  4. [RESOLVED] Telegram notification broke with latest update
11 Posts 4 Posters 1.2k Views 4 Watching
  • 3 Offline
    3 Offline
    Running MSR "latest-26174-bd90c17c" via a docker within unRAID. With this latest docker update a day or two ago, Telegram stopped working. In looking at the logs, the ultimate error is that the chat_id is missing. I verified that my chat ID is still noted within the notifications YAML, but the reactor log still shows it failing. If I manually paste the chat ID into the notification field in the GUI, MSR will send the telegram message. It appears to be ignoring the "If left blank, the profile's default_chat_id value will be used."
    Error log
    [latest-26174]2026-06-26T18:04:45.814Z <Engine:INFO> Enqueueing "rule-2ajie2fd<SET>" (rule-2ajie2fd:S)
    [latest-26174]2026-06-26T18:04:45.815Z <Engine:NOTICE> Starting reaction rule-2ajie2fd<SET> (rule-2ajie2fd:S)
    [latest-26174]2026-06-26T18:04:45.815Z <Engine:INFO> rule-2ajie2fd<SET> all actions completed.
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:ERR> NotifyTelegram failure response from endpoint: 400 Bad Request
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:INFO> NotifyTelegram request URL: https://api.telegram.org/bot[[REDACTED]]:[[REDACTED]]/sendMessage
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:INFO> NotifyTelegram request body: {"text":"Test message","chat_id":""}
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:INFO> NotifyTelegram request headers: { "content-type": "application/json", "content-length": (undefined) }
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:ERR> NotifyTelegram request to https://api.telegram.org/bot[[REDACTED]]:[[REDACTED]]/sendMessage message Test message
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:CRIT> Error: NotifyTelegram request failed [-]
        at NotifyTelegram.notify (/opt/reactor/server/lib/NotifyTelegram.js:300:23)
        at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
        at async NotifyTelegram.sendNotification (/opt/reactor/server/lib/Notifier.js:189:137)
    [latest-26174]2026-06-26T18:04:45.983Z <Engine:ERR> Engine#1 reaction rule-2ajie2fd:S step 1 notification (Telegram) failed: [Error] NotifyTelegram request failed [-]
    [latest-26174]2026-06-26T18:04:45.983Z <Engine:CRIT> Error: NotifyTelegram request failed [-]
    [latest-26174]2026-06-26T18:04:45.983Z <NotifyTelegram:ERR> NotifyTelegram failure response text: {"ok":false,"error_code":400,"description":"Bad Request: chat_id is empty"}
    Snippet of the notification yaml with all the description text removed:
      # Telegram
      Telegram:
        profiles:
          default:
            description: Default Profile
            api_url: https://api.telegram.org
            bot_token: "[[REDACTED]]:[[REDACTED]]"
            default_chat_id: "[[REDACTED]]"
    • wmarcolinW Offline
      If it might help with the investigation, here is the error message I'm getting when I run the query.
      systemctl status reactor
      ● reactor.service - Multi System Reactor
      Loaded: loaded (/etc/systemd/system/reactor.service; enabled; preset: enabled)
      Drop-In: /etc/systemd/system/reactor.service.d
      └─override.conf
      Active: active (running) since Fri 2026-06-26 14:48:22 EST; 38min ago
      Main PID: 6370 (MainThread)
      Tasks: 11 (limit: 4599)
      Memory: 112.8M (peak: 157.1M)
      CPU: 28.239s
      CGroup: /system.slice/reactor.service
      └─6370 /usr/bin/node app -p
      Jun 26 15:06:23 reactor node[6370]: at async NotifyTelegram.sendNotification (/home/wilson/reactor/server/lib/Notifier.js:189:137)
      Jun 26 15:06:23 reactor node[6370]: [latest-26174]2026-06-26T20:06:23.394Z Engine:CRIT Error: NotifyTelegram request failed [-]
      Jun 26 15:06:23 reactor node[6370]: Error: NotifyTelegram request failed
      Jun 26 15:06:23 reactor node[6370]: at NotifyTelegram.notify (/home/wilson/reactor/server/lib/NotifyTelegram.js:300:23)
      Jun 26 15:06:23 reactor node[6370]: at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
      Jun 26 15:11:10 reactor node[6370]: [latest-26174]2026-06-26T20:11:10.209Z Engine:CRIT Error: terminated [preempted by rule state change]
      Jun 26 15:11:10 reactor node[6370]: Error: terminated
      Jun 26 15:11:10 reactor node[6370]: at Engine._process_reaction_queue (/home/wilson/reactor/server/lib/Engine.js:2091:47)
      Jun 26 15:11:10 reactor node[6370]: at process.processTicksAndRejections (node:internal/process/task_queues:104:5)
      root@reactor:/home/wilson/reactor/logs#
        OK. Fix coming soon...
