  4. [Solved] build 26150 - engine not starting
8 Posts 2 Posters 780 Views 2 Watching
    @toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline.
    The log looks like it ends with 26143.
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons
    [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons
    [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped
    [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs...
    [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing...
    [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing)
    [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing...
    [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed
    [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed.
    [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers...
    [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1
    [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs...
    [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log
    I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
    *Hubitat C-7 2.5.2.135
    Core 2026.10.1
    MSR: latest-26287-0a7107d5
      Following up here, did a backup restore of my Portainer VM from 05/29 (most recent) and MSR is back on 26143.
      Core 2026.10.1
        Huh. I'm running the 26150 amd64 container with no issue... sure would be nice to have logs. If you go for them, startup is where it's at, and you may need to look at the container syslog if an error is being thrown before the logger is up and running. Some early message get written to the console, and that usually ends up directed to the system logs.
        G 2 Replies Last reply
          @toggledbits if I have time here I'll try to pull the image again and capture logging.
          Core 2026.10.1
            @toggledbits Repulled, same thing happened: unreachable.
            2026-05-31T19:33:04.533976919Z     at wrapModuleLoad (node:internal/modules/cjs/loader:255:19)
            2026-05-31T19:33:04.533978974Z     at Module.require (node:internal/modules/cjs/loader:1600:12)
            2026-05-31T19:33:04.533980967Z     at require (node:internal/modules/helpers:153:16)
            2026-05-31T19:33:04.533983008Z
            2026-05-31T19:33:04.533984917Z Node.js v24.16.0
            2026-05-31T19:33:56.035775922Z Reactor latest-26150-7b86db04 app 26150 configuration from /var/reactor/config
            2026-05-31T19:33:56.053129729Z NODE_PATH /opt/reactor:/opt/reactor/node_modules
            2026-05-31T19:33:56.054371749Z Failed to parse /var/reactor/config/logging.yaml YAMLException: bad indentation of a mapping entry in "/var/reactor/config/logging.yaml" (56:34)
            2026-05-31T19:33:56.054391711Z
            2026-05-31T19:33:56.054396228Z  53 |     - type: file  # filename is derived from rule ID
            2026-05-31T19:33:56.054399741Z  54 |       keep: 2
            2026-05-31T19:33:56.054402822Z  55 |       level: 999
            2026-05-31T19:33:56.054405736Z  56 |       recycle: true#      recycle: true
            2026-05-31T19:33:56.054408789Z ---------------------------------------^
            2026-05-31T19:33:56.054456413Z At about line 55; near
            2026-05-31T19:33:56.054461049Z    >    level: 5
            2026-05-31T19:33:56.054464372Z    >    streams:
            2026-05-31T19:33:56.054509289Z    >    - type: file  # filename is derived from rule ID
            2026-05-31T19:33:56.054513314Z    >      keep: 2
            2026-05-31T19:33:56.054515586Z    >      level: 999
            2026-05-31T19:33:56.054517599Z    >      recycle: true#      recycle: true
            2026-05-31T19:33:56.054478049Z Use https://yamlvalidator.com/ and correct all indicated errors.
            2026-05-31T19:33:56.054522741Z failed to read configuration file /var/reactor/config/logging.yaml; attemping last-known-good
            2026-05-31T19:33:56.054619109Z unable to load configuration data for logging
            2026-05-31T19:33:56.056778406Z /opt/reactor/server/lib/Logger.js:429
            2026-05-31T19:33:56.056793267Z         const _0x98a8e2 = a22_0xf250f4, _0x36af7e = log_config['getConfig'](_0x98a8e2(0x14d), _0x98a8e2(0xfd), {});
            2026-05-31T19:33:56.056795940Z                                                               ^
            2026-05-31T19:33:56.056798247Z
            2026-05-31T19:33:56.056800114Z TypeError: Cannot read properties of undefined (reading 'getConfig')
            2026-05-31T19:33:56.056801991Z     at Logger.getLogger (/opt/reactor/server/lib/Logger.js:429:63)
            2026-05-31T19:33:56.056803906Z     at Logger.getDefaultLogger (/opt/reactor/server/lib/Logger.js:460:40)
            2026-05-31T19:33:56.056805752Z     at Object.<anonymous> (/opt/reactor/server/lib/Logger.js:761:619)
            2026-05-31T19:33:56.056807789Z     at Module._compile (node:internal/modules/cjs/loader:1854:14)
            2026-05-31T19:33:56.056809659Z     at Object..js (node:internal/modules/cjs/loader:1985:10)
            2026-05-31T19:33:56.056811482Z     at Module.load (node:internal/modules/cjs/loader:1577:32)
            2026-05-31T19:33:56.056813567Z     at Module._load (node:internal/modules/cjs/loader:1379:12)
            2026-05-31T19:33:56.056815388Z     at wrapModuleLoad (node:internal/modules/cjs/loader:255:19)
            2026-05-31T19:33:56.056817221Z     at Module.require (node:internal/modules/cjs/loader:1600:12)
            2026-05-31T19:33:56.056819018Z     at require (node:internal/modules/helpers:153:16)
            2026-05-31T19:33:56.056820871Z
            2026-05-31T19:33:56.056822616Z Node.js v24.16.0
            This is what the container logs show.
            Core 2026.10.1
              Did you read the log entries? Pretty strong starting point there...
              The logs are showing that your logging.yaml has an unrecoverable error. First, check to make sure you have only spaces, no tabs, for indenting.
              If that's not it, indent the - type: file line two spaces, as well as the keep, level, and recycle lines that follow it.
                @toggledbits I checked, rechecked, RErechecked and couldn't find any issue with that YAML.
                That being said, I completely removed the extra rule logging I had added and restarted. Brought down the new image and everything is fine.
                So... my question NOW is: why did it run fine until this build? That logging has been there for several weeks.
                Core 2026.10.1
                  @gwp1 said in [Solved] build 26150 - engine not starting:
                  Upload it to me, I'd like to take a look.
                  No idea. But, having once gotten a clean startup, it now has a last known good version of that config file, so whatever it's not happy with won't prevent startup in future.
                    1.0k
                    148.6k
