  4. UI not loading after upgrading to 26318
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 2 Posters 84 Views 2 Watching
    wrote last edited by tunnus
    authtrack:
      max_attempts: 4
    EDIT: some logs
      Stop Reactor, remove the auth.json and auth.dval files from the storage directory, restart Reactor.
      This will also invalidate all auths for all clients. Everyone will need to log in again.
      If you want something a little less dramatic, stop Reactor, edit auth.json and remove the contents of the value under authtrack (i.e. make it read value: {} with nothing between the curly braces). Then delete auth.dval and restart Reactor.
        @toggledbits thanks, this solved my issue
        • tunnusT tunnus marked this topic as a question
        • tunnusT tunnus has marked this topic as solved
          authtrack:
            max_attempts: 4
          EDIT: some logs
          @tunnus said in UI not loading after upgrading to 26318:
          By the way, I didn't fully catch this on my earlier reading, but this is not true. At least, it's not the design. Blocking only blocks a single host IP address. You should be able to make the request to the clear_authtrack endpoint from any other IP (as long as you can correctly authenticate from that IP). You definitely won't be able to do it from the same IP that got blocked, of course, but any other IP should work.
          The other thing is that that endpoint will not stop the docker container. That would actually be an unexpected result (bug) for that endpoint.
            163.1k