        • 3 Offline
          3 Offline
          I upgraded the docker to version latest-26177-be756a68. Unfortunately I am still not getting my Telegram alerts unless I put the Chat ID in the GUI. I don't know if it matters, but my chat_id starts with a "-". I think I have another chat ID that does not start/show as a negative ID. I can't test with that ID though.
          • 3 Offline
            3 Offline
            Thank you @toggledbits. The latest-26177-3f86f4af build resolved the issue.
              I think my situation with Telegram is a little different. Version 26177 has actually partially resolved the sending issue.
              I have two profiles set up, with two token and two ChatID, as you can see below (change the token and ChatID). For the first profile, I can send a message without entering the Chat ID in “Set Reaction.” For the second profile, if I leave it blank, it doesn’t send the message—it doesn’t use the settings I’ve configured. If I enter the Chat ID for the second profile, then the message sends perfectly.
                # Telegram
                Telegram:
                  profiles:
                    default:
                      description: Default Familia
                      # api_url - NOTIFICATION Access URL for Telegram API. Default is https://api.telegram.org/
                      # bot_token - (required) Bot Token, from Telegram. See: https://core.telegram.org/bots
                      bot_token: "xxxxxxxxxx:AAEOr9ZY4LxxxxxxxKPYJBSBxxxxxxxxxx"
                      # default_chat_id - (required) Default chat ID to use if not specified in message. See
                      #                   this link for how to get chat ID:
                      #                   https://stackoverflow.com/questions/32423837/telegram-bot-how-to-get-a-group-chat-id
                      default_chat_id: "-1234567890"
                      # default_disable_notification - Default notification flag, may be either "true"
                      #                                or "false". The system default is "false"
                      #                                (false == notification enabled/not disabled).
                      default_disable_notification: "false"
                      # default_parse_mode - Default message format/parse mode. The system default is
                      #                      blank, for plain text. Other options: MarkdownV2, HTML
                      #                      See: https://core.telegram.org/bots/api#formatting-options
                      default_parse_mode: "HTML"
                    wilson:
                      # description - INFORMATION A friendly description of this profile (for menus)
                      description: Default Wilson
                      # api_url - Access URL for Telegram API. Default is https://api.telegram.org/
                      bot_token: "xxxxxxxxxx:AAEFPoERxxxxxxxxkKFdEHc3txxxxxxxxxx"
                      # 6272 default_chat_id: "1544809334"
                @toggledbits I ran tests after upgrading Node.js, and the scenario is as described above; for the second profile, it only works if you enter the Chat ID.
                  Now that the log file has fewer errors (Node.js), I can see this log message appear—I'm not sure if it helps.
                  [latest-26177]2026-06-28T23:20:20.829Z <NotifyTelegram:CRIT> Error: NotifyTelegram request failed [-]
                      at NotifyTelegram.notify (/home/wilson/reactor/server/lib/NotifyTelegram.js:304:23)
                      at async NotifyTelegram.sendNotification (/home/wilson/reactor/server/lib/Notifier.js:188:145)
                  [latest-26177]2026-06-28T23:20:20.830Z <Engine:ERR> Engine#1 reaction rule-mevuuj8w:S step 3 notification (Telegram) failed: [Error] NotifyTelegram request failed [-]
                  [latest-26177]2026-06-28T23:20:20.830Z <Engine:CRIT> Error: NotifyTelegram request failed [-]
                  [latest-26177]2026-06-28T23:20:20.831Z <NotifyTelegram:ERR> NotifyTelegram failure response text: {"ok":false,"error_code":400,"description":"Bad Request: chat not found"}
                    I came here as I was seeing the same Telegram behaviour. I only have one profile. so am happy that the fix will resolve it for me
                      @CatmanV2 A subsequent (to the prior post) respin of build 26177 fixed multiple profiles as well, so you're good either way.
                        As ever, my thanks. Upgraded to 26177 and all is well!
                          146.4k
