  4. [RESOLVED] HTTP query failing after version 26177
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 480 Views 2 Watching
  • wmarcolinW Offline
    Hi @toggledbits
    The HTTP query below worked perfectly in Set Reaction
    https://api.open-meteo.com/v1/forecast?latitude=9.0714&longitude=-79.3834&daily=precipitation_sum&timezone=America%2FChicago&past_days=6&forecast_days=0
    And when performed directly in the browser, it returns the information correctly
    However, now with the new version 26177, the response is null.
    Log.
    [latest-26177]2026-06-28T00:38:17.105Z <OWMWeatherController:null> Module OWMWeatherController v25268
    [latest-26177]2026-06-28T00:38:17.113Z <NUTController:null> Module NUTController v25026
    [latest-26177]2026-06-28T00:38:17.119Z <SystemController:null> Module SystemController v25330
    [latest-26177]2026-06-28T00:38:17.191Z <HassController:ERR> HassController#hass implementation data has no/empty mapping section; supplying default mapping
    [latest-26177]2026-06-28T00:38:17.234Z <DynamicGroupController:WARN> DynamicGroupController#groups group dgc_Device_IMOTION attempts to include entity hubitat>50; not found
    [latest-26177]2026-06-28T00:38:17.526Z <Engine:ERR> Engine#1: error evaluating expression HistShow: [ReferenceError] Invalid scope in reference to member daily of (object)null [-]
    [latest-26177]2026-06-28T00:38:17.526Z <Engine:ERR> Engine#1: expression: join((each i in 5..0 :
            format( "{0} {1} {2:4.1f}mm<br>",
              substr(HistPrecipitation.daily.time[i],8,2),
              if HistPrecipitation.daily.precipitation_sum[i] <= 2
                then "💦" else "🌧️" endif,
              HistPrecipitation.daily.precipitation_sum[i])), " ")
    [latest-26177]2026-06-28T00:38:17.526Z <Engine:CRIT> ReferenceError: Invalid scope in reference to member daily of (object)null [-]
        at _run (/home/wilson/reactor/common/lexp.js:1611:31)
        at _run (/home/wilson/reactor/common/lexp.js:1605:33)
        at /home/wilson/reactor/common/lexp.js:1702:33
        at _run (/home/wilson/reactor/common/lexp.js:1701:28)
        at _run (/home/wilson/reactor/common/lexp.js:1725:41)
    [latest-26177]2026-06-28T00:38:17.530Z <Engine:ERR> Engine#1: error evaluating expression HistLastRain: [ReferenceError] Invalid scope in reference to member daily of (object)null [-]
    [latest-26177]2026-06-28T00:38:17.530Z <Engine:ERR> Engine#1: expression: if HistPrecipitation.daily.precipitation_sum[5] > 2
      then format( "{0} {1} {2:4.1f}mm", substr(HistPrecipitation.daily.time[5],8,2),
                   "🌧️", HistPrecipitation.daily.precipitation_sum[5])
      else
        HistLastRain
    endif
    [latest-26177]2026-06-28T00:38:17.530Z <Engine:CRIT> ReferenceError: Invalid scope in reference to member daily of (object)null [-]
        at _run (/home/wilson/reactor/common/lexp.js:1436:34)
        at _run (/home/wilson/reactor/common/lexp.js:1623:26)
        at /home/wilson/reactor/common/lexp.js:1426:29
        at _run (/home/wilson/reactor/common/lexp.js:1425:28)
        at Object.run (/home/wilson/reactor/common/lexp.js:1855:24)
        at Engine._eval_expr (/home/wilson/reactor/server/lib/Engine.js:1235:165)
    [latest-26177]2026-06-28T00:38:17.870Z <NUTController:ERR> NUTController#nut unable to establish communication with "192.168.1.6":3493: [Error] connect ECONNREFUSED 192.168.1.6:3493 [-]
    [latest-26177]2026-06-28T00:38:17.935Z <app:ERR> Trapped unhandled Promise rejection: [FetchError] Invalid response body while trying to fetch http://192.168.1.15/apps/api/8/modes?access_token=e6d0afa6-caad-4f01-a0f3-e>
    [latest-26177]2026-06-28T00:38:17.935Z <app:CRIT> FetchError: Invalid response body while trying to fetch http://192.168.1.15/apps/api/8/modes?access_token=e6d0afa6-caad-4f01-a0f3-e27bb8098221: Premature close [-]
        at PassThrough.<anonymous> (/home/wilson/reactor/node_modules/node-fetch/lib/index.js:217:52)
        at PassThrough.emit (node:events:509:28)
      Your post should ideally indicate if your runtime is bare-metal or docker, and the OS and architecture being used, because I can't keep that kind of info in memory. If you're bare-metal, make sure you've updated packages npm run deps.
      Most of the errors you are showing are expression errors downstream of the HTTP request, so that's not really showing me anything useful. The last two lines are suspicious, though... NUTController isn't able to establish a connection with the NUT service, saying that the server is reachable but it refused the connection. Right after is an attempted query apparently to a Hubitat hub that fails with the connection closing before the response is complete. This looks more to me like you're having other network-related issues.
      While you say you can run successful queries from the browser, if that browser isn't on the same IP address as the Reactor instance, it's not a great test of network reachability for this. What you need to do is run a curl query from the Reactor host system; if that's a docker container, you need to attach your console to the container and run curl from within the container (e.g. docker exec -it reactor /bin/sh).
      I am, of course, running 26177 for my house, and use a lot of HTTP requests (e.g. most of my Blue Iris control). No issues for me. I am able to run your query URL from an HTTP Request action and get a valid response to a global variable (advanced response format shown here):
      {"ok":true,"status":200,"message":"OK","data":{"latitude":9.033392,"longitude":-79.41177,"generationtime_ms":0.023484230041503906,"utc_offset_seconds":-18000,"timezone":"America/Chicago","timezone_abbreviation":"GMT-5","elevation":12,"daily_units":{"time":"iso8601","precipitation_sum":"mm"},"daily":{"time":["2026-06-22","2026-06-23","2026-06-24","2026-06-25","2026-06-26","2026-06-27"],"precipitation_sum":[16.6,6.1,2.2,4.4,8.2,0.1]}}}
        After updating Node.js, the query is working.
          163.4k
