Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
New to the forum
Welp, I'm not getting anywhere with this. I tried installing over my previous install once again and then navigating to the address provided (http://172.31.206.111:3480/data_request?id=altui ). If anything, things are getting worse. The openLuup page is no longer formatted properly and lacks the graphic element that was there the first time around.
Here's my latest log:2020-12-14 01:54:34.563 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2020-12-14 01:54:34.563 openLuup.init:: init phase completed 2020-12-14 01:54:34.563 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x557ccbcb5a68 2020-12-14 01:54:34.563 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x557ccbd381c8 2020-12-14 01:54:34.563 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x557ccbd141c8 2020-12-14 01:54:34.563 openLuup.historian:: starting data historian 2020-12-14 01:54:34.563 openLuup.historian:: using memory cache size (per-variable): 1024 2020-12-14 01:54:34.563 openLuup.scheduler:: starting 2020-12-14 01:54:34.563 openLuup.scheduler:: [2] openLuup device startup 2020-12-14 01:54:34.563 luup_log:2: v20.5.22 2020-12-14 01:54:34.563 luup_log:2: sync in 85.4 s 2020-12-14 01:54:34.563 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2020-12-14 01:54:34.563 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2020-12-14 01:54:34.563 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2020-12-14 01:54:34.564 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2020-12-14 01:54:34.564 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2020-12-14 01:54:34.564 luup.chdev.append:: [AltAppStore] Alternate App Store 2020-12-14 01:54:34.564 luup.chdev.sync:: [2] openLuup, syncing children 2020-12-14 01:54:34.564 luup_log:2: 1Mb, 0%cpu, 0.0days 2020-12-14 01:54:34.564 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 85.4 s, name=L_openLuup 2020-12-14 01:54:34.564 openLuup.scheduler:: [3] Alternate App Store device startup 2020-12-14 01:54:34.564 luup_log:3: AltAppStore : starting... 2020-12-14 01:54:34.564 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine1 was: EMPTY now: AltAppStore #hooks:0 2020-12-14 01:54:34.564 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: EMPTY now: #hooks:0 2020-12-14 01:54:34.564 luup.variable_set:: 3.urn:upnp-org:serviceId:AltAppStore1.Version was: EMPTY now: v20.3.30 #hooks:0 2020-12-14 01:54:34.564 luup_log:3: AltAppStore : v20.3.30 2020-12-14 01:54:34.564 luup.set_failure:: status = 0 2020-12-14 01:54:34.564 luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: EMPTY now: 0 #hooks:0 2020-12-14 01:54:34.564 luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0 2020-12-14 01:54:34.564 openLuup.scheduler:: [3] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2020-12-14 01:56:00.050 luup_log:2: synchronising to on-the-minute 2020-12-14 01:56:00.050 luup.call_timer:: interval: time=2m, days={} 2020-12-14 01:56:00.050 luup_log:2: 2 minute timer launched 2020-12-14 01:56:00.050 luup_log:2: 2Mb, 0%cpu, 0.0days 2020-12-14 01:57:09.812 openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbe5faf8 2020-12-14 01:57:09.814 openLuup.server:: GET / HTTP/1.1 tcp{client}: 0x557ccbe5faf8 2020-12-14 01:57:09.814 openLuup.server:: request completed (194 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe5faf8 2020-12-14 01:57:10.466 openLuup.server:: GET /data_request?id=lr_ALTUI_Handler&command=home HTTP/1.1 tcp{client}: 0x557ccbe5faf8 2020-12-14 01:57:10.466 openLuup.servlet:: No handler for data_request?id=lr_ALTUI_Handler 2020-12-14 01:57:10.466 openLuup.server:: request completed (153 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe5faf8 2020-12-14 01:57:10.524 openLuup.server:: GET /favicon.ico HTTP/1.1 tcp{client}: 0x557ccbe5faf8 2020-12-14 01:57:10.524 openLuup.servlet:: file not found:favicon.ico 2020-12-14 01:57:10.525 openLuup.server:: request completed (126 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe5faf8 2020-12-14 01:58:00.133 luup_log:0: 2Mb, 0%cpu, 0.0days 2020-12-14 01:58:24.472 openLuup.server:: GET /data_request?id=altui HTTP/1.1 tcp{client}: 0x557ccbe5faf8 2020-12-14 01:58:24.473 luup.call_action:: 3.urn:upnp-org:serviceId:AltAppStore1.update_plugin 2020-12-14 01:58:24.473 luup_log:3: AltAppStore : starting <run> phase... 2020-12-14 01:58:24.473 luup_log:3: AltAppStore : downloading amg0/ALTUI [master] to trash/AltAppStore/ 2020-12-14 01:58:24.473 luup_log:3: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=master 2020-12-14 01:58:25.268 luup_log:3: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=master 2020-12-14 01:58:25.678 luup_log:3: AltAppStore : getting contents of version: master 2020-12-14 01:58:25.678 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0 2020-12-14 01:58:25.678 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: Alternate UI #hooks:0 2020-12-14 01:58:25.678 luup_log:3: AltAppStore : scheduling <job> phase... 2020-12-14 01:58:25.678 openLuup.requests:: 2020-12-14 01:58:25.678 openLuup.server:: request completed (0 bytes, 0 chunks, 1205 ms) tcp{client}: 0x557ccbe5faf8 2020-12-14 01:58:30.958 luup_log:3: AltAppStore : starting <job> phase... 