  4. Reactor Build 26284 stuck at Loading Reactor UI
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
16 Posts 2 Posters 1.9k Views 2 Watching
    I found two cases where proxy-handling behavior can be triggered even though Reactor isn't configured with proxy info. Build 26287 contains fixes for those.
    @toggledbits said in Reactor Build 26284 stuck at Loading Reactor UI:
    I updated to the 26287 build, commented out my public IP, and the behavior returned.
    I put removed the comment so it's working currently. As a work around, I set up a crontab that checks my public IP hourly, replaces the line with the IP (new or not), then reboots the docker instance. This is working but, I have a feeling the hourly restarts will bite me at some point.
      I found the proxy section in the doc (search function works great).
      I added my cloudflare URL in a below baseurl and recommented by public IP.
      proxy_baselurl: https://reactor.xyz.com #not xyz.com
      I am now getting Access Denied.
      Edit: I also tried it with quotes around the URL. I'm not sure why, but in your documentation you have quotes around the baseurl URL and the proxy_baseurl with an IP, but in the next section with a FQDN, there is no quotes. Is that intentional, or does it matter?
      • T tamorgen
        @tamorgen said in Reactor Build 26284 stuck at Loading Reactor UI:
        Must include port number
        Best practice to quote it. Makes no difference to Reactor as long as the YAML parser accepts it (the quotes assure that).
          I tried both 443 and 8554. When I go to the url in my browser, the port is simply 443. Cloudflare forwards the traffic to my local (Private) IP via the tunnel and port number. I tried using both port numbers, and neither works. I don't think my setup is so much a proxy in the way that reactor is expecting.
          So, when i try and access my reactor instance, I goto https://reactor.xyz.com (not xyz.com). Cloudflare has a tunnel established the a cloudflare client on my server, and the reactor.xyz.com has a service published of https://192.168.x.x:8554. Cloudflare establishes the SSL certificate for the domain.
          When I look in the logs, I see this
          [latest-26287]2026-10-17T00:12:07.524Z httpapi:WARN httpapi#1 request from "aaa.bbb.ccc.ddd" rejected (IP restriction)
          Which shows my public IP
            There's a reason that I ask that log data is always posted with context (lots of preceding lines): often there are messages before that provide hints or additional data that are important to troubleshooting. There is a line logged for httpapi prior to one you included that would be useful to see. I'd also like to see all of the related configuration settings as you have them right now.
              I'm not seeing anything in the logs when I perform a tail -f and reload the page, other than reactions prior to the httpapi warning.
              tmorgenthaler@docker:~/reactor/logs$ sudo tail -f reactor.log
              [latest-26287]2026-10-17T12:39:53.325Z <ZWaveJSController:5:ZWaveJSController.js:876> ZWaveJSController#zwavejs _apply_value dimming.level=1 force_update=false
              [latest-26287]2026-10-17T12:39:53.326Z <ZWaveJSController:5:ZWaveJSController.js:966> ZWaveJSController#zwavejs setting Light#zwavejs>263-0.x_zwave_values.Multilevel_Switch_currentValue to 99
              [latest-26287]2026-10-17T12:39:53.527Z <ZWaveJSController:5:ZWaveJSController.js:361> ZWaveJSController#zwavejs handling event message
              [latest-26287]2026-10-17T12:39:53.527Z <ZWaveJSController:5:ZWaveJSController.js:471> ZWaveJSController#zwavejs handling event { "source": "controller", "event": "statistics updated", "statistics": { "messagesTX": 21708, "messagesRX": 102412, "messagesDroppedRX": 27, "NAK": 0, "CAN": 0, "timeoutACK": 0, "timeoutResponse": 0, "timeoutCallback": 0, "messagesDroppedTX": 0, "backgroundRSSI": { "channel0": { "current": -105, "average": -105 }, "channel1": { "current": -106, "average": -106 }, "channel2": { "current": -106, "average": -106 }, "channel3": { "current": -92, "average": -93 }, "timestamp": 1792240767719 } } }
              [latest-26287]2026-10-17T12:39:53.547Z <ZWaveJSController:5:ZWaveJSController.js:361> ZWaveJSController#zwavejs handling event message
              [latest-26287]2026-10-17T12:39:53.547Z <ZWaveJSController:5:ZWaveJSController.js:471> ZWaveJSController#zwavejs handling event { "source": "node", "event": "statistics updated", "nodeId": 263, "statistics": { "commandsTX": 3154, "commandsRX": 3351, "commandsDroppedRX": 1, "commandsDroppedTX": 0, "timeoutResponse": 1, "lwr": { "protocolDataRate": 4, "repeaters": Array(0) [], "rssi": -66, "repeaterRSSI": Array(0) [] }, "lastSeen": "2026-10-17T12:39:53.315Z", "rtt": 43.9, "rssi": -60 } }
              [latest-26287]2026-10-17T12:39:53.547Z <ZWaveJSController:5:ZWaveJSController.js:486> ZWaveJSController#zwavejs handling node event statistics updated entity Light#zwavejs>263-0
