  4. [RESOLVED] Phantom device, “INFO” appears
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 2 Posters 367 Views 2 Watching
  • wmarcolinW Offline
    I'm seeing multiple warnings "INFO" like the one below in the Reactor log file.
    [latest-26177]2026-06-28T23:19:39.784Z <Engine:INFO> Resuming reaction HOME UPDATE 30/30<SET> (rule-me9cq25r:S) from step 5
    [latest-26177]2026-06-28T23:19:39.784Z <Engine:INFO> HOME UPDATE 30/30<SET> all actions completed.
    [latest-26177]2026-06-28T23:19:39.791Z <Engine:INFO> Engine#1 task 114 (rule-me9cq25r:S) has completed after restart
    [latest-26177]2026-06-28T23:19:40.211Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.214Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.312Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.314Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.413Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.414Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.513Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.515Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.615Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.616Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:40.716Z <HubitatController:INFO> HubitatController#hubitat ignoring DEVICE event for device 225 (Ping VM Reactor); device not enumerated by Maker API
    [latest-26177]2026-06-28T23:19:41.453Z <Rule:INFO> Panel Tripped (rule-mfdbsyrp in SharpTools) starting rule state evaluation; because predicate-state-changed Predicate#rule-mfdbsyrp/trig
    [latest-26177]2026-06-28T23:19:41.454Z <Rule:INFO> Panel Tripped (rule-mfdbsyrp in SharpTools) evaluated; rule state transition from SET to 'RESET'
    And that's correct; this device hasn't been exported from Hubitat to MSR.
    I ran a query to see if it was in any of the reactor's files, and the only thing I found was the information in the log.
    root@reactor:/home/wilson/reactor# grep -rl "hubitat>225" .
    root@reactor:/home/wilson/reactor# grep -rl "device 225" .
    ./logs/reactor.log.1
    ./logs/reactor.log.2
    ./logs/reactor.log.3
    ./logs/reactor.log
    I looked in the entity directory, and this device isn't there either.
    root@reactor:/home/wilson/reactor# cd storage/
    root@reactor:/home/wilson/reactor/storage# ls
    access_token.hex  default.dval  default.json.corrupted  expressions.dval  hostkey.key  reactions               reactor.pid  rulesets
    baseurl.sh        default.json  entities                expressions.json  hostkey.pub  reactor_inet_check.dat  rules        states
    root@reactor:/home/wilson/reactor/storage# cd entities/
    root@reactor:/home/wilson/reactor/storage/entities# cd hubitat/
    root@reactor:/home/wilson/reactor/storage/entities/hubitat# ls
    109.dval  138.json  147.dval  15.json   170.dval  211.json  24.dval   261.json  29.dval  48.json  62.dval   656.json  668.dval  679.json  76.dval  87.json
    109.json  139.dval  147.json  163.dval  170.json  219.dval  24.json   262.dval  29.json  49.dval  62.json   657.dval  668.json  67.dval   76.json  98.dval
    112.dval  139.json  148.dval  163.json  182.dval  219.json  253.dval  262.json  2.dval   49.json  63.dval   657.json  669.dval  67.json   7.dval   98.json
    112.json  13.dval   148.json  165.dval  182.json  21.dval   253.json  263.dval  2.json   51.dval  63.json   658.dval  669.json  681.dval  7.json   99.dval
    118.dval  13.json   149.dval  165.json  190.dval  21.json   254.dval  263.json  32.dval  51.json  64.dval   658.json  66.dval   681.json  83.dval  99.json
    118.json  142.dval  149.json  166.dval  190.json  220.dval  254.json  264.dval  32.json  57.dval  64.json   659.dval  66.json   68.dval   83.json  controller_all.dval
    11.dval   142.json  14.dval   166.json  19.dval   220.json  257.dval  264.json  3.dval   57.json  653.dval  659.json  676.dval  68.json   84.dval  controller_all.json
    11.json   143.dval  14.json   167.dval  19.json   224.dval  257.json  265.dval  3.json   58.dval  653.json  65.dval   676.json  69.dval   84.json  sys_hsm.dval
    123.dval  143.json  150.dval  167.json  201.dval  224.json  259.dval  265.json  46.dval  58.json  654.dval  65.json   677.dval  69.json   85.dval  sys_hsm.json
    123.json  144.dval  150.json  168.dval  201.json  22.dval   259.json  27.dval   46.json  60.dval  654.json  666.dval  677.json  70.dval   85.json  sys_mode.dval
    12.dval   144.json  151.dval  168.json  20.dval   22.json   260.dval  27.json   47.dval  60.json  655.dval  666.json  678.dval  70.json   86.dval  sys_mode.json
    12.json   146.dval  151.json  169.dval  20.json   23.dval   260.json  28.dval   47.json  61.dval  655.json  667.dval  678.json  74.dval   86.json  system.dval
    138.dval  146.json  15.dval   169.json  211.dval  23.json   261.dval  28.json   48.dval  61.json  656.dval  667.json  679.dval  74.json   87.dval  system.json
    Obviously, I can't find anything when I search in the Reactor GUI either.
    Where else should I look to try to resolve this situation?
      That's a bug in Maker API... it's sending updates for a device that isn't enumerated for export. You can safely ignore those messages.
        163.4k
