  3. New to the forum
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
New to the forum
81 Posts 6 Posters 50.3k Views 6 Watching
  • Q Offline
    Q Offline
    Quixote
    Yes, multiple times. Like, multi multi times.
      #71
      Have you tried Alpine, next? We seem to have two examples of that working already...
      ...although I do still wonder whether if isn’t a more fundamental Windows issue, but it would be good to try.
      Q 1 Reply Last reply
        Q Offline
        Q Offline
        Quixote
        #72
        @akbooer
        alt text Can't even get a f*****g image to display here. I think I'm about done here.
        • Q Quixote
          @akbooer
          @quixote
          You can't do it in 'Quick Reply', but just using 'Reply' gives you a menu or drag-and-drop:
          ...it would help if you had spelled openLuup correctly.
            @quixote
            Q Offline
            Q Offline
            Quixote
            @akbooer Sorry... I'm just kind of at the end of my rope here, other stuff included. My apologies.
            So please explain to me how I misspelled openLuup when I've been meticulously spelling it over and over like literally hundreds of times in the last week or two. I must be losing it. Perhaps a sign for me to take up another hobby? 😕
            • Q Offline
              Q Offline
              Quixote
              #75
              ah shit. I see it now.
              Think I'm just worn down at this point. That''s embarrassing.
              • Q Quixote
                @quixote said in New to the forum:
                No, that's fine. Quite understand.
                This has not gone smoothly for you, despite others chipping in to try and help.
                If you want to leave it here, that's OK, of course. If you want to come back to it on a better day, then just ask.
                Good luck.
                • Q Offline
                  Q Offline
                  Quixote
                  #77
                  I'm not an idiot, and I've installed and worked on several complicated systems, both hard and software related, but it seems that I have some sort of technological curse. I'm not even kidding -- I can follow directions to the tee without a single deviation, it will fuck up. Ok, so I misspelled "openLuup" once, but I assure you, I've been super attentive to every instruction and somehow things just aren't gelling. I understand case-sensitive commands, etc.
                  I wish I were a Linux nerd. Too bad gaming pulled me into Micro$oft Winblows as a kid. It is what it is.
                  So, I've literally followed "the idiot proof" instructions, changed my Linux distribution according to instruction, reinstalled multiple times, ... I guess that's it then?
                  I'm sorry for taking up so much of you guys' time. 😞
                    Well, OK. Sorry for taking your time...
                    ...but I did think it was worth one last time with Alpine:
                    https://smarthome.community/topic/276/openluup-windows-subsystem-for-linux-wsl
                    • Q Offline
                      Q Offline
                      Quixote
                      I had no idea you had put so much effort into this. I'll give it one last try.
                      You didn't take my time -- I took my own. We were trying something unconventional and I knew that even before attempting this, so don't worry about it. Sorry if I was snarky but it seems like everything I've been trying relating to HA in the last year or so has gone dreadfully wrong.
                      I'll try it out when I feel up to it and let you know how things go.
                      • Q Quixote
                        As I said, I'm runing openLuup in WSL since 2+ years. It's my development instance. So, nothing really unconventional, because it's a linux VM, after all.
                        • Q Offline
                          Q Offline
                          Quixote
                          Well, that may be true for you, but as we've seen with the Cyberpunk 2077 launch, different systems seem to yield different results. 😉
                            154.0k