              [latest-26287]2026-10-17T12:39:53.848Z <DynamicGroupController:INFO> DynamicGroupController#groups processing pending updates for Array(2) ["door_sensors", "interior_motion"]
              [latest-26287]2026-10-17T12:39:55.595Z <Rule:INFO> Alarm State (rule-grpq7soqaj in Home Modes) starting rule state evaluation; because predicate-state-changed Predicate#rule-grpq7soqaj/trig
              [latest-26287]2026-10-17T12:39:55.595Z <Rule:INFO> Alarm State (rule-grpq7soqaj in Home Modes) evaluated; rule state transition from RESET to 'SET'
              [latest-26287]2026-10-17T12:39:58.347Z <ZWaveJSController:5:ZWaveJSController.js:361> ZWaveJSController#zwavejs handling event message
              [latest-26287]2026-10-17T12:39:58.348Z <ZWaveJSController:5:ZWaveJSController.js:471> ZWaveJSController#zwavejs handling event { "source": "controller", "event": "statistics updated", "statistics": { "messagesTX": 21708, "messagesRX": 102413, "messagesDroppedRX": 27, "NAK": 0, "CAN": 0, "timeoutACK": 0, "timeoutResponse": 0, "timeoutCallback": 0, "messagesDroppedTX": 0, "backgroundRSSI": { "channel0": { "current": -105, "average": -105 }, "channel1": { "current": -106, "average": -106 }, "channel2": { "current": -106, "average": -106 }, "channel3": { "current": -92, "average": -93 }, "timestamp": 1792240767719 } } }
              [latest-26287]2026-10-17T12:39:58.597Z <ZWaveJSController:5:ZWaveJSController.js:361> ZWaveJSController#zwavejs handling event message
              [latest-26287]2026-10-17T12:39:58.597Z <ZWaveJSController:5:ZWaveJSController.js:471> ZWaveJSController#zwavejs handling event { "source": "controller", "event": "statistics updated", "statistics": { "messagesTX": 21709, "messagesRX": 102413, "messagesDroppedRX": 27, "NAK": 0, "CAN": 0, "timeoutACK": 0, "timeoutResponse": 0, "timeoutCallback": 0, "messagesDroppedTX": 0, "backgroundRSSI": { "channel0": { "current": -105, "average": -105 }, "channel1": { "current": -107, "average": -106 }, "channel2": { "current": -107, "average": -106 }, "channel3": { "current": -92, "average": -93 }, "timestamp": 1792240798344 } } }
              [latest-26287]2026-10-17T12:39:58.783Z <httpapi:WARN> httpapi#1 request from "174.172.AAA.BB" rejected (IP restriction)
              And here is the first area of reactor.yaml that pertains to proxy and permitted ips:
              # See the Reactor documentation at https://reactor.toggledbits.com/docs/
              # Template version 22127
              # Try this browser-based YAML editor: https://onlineyamltools.com/edit-yaml
              # Here's a quick YAML checker: https://www.yamlchecker.com/
              reactor:
                # baseurl - The base URL to access the Reactor system. If you want to use
                #           HTTPS, please see the How-To section of the docs.
                baseurl: "https://192.168.1.70:8554"
                proxy_baseurl: "https://reactor.xyz.org:443"
                pki_certfile: reactor1.crt
                pki_keyfile: reactor1.key
                # allowed_ips - List (array) of IP addresses/prefixes allowed access.
                #               if empty (default, commented out), all IPs are allowed. If
                #               you wish to filter (recommended), uncomment the lines below
                #               and edit the addresses as needed to match your network.
                allowed_ips:
                #  - "127.0.0.1"
                #  - "192.168.0."  # or whatever your local trusted subnet
                  - "192.168.1.0/24"
                #  - "174.172.AAA.BB" # MY_DYNAMIC_IP
                  - "169.252.4.16/29"
                  - "169.253.162.0/29"
                OK. Please do this: make the httpapi section of config/logging.yaml look like below (or add if not present):
                  httpapi:
                    level: 5
                    streams:
                      - type: file
                        recycle: true
                        keep: 4
                        maxsize: 2
                        level: 999
                Also add trusted_proxy: "127.0.0.2" to your config/reactor.yaml (after the baseurls is a good spot).
                Restart Reactor. Launch a request from the remote side of the tunnel. There should be messages logged in httpapi.log for that request that say either httpapi#1 starting request from <ip> for... or httpapi#1 starting proxied request from <ip> via <ip> for....
                If the logged message is the first form, or it's the second form and the two IP addresses logged ("from" and "via") are identical, there is no stable internal (CloudFlare) address seen on the request from your tunnel. This means you can't use allowed_ips (at all) unless your external request address is stable and can be listed in it.
                If the logged message is the second form (<ip> via <ip>), and the two IP addresses are different, then the second address is the (detectable) inside address of the tunnel. In that case, you would replace the 127.0.0.2 in trusted_proxy with that ("via") IP address, and add pass_all_proxy: true to config/reactor.yaml.
