I've seen many of you using Dynamic Group Controller. I'm using it myself for monitoring device battery levels. I've read and re-read the Dynamic Group Controller docs and still cannot come to an answer for my question so let me paint my scenario:
I've migrated from EchoSpeaks in Hubitat ('cause borked and seemingly unmaintained) to Alexa Devices in Home Assistant ('cause not borked in 2026.11.0) to be able to send TTS to my Echo devices.
In EchoSpeaks I could create groups. Sweet.
In Alexa Devices I don't seem to be able to do so. As such, my thought was "wait - isn't there a way in MSR?"
Is this an effective scenario that Dynamic Group Controller can be used for?
I'm trying to allow anonymous access from a local network to /api/v1/log, but the problem now with the reverse proxy configuration is that this access is open via proxy to the internet. At least I wasn't able to configure ACL so that only an access from a local network would be permitted.
reactor.yaml:
baseurl: "http://192.168.1.12:8111"
proxy_baseurl: "https://external.com:30000"
trusted_proxy: "192.168.1.12"
Local traffic would originate from 192.168.1.0/24 network. Synology is acting as a reverse proxy and hosting MSR as a docker container (which has its own network and IP 172.18.0.5). MSR build is latest-26298-fbb75fb8
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
Using the above ACL works, but it enables access via proxy also. If I use source_ip: 192.168.1.0/24, then it doesn't work either locally or remotely. So I'm kinda lost what should I use as source_ip in this case?
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Posters
242
Views
Watching
I have a couple of them. ie, this is from ESPHome via HASS.x_hass.domain="fan" x_hass.entity_id="fan.kitchen_seashell_hood_ventilation_fan" x_hass.floor_id=null x_hass.services=["fan","esphome"] x_hass.source="esphome" x_hass.state="off" x_hass_attr.friendly_name="Seashell Hood Ventilation Fan" x_hass_attr.percentage=50 x_hass_attr.percentage_step=25 x_hass_attr.preset_mode="" x_hass_attr.preset_modes=[] x_hass_attr.supported_features=49Thanks.
Can you add the following to your HassController config, restart, and post the contents of the dump file created (named
<controllerid>-fan_kitchen_seashell_hood_ventilation_fan.json). Thank you!config: # other stuff dump_entity: "fan_kitchen_seashell_hood_ventilation_fan": true -
Here we go. Sorry for the delay, crazy days at work:
{ "entity_id": "fan.kitchen_seashell_hood_ventilation_fan", "state": "off", "attributes": { "preset_modes": [], "percentage": 50, "percentage_step": 25, "preset_mode": "", "friendly_name": "Seashell Hood Ventilation Fan", "supported_features": 49 }, "last_changed": "2026-09-19T04:06:16.582977+00:00", "last_reported": "2026-09-19T04:06:16.582977+00:00", "last_updated": "2026-09-19T04:06:16.582977+00:00", "context": { "id": "01M2VXFV869XHBDKVKPFSSCC21", "parent_id": null, "user_id": null }, "source": { "domain": "esphome" } }Thanks.
