Edit: Fixed in re-spun 26328.
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up).
Bare metal latest-26328
Issue 1: Nodes don't update in Reactor after update from 26318.
Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start.
Notice: No device mapping matches Intrusion Sensor.I don't know if you still support EzloController but seems like an easy fix?
Let me know if you need more info!
[latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online. -
Given the state of things on the Pequod, I've been wondering if anybody is still left using EzloController. But, let me have a squiz and see what I can do. Busy today, so may be more towards evening (US Eastern).
I managed to map
Intrution SensorandSirenin local_ezlo_devices.yaml.
Here are the attributes if you want to add them to the controller:Intrusion Sensor:
binary_sensor.state=false x_ezlo_device.battery_powered=true x_ezlo_device.category="security_sensor" x_ezlo_device.manufacturer="Unknown" x_ezlo_device.model="Unknown" x_ezlo_device.parent="6b02d41d129e0715b720f012" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="6b02d224129e0715b720f011" x_ezlo_device.status="idle" x_ezlo_device.subcategory="intrusion" x_ezlo_device.type_id="374_5_1" x_ezlo_item.intrusion_alarm="no_intrusion" x_ezlo_item.security_threat=false x_ezlo_object.id="6b02d41e129e0715b720f01c" x_ezlo_object.name="Intrusion Sensor" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Unknown","Unknown",null] zwave_device.node_id=6 zwave_device.version_info=nullSiren:
battery_power.alert_level=0.5 battery_power.level=0.8 battery_power.since=1795628243922 power_switch.state=false x_ezlo_device.battery_powered=true x_ezlo_device.category="siren" x_ezlo_device.manufacturer="Everspring/Hawking/Chromagic" x_ezlo_device.model="SE812" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="6b02d224129e0715b720f011" x_ezlo_device.status="idle" x_ezlo_device.subcategory="" x_ezlo_device.type_id="96_12_1" x_ezlo_item.battery=80 x_ezlo_item.switch=false x_ezlo_object.id="6b06ff24129e0715b41e4ff0" x_ezlo_object.name="Siren Garaget" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Everspring/Hawking/Chromagic","SE812",null] zwave_device.node_id=17 zwave_device.version_info=null -
The 26328 build has been re-spun with a fix for EzloController. Give it a go!
Now available
ezlo_data.zipwith support for your two devices (hopefully... I can't fully test without the devices themselves). Place that in yourconfigdirectory and remove (or rename) your own local file and restart. -
[latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.@Crille said in [Solved] EzloController throws error in latest-26328:
OT: how the thing's going? I have a couple in my drawer and I'm wondering if you run it "plain", or with some modifications. I could try to give some AI a try to find how to change this in this, and repurpose to some Zwave repeater or similar, even if I admin I'm more than OK after switching to Home Assistant's ZWA-2. but I'll do because I'm bored during winter
I modified mine years ago to purpose as a WiFi access point but I think it bogged up when it thought it couldn't reach Ezlos servers in bridged mode (hardcoded interface name test in fw), the Ezlo firmware was still running to handle the VistaCam 1203 Doorbell (not the best but given as beta test, that's still mounted).
To gain access to Z-wave devices that went out of reach from Vera it was a quick fix to test Ezlo in it's own Z-wave network. I tried it as secondary to Vera first (pita to achieve) but realised it added no value at all.
It's factory reset and running as Ezlo intended but after just a couple of days I ordered new sensors and devices with Thread or Zigbee to replace the most critical ones because even when the hub is no more than 3-4 meters from any device it's sometimes a bit of hit and miss sending and receiving data.
I will keep it in the garage for a few remaining non critical devices, until they are replaced as well, and control/present values in Apple Home thanks to ezmqtt and when the doorbell is replaced I'm sure the Ezlo Plus goes offline forever unless @therealdb finds a good use I can borrow and replicate
My long term goal is to phase out Z-wave in favor of Matter/Thread and Zigbee.