2020-12-14 01:58:30.958 luup_log:3: AltAppStore : download failed, status: wantread 2020-12-14 01:58:30.958 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI failed #hooks:0 2020-12-14 01:59:56.243 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x557ccbe5faf8 2020-12-14 02:00:00.051 luup_log:0: 2Mb, 0.1%cpu, 0.0days 2020-12-14 02:02:00.110 luup_log:0: 2Mb, 0%cpu, 0.0days 2020-12-14 02:04:00.062 luup_log:0: 3Mb, 0%cpu, 0.0days 2020-12-14 02:06:00.116 luup_log:0: 2Mb, 0%cpu, 0.0days 2020-12-14 02:07:33.504 openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.504 openLuup.server:: GET / HTTP/1.1 tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.504 openLuup.server:: request completed (194 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.575 openLuup.server:: GET /data_request?id=lr_ALTUI_Handler&command=home HTTP/1.1 tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.576 openLuup.servlet:: No handler for data_request?id=lr_ALTUI_Handler 2020-12-14 02:07:33.576 openLuup.server:: request completed (153 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.647 openLuup.server:: GET /favicon.ico HTTP/1.1 tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.647 openLuup.servlet:: file not found:favicon.ico 2020-12-14 02:07:33.647 openLuup.server:: request completed (126 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:07:33.647 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557ccbe8a1f8 2020-12-14 02:08:00.103 luup_log:0: 2Mb, 0%cpu, 0.0days 2020-12-14 02:08:01.193 openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.194 openLuup.server:: GET /openLuup HTTP/1.1 tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.194 openLuup.wsapi:: using openLuup/console.lua for openLuup 2020-12-14 02:08:01.196 openLuup.wsapi:: using REQUIRE to load CGI openLuup/console.lua 2020-12-14 02:08:01.206 openLuup.server:: request completed (8063 bytes, 0 chunks, 12 ms) tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.819 openLuup.server:: GET /w3.css HTTP/1.1 tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.819 openLuup.server:: request completed (0 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.821 openLuup.server:: GET /icons/openLuup.svg HTTP/1.1 tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.821 openLuup.server:: request completed (458 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe949c8 2020-12-14 02:08:01.821 openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbeddd88 2020-12-14 02:08:06.822 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557ccbeddd88 2020-12-14 02:08:13.090 openLuup.server:: GET /openLuup?page=log HTTP/1.1 tcp{client}: 0x557ccbe949c8
@therealdb What is the difference between Windows Terminal and PowerShell? Are you suggesting that I type my commands into Terminal instead of Ubuntu Bash?
@quixote said in New to the forum:
It's a multi-window terminal. No differences, besides side-by-side window, colors, and much more.
2020-12-14 01:58:30.958 luup_log:3: AltAppStore : download failed, status: wantreadSo, it's not able to download AltUI. Have you tried running
sudo ./openLuup_reload
@therealdb said in New to the forum:
Have you tried running sudo ./openLuup_reload?
That's a really good suggestion.
@akbooer Sorry... I'm just kind of at the end of my rope here, other stuff included. My apologies.
So please explain to me how I misspelled openLuup when I've been meticulously spelling it over and over like literally hundreds of times in the last week or two. I must be losing it. Perhaps a sign for me to take up another hobby? -
No, that's fine. Quite understand.
This has not gone smoothly for you, despite others chipping in to try and help.
If you want to leave it here, that's OK, of course. If you want to come back to it on a better day, then just ask.
Good luck.
I'm not an idiot, and I've installed and worked on several complicated systems, both hard and software related, but it seems that I have some sort of technological curse. I'm not even kidding -- I can follow directions to the tee without a single deviation, it will fuck up. Ok, so I misspelled "openLuup" once, but I assure you, I've been super attentive to every instruction and somehow things just aren't gelling. I understand case-sensitive commands, etc.
I wish I were a Linux nerd. Too bad gaming pulled me into Micro$oft Winblows as a kid. It is what it is.
So, I've literally followed "the idiot proof" instructions, changed my Linux distribution according to instruction, reinstalled multiple times, ... I guess that's it then?
I'm sorry for taking up so much of you guys' time. -
Well, OK. Sorry for taking your time...
...but I did think it was worth one last time with Alpine:
https://smarthome.community/topic/276/openluup-windows-subsystem-for-linux-wsl
I had no idea you had put so much effort into this. I'll give it one last try.
You didn't take my time -- I took my own. We were trying something unconventional and I knew that even before attempting this, so don't worry about it. Sorry if I was snarky but it seems like everything I've been trying relating to HA in the last year or so has gone dreadfully wrong.
I'll try it out when I feel up to it and let you know how things go.
Thanks -