                Since your tunnel is not a reverse proxy, I suspect you're going to be in the former situation. I'm just hoping to be surprised.
                    httpapi:
                      level: 5
                      streams:
                        - type: file
                          recycle: true
                          keep: 4
                          maxsize: 2
                          level: 999
                  Okay, done.
                  Here's what I'm seeing:
                  [latest-26287]2026-10-17T13:50:39.179Z <wsapi:5:wsapi.js:538> (event handler) sending update for 5 entities
                  [latest-26287]2026-10-17T13:50:39.332Z <wsapi:INFO> wsapi: SSL/TLS connection from "174.172.AAA.BB" via ::ffff:192.168.1.73 (TLSv1.3)
                  [latest-26287]2026-10-17T13:50:39.333Z <wsapi:WARN> wsapi: rejecting request from "174.172.AAA.BB"; IP restriction
                  [latest-26287]2026-10-17T13:50:39.377Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.378Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.379Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.380Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.402Z <wsapi:5:wsapi.js:538> (event handler) sending update for 5 entities
                  [latest-26287]2026-10-17T13:50:39.545Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.546Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.547Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.571Z <wsapi:5:wsapi.js:538> (event handler) sending update for 4 entities
                  [latest-26287]2026-10-17T13:50:39.696Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.697Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.698Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.722Z <wsapi:5:wsapi.js:538> (event handler) sending update for 4 entities
                  [latest-26287]2026-10-17T13:50:39.945Z <wsapi:INFO> wsapi: SSL/TLS connection from "174.172.AAA.BB" via ::ffff:192.168.1.73 (TLSv1.3)
                  [latest-26287]2026-10-17T13:50:39.945Z <wsapi:WARN> wsapi: rejecting request from "174.172.AAA.BB"; IP restriction
                  [latest-26287]2026-10-17T13:50:39.955Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.956Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.957Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.958Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  [latest-26287]2026-10-17T13:50:39.970Z <wsapi:5:wsapi.js:555> (event handler): sending data
                  It still appears to be seeing the my public facing IP, but it does say "via" the IP of my Cloudflared VM, which is covered in the allowed IP's via the 192.168.1.0/24.
                  Uncommenting the hard coded public IP does work. Unless you can think of another work around, I see one of two options.
                  • Leave it hard coded, and manually change it if I get the Access Denied page.
                  • Have the crontab run daily in the middle of the night to check the IP and update the config as needed.
                  I will say that I don't believe my public IP changes often, however, I don't know what that interval is for certain. It is not a static IP, and unless I'm a business, I don't believe Xfinity will give me one.
                  • T tamorgen
                    Okay, done.
                    I just reread that last part about the different addresses. I changed the local 127.0.0.2 to 192.168.1.73 and restarted the service.
                    reactor:
                      trusted_proxy: "192.168.1.73"
                      allowed_ips:
                      #  - "127.0.0.1"
                        - "192.168.1.0/24"
                        - "169.252.4.16/29"
                    I am still getting access denied:
                    [latest-26287]2026-10-17T14:40:32.708Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:32.733Z <wsapi:5:wsapi.js:538> (event handler) sending update for 1 entities
                    [latest-26287]2026-10-17T14:40:32.959Z <wsapi:INFO> wsapi: SSL/TLS connection from "174.172.AAA.BB" via ::ffff:192.168.1.73 (TLSv1.3)
                    [latest-26287]2026-10-17T14:40:32.960Z <wsapi:WARN> wsapi: rejecting request from "174.172.AAA.BB"; IP restriction
                    [latest-26287]2026-10-17T14:40:33.028Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.029Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.030Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.054Z <wsapi:5:wsapi.js:538> (event handler) sending update for 5 entities
                    [latest-26287]2026-10-17T14:40:33.342Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.343Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.344Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.368Z <wsapi:5:wsapi.js:538> (event handler) sending update for 3 entities
                    [latest-26287]2026-10-17T14:40:33.454Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.479Z <wsapi:5:wsapi.js:538> (event handler) sending update for 1 entities
                    [latest-26287]2026-10-17T14:40:33.516Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.517Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.542Z <wsapi:5:wsapi.js:538> (event handler) sending update for 1 entities
                    [latest-26287]2026-10-17T14:40:33.736Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.737Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.738Z <wsapi:5:wsapi.js:555> (event handler): sending data
                    [latest-26287]2026-10-17T14:40:33.761Z <wsapi:5:wsapi.js:538> (event handler) sending update for 5 entities
                    [latest-26287]2026-10-17T14:40:33.893Z <wsapi:INFO> wsapi: SSL/TLS connection from "174.172.AAA.BB" via ::ffff:192.168.1.73 (TLSv1.3)
                    [latest-26287]2026-10-17T14:40:33.893Z <wsapi:WARN> wsapi: rejecting request from "174.172.AAA.BB"; IP restriction
                      SOVLED: I forgot the pass_all_proxy: true line!
                      Thank you much Patrick!
                        165.2k
