":"2026-05-22T17:15:00+03:00","value":1.653},{"start":"2026-05-22T17:15:00+03:00","end":"2026-05-22T17:30:00+03:00","value":4.982},{"start":"2026-05-22T17:30:00+03:00","end":"2026-05-22T17:45:00+03:00","value":6.284},{"start":"2026-05-22T17:45:00+03:00","end":"2026-05-22T18:00:00+03:00","value":7.819},{"start":"2026-05-22T18:00:00+03:00","end":"2026-05-22T18:15:00+03:00","value":3.799},{"start":"2026-05-22T18:15:00+03:00","end":"2026-05-22T18:30:00+03:00","value":6.367},{"start":"2026-05-22T18:30:00+03:00","end":"2026-05-22T18:45:00+03:00","value":7.77},{"start":"2026-05-22T18:45:00+03:00","end":"2026-05-22T19:00:00+03:00","value":10.393},{"start":"2026-05-22T19:00:00+03:00","end":"2026-05-22T19:15:00+03:00","value":7.398},{"start":"2026-05-22T19:15:00+03:00","end":"2026-05-22T19:30:00+03:00","value":9.333},{"start":"2026-05-22T19:30:00+03:00","end":"2026-05-22T19:45:00+03:00","value":9.592},{"start":"2026-05-22T19:45:00+03:00","end":"2026-05-22T20:00:00+03:00","value":10.373},{"start":"2026-05-22T20:00:00+03:00","end":"2026-05-22T20:15:00+03:00","value":8.903},{"start":"2026-05-22T20:15:00+03:00","end":"2026-05-22T20:30:00+03:00","value":10.05},{"start":"2026-05-22T20:30:00+03:00","end":"2026-05-22T20:45:00+03:00","value":10.554},{"start":"2026-05-22T20:45:00+03:00","end":"2026-05-22T21:00:00+03:00","value":12.48},{"start":"2026-05-22T21:00:00+03:00","end":"2026-05-22T21:15:00+03:00","value":11.535},{"start":"2026-05-22T21:15:00+03:00","end":"2026-05-22T21:30:00+03:00","value":10.789},{"start":"2026-05-22T21:30:00+03:00","end":"2026-05-22T21:45:00+03:00","value":10.554},{"start":"2026-05-22T21:45:00+03:00","end":"2026-05-22T22:00:00+03:00","value":7.576},{"start":"2026-05-22T22:00:00+03:00","end":"2026-05-22T22:15:00+03:00","value":13.341},{"start":"2026-05-22T22:15:00+03:00","end":"2026-05-22T22:30:00+03:00","value":10.832},{"start":"2026-05-22T22:30:00+03:00","end":"2026-05-22T22:45:00+03:00","value":8.376},{"start":"2026-05-22T22:45:00+03:00","end":"2026-05-22T23:00:00+03:00","value":7.646},{"start":"2026-05-22T23:00:00+03:00","end":"2026-05-22T23:15:00+03:00","value":9.674},{"start":"2026-05-22T23:15:00+03:00","end":"2026-05-22T23:30:00+03:00","value":4.999},{"start":"2026-05-22T23:30:00+03:00","end":"2026-05-22T23:45:00+03:00","value":3},{"start":"2026-05-22T23:45:00+03:00","end":"2026-05-23T00:00:00+03:00","value":1.146}]
    x_hass_attr.region="FI"
    x_hass_attr.restored=true
    x_hass_attr.state_class="total"
    x_hass_attr.supported_features=0
    x_hass_attr.today=[3.982,3.183,2.991,2.588,2.797,2.653,2.797,2.441,2.255,2.791,2.87,3.231,2.793,2.999,2.851,2.814,2.389,2.793,2.9,3.381,2.84,3.735,4.999,5.689,2.838,4.999,6.19,10.661,1.188,4.259,9.804,13.01,10.39,10.726,12.032,12.654,12.743,11.514,10.952,10.273,11.009,9.09,8.448,7.698,9.599,8.059,6.586,5.546,7.348,5.544,4.164,3,5.23,4.887,3.942,2.924,4.408,4.004,3.398,3.082,3.071,3.753,3.429,3.114,2.647,2.456,4.836,6.734,2.741,6.63,8.838,9.839,5.414,8.412,10.386,11.874,10.273,10.775,12.398,14.145,11.399,11.592,12.992,14.555,13.434,13.697,13.671,13.851,13.753,13.662,12.542,10.853,14.445,12.675,10.164,8.316]
    x_hass_attr.tomorrow=[11.153,8.285,6.982,6.393,7.771,7.223,6.893,6.303,7.21,6.925,6.774,6.661,6.927,6.876,6.769,6.89,7.25,6.887,6.74,6.724,6.679,6.786,6.762,7.254,8.086,8.887,9.137,12.066,9.283,11.21,12.509,13.006,12.383,13.465,12.571,11.12,13.85,12.649,11.639,9.4,11.78,10.428,7.958,5.408,9.257,6.292,1.849,1.618,4.873,4.017,3.653,2.654,3.284,3.198,2.795,2.256,3.038,2.813,2.384,2.063,2.467,2.154,1.811,1.7,1.592,1.61,2.401,5.093,1.653,4.982,6.284,7.819,3.799,6.367,7.77,10.393,7.398,9.333,9.592,10.373,8.903,10.05,10.554,12.48,11.535,10.789,10.554,7.576,13.341,10.832,8.376,7.646,9.674,4.999,3,1.146]
    x_hass_attr.tomorrow_valid=true
    x_hass_attr.unit="kWh"
    x_hass_attr.unit_of_measurement="c/kWh"
    As the only thing that has changed is MSR build, I suspect some array handling could be different? I might be completely mistaken, but cannot solve this currently on my own.
      x_hass.area_id=null
      Some additional information to this case, as if I create a variable with "getEntity", but don't tick the box "Use Name", there's no error:
        It looks like the entity ID changed on the HA side. That, or something else in your world is now named "Nordpool", and it's finding that one first. Go to the Entities list and (name) filter for /^nordpool$/i. If it finds more than one entity, you'll need to change the name of one of them.
          @toggledbits you're right, there's now a new entity "Nordpool" (with a capital N), that appeared after upgrading to 26140:
            Easiest/quickest is to just change the name of the integration entity.
            Or, you can filter out the entity in your HassController config:
              - id: hass
                enabled: true
                name: Home Assistant
                  # ...other stuff...
                  filter_entity:
                    "integration_01J9VP...etc": true  # filter out integration with specified ID
                    "/^integration_/i": true  # filter out all integration entities
                - id: hass
                  enabled: true
                    # ...other stuff...
                    filter_entity:
              @toggledbits got it, thanks!
                114.6k
