  4. Logon screen timeout
5 Posts 2 Posters 457 Views 2 Watching
    Noticing since 170 that the lock screen doesn't switch to the logon prompt but, rather, stays on the active UI until such time as you go to click something within it. Then it jumps to the login screen.
    Brave browser
    Brave 1.92.139 (Official Build) (arm64)
    Chromium: 150.0.7871.114
    *Hubitat C-7 2.5.2.135
    Core 2026.10.1
    MSR: latest-26287-0a7107d5
      Did you check the log files? Whenever something isn't working right, that should be the first place you look.
        @toggledbits I will the next time it times out. It's annoying but not debilitating so I deprioritized troubleshooting for other things. Dealing with a lot of work-related browser issues and this finally added to the pile 🙂
        Core 2026.10.1
          OK. I think I found it. Patched and respun the 26193 build, so pull that again and let's see if it behaves better.
            @toggledbits Damn you lol I'd just updated Brave a couple hours ago, then sat back lying in wait.
            I just now went to test it and it worked normally, I was logged out with the login screen visible. I thought "huh - musta been a Brave issue, well it's fixed now" - and then I saw both this post and the version change.
            Thank you, sir, as always!
            Core 2026.10.1
              148.9k
